Arduino gets stuck and have to reflash to get started
I am using the following code on Arduino MKR1500, where the device connects to a MQTT broker and publishes ADC value. This code runs for some time (example 3-5 mins) and then gets stuck. Even if I reset it, it does not get started with trying to connect to internet. I have to reflash it to get it working again. Can you please let me know what could be causing that issue?
  Adapted from ArduinoMqttClient - WiFi Simple Receive Callback
  This example connects to a MQTT broker and subscribes to a single topic.
  When a message is received it prints the message to the serial monitor,
  it uses the callback functionality of the library.
  This example also publishes a sensor value to a separate topic
  The circuit:
  - Arduino MKR 1000, MKR 1010 or Uno WiFi Rev.2 board
  This example code is in the public domain.
#include <ArduinoMqttClient.h>
#include <MKRNB.h>
// Please enter your sensitive data in the Secret tab or arduino_secrets.h
// PIN Number
const char PINNUMBER[]     = "";
// MQTT Broker and Port
const char broker[] = "test.mosquitto.org"; //
int        port     = 1883;
// Pub/Sub Topics - Make it something unique since we are using a public broker
const char subscribeTopic[]  = "test";
const char publishTopic[]  = "test";
// To connect with SSL/TLS:
// 1) Change NBClient to NBSSLClient.
// 2) Change port value from 1883 to 8883.
// 3) Change broker value to a server with a known SSL/TLS root certificate
//    flashed in the WiFi module.
NBClient client;
GPRS gprs;
NB nbAccess;
MqttClient mqttClient(client);
int LED = 6; // Onboard LED
// Publish interval
long previousMillis = 0;
long interval = 11000;
  pinMode(LED, OUTPUT); // Set built in LED pinMode
  //Initialize serial and wait for port to open:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // attempt to connect to GSM and GPRS:
  Serial.print("Attempting to connect to GSM and GPRS");
   // connection state
  bool connected = false;
  // After starting the modem with GSM.begin()
  // attach the shield to the GPRS network with the APN, login and password
  while (!connected) {
    if ((nbAccess.begin(PINNUMBER) == NB_READY) &&
        (gprs.attachGPRS() == GPRS_READY)) {
      connected = true;
      Serial.println("Not connected");
  Serial.println("You're connected to the network");
  // You can provide a unique client ID, if not set the library uses Arduino-millis()
  // Each client can have a unique client ID
  // mqttClient.setId("clientId");
  // You can provide a username and password for authentication
  // mqttClient.setUsernamePassword("username", "password");
  Serial.print("Attempting to connect to the MQTT broker: ");
  Serial.println(broker);
  if (!mqttClient.connect(broker, port)) {
    Serial.print("MQTT connection failed! Error code = ");
    Serial.println(mqttClient.connectError());
    while (1);
  Serial.println("You're connected to the MQTT broker!");
  // set the message receive callback
  mqttClient.onMessage(onMqttMessage);
  Serial.print("Subscribing to topic: ");
  Serial.println(subscribeTopic);
  // subscribe to a topic
  mqttClient.subscribe(subscribeTopic);
  // topics can be unsubscribed using:
  // mqttClient.unsubscribe(topic);
  Serial.print("Waiting for messages on topic: ");
  // call poll() regularly to allow the library to receive MQTT messages and
  // send MQTT keep alives which avoids being disconnected by the broker
  mqttClient.poll();
  // Enforce Interval
  if(currentMillis - previousMillis > interval) {
        // Call a function that handles publishing message
        publishSensorVal();
void publishSensorVal() {
    // read the first Analog pin
    int sensorVal = analogRead(0);
    String speak = "The sensor val is " + String(sensorVal);
    // Publish our sensor value to the publish topic
    mqttClient.beginMessage(publishTopic);
    mqttClient.print(speak);
    mqttClient.endMessage();
void handleCommand(String cmd) {
  if (cmd == "on"){
    digitalWrite(LED, HIGH);
  }else if(cmd == "off"){
    digitalWrite(LED, LOW);
void onMqttMessage(int messageSize) {
  // we received a message, print out the topic and contents
  Serial.println("Received a message with topic '");
  Serial.print(mqttClient.messageTopic());
  Serial.print("', length ");
  Serial.print(messageSize);
  Serial.println(" bytes:");
  // We want to read each character into a useable String
  String content = "";
  char character;
  // use the Stream interface to print the contents
  while (mqttClient.available()) {
    character = (char)mqttClient.read();
    content.concat(character);
  handleCommand(content); // This function does something with our incoming string
  Serial.println(content);
  Serial.println(); Serial.println(); // double spacing
You have embedded debug prints, so at what point in the output print does it freeze?
It published the adc values in the serial monitor for a few min and then it will get stuck without any error. I checked the device manager to check if the USB still shows up there and it was(just to ensure that it is not a bad connection or bad cable).
It's probably the String class crashing because of memory fragmentation.
In loop(), you need to test if the MQTT broker is still connected.
I have two functions that I call from setup() and loop():
// =====  mqttReconnect =====
void mqttReconnect() {
  //mqttConnect
  //Make sure we stay connected to the mqtt broker
  if (!client.connected()) {
    mqttConnect();
  if (!client.loop()) {
    client.connect(hostName);
//=====  mqttConnect =====
void mqttConnect() {
  client.setServer(mqttServer, mqttPort); //Call the setServer method
  while (!client.connected()) {
    Serial.print(F("MQTT connecting..."));
    if (client.connect(hostName)) {
      Serial.println(F("connected"));
      client.setCallback(callback);
      //Subscriptions:
      client.subscribe(cmndTopic);
      Serial.print(F("Subscribing to "));
      Serial.println(cmndTopic);
      Serial.print(F("failed, rc="));
      Serial.print(client.state());
      Serial.println(F("- trying again in 5-seconds."));
      delay(5000);
In setup, I call
mqttConnect();
in loop I call
mqttReconnect(); //Make sure we stay connected to the mqtt broker
Hi @SteveMann : is that code available on github, so I can adopt the code and work on it
Here is my current project that uses MQTT
Download the whole zip, then look in src. Both lid and tail use MQTT.
Thanks @SteveMann!!
