Im driving 8 relay module using Arduino and at the same time using an 1602 LCD Display and a Ultra sound Scanner to detect if object exists.
Program below.
It works for a while, after a while it gets stuck. Even i cannot provide any characters using Serial Monitor/Plotter once stuck. No pattern on when it gets stuck
Im using Python in RPI to drive the Arduino.
No separate power supply used, however, Relay has its own 12v power supply.
Any help would be much appreciated.
#include <lcd_i2c.h>
char receivedChar;
boolean newData = false;
const int pingPin = 10; // Trigger Pin of Ultrasonic Sensor
const int echoPin = 11; // Echo Pin of Ultrasonic Sensor
boolean nameDisplayFlag=false;
boolean pumpDisplayFlag=false;
boolean errorDisplayFlag=false;
long duration,cm;
char pumpDisplay[17] = "Dispense00000000";
lcd_i2c lcd(0x3E,16,2);
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(9, OUTPUT);
//US Scanner
pinMode(pingPin, OUTPUT);
pinMode(echoPin, INPUT);
digitalWrite(2, HIGH);
digitalWrite(3, HIGH);
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);
digitalWrite(6, HIGH);
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
digitalWrite(9, HIGH);
// LCD
lcd.begin();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Welcome ");
//Serial.println(cm);
recvInfo();
operateMotor();
if (checkNotDispensing() && nameDisplayFlag == false && errorDisplayFlag==false){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Welcome ... ");
nameDisplayFlag = true;
pumpDisplayFlag = false;
if (!checkNotDispensing() && pumpDisplayFlag == false && errorDisplayFlag==false){
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Welcome.....");
lcd.setCursor(0,1);
lcd.print("Dispensing......");
nameDisplayFlag = false;
pumpDisplayFlag = true;
void recvInfo() {
if (Serial.available() > 0) {
receivedChar = Serial.read();
newData = true;
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(10);
duration = pulseIn(echoPin, HIGH);
cm = microsecondsToCentimeters(duration);
if(cm > 15 && checkONData()){
lcd.clear();
lcd.setCursor(0,0);
lcd.setCursor(0,1);
receivedChar='Z';
newData = false;
errorDisplayFlag=true;
lcd.print("ABORTED-No Object");
Serial.println(cm);
while(Serial.available() > 0) {Serial.read();}
}else{
errorDisplayFlag= false;
}//Serial.println("V=");
void operateMotor() {
while(newData == true) {
if( receivedChar == 'A'){
pumpDisplay[8]='0';
if(receivedChar == 'B'){
pumpDisplay[8]='1';
digitalWrite(2, LOW);
if( receivedChar == 'C'){
pumpDisplay[9]='0';
if(receivedChar == 'D'){
pumpDisplay[9]='1';
digitalWrite(3, LOW);
if( receivedChar == 'E'){
pumpDisplay[10]='0';
if(receivedChar == 'F'){
digitalWrite(4, LOW);
pumpDisplay[10]='1';
if( receivedChar == 'G'){
pumpDisplay[11]='0';
if(receivedChar == 'H'){
pumpDisplay[11]='1';
digitalWrite(5, LOW);
if( receivedChar == 'I'){
pumpDisplay[12]='0';
if(receivedChar == 'J'){
pumpDisplay[12]='1';
digitalWrite(6, LOW);
if( receivedChar == 'K'){
pumpDisplay[13]='0';
if(receivedChar == 'L'){
pumpDisplay[13]='1';
digitalWrite(7, LOW);
if( receivedChar == 'M'){
pumpDisplay[14]='0';
if(receivedChar == 'N'){
pumpDisplay[14]='1';
digitalWrite(8, LOW);
if( receivedChar == 'O'){
pumpDisplay[15]='0';
if(receivedChar == 'P'){
pumpDisplay[15]='1';
digitalWrite(9, LOW);
Serial.print(receivedChar);
newData = false;
long microsecondsToCentimeters(long microseconds) {
return microseconds / 29 / 2;
boolean checkNotDispensing(){
if( pumpDisplay[8] == '0' && pumpDisplay[9] == '0' && pumpDisplay[10] == '0' && pumpDisplay[11] == '0'
&& pumpDisplay[12] == '0' && pumpDisplay[13] == '0' && pumpDisplay[14] == '0'
&& pumpDisplay[15] == '0' ){
return true;
else{
return false;
boolean checkONData(){
if(receivedChar == 'B' || receivedChar == 'D'|| receivedChar =='F'|| receivedChar =='H'|| receivedChar =='J'|| receivedChar =='L'|| receivedChar =='N'|| receivedChar =='P'){
return true;
} else{
return false;
