Hello everyone. I'm a bit new using this Arduino Giga board paired with this sensor : WT901SDCL-BT50. It's a 9-axis IMU and I'm using it for a robotic application involving Exoskeleton on the lower limbs. I was trying to make sense of the communication protocol to better extract all the data and display it on the serial monitor every time it refresh which I think it's approximately 20Hz, but I'm having issues because it connects but doesn't show the data. Can I receive some guidance? This is the closest program I have got.
#include <ArduinoBLE.h>
while (!Serial)
// begin initialization
if (!BLE.begin()) {
Serial.println("starting Bluetooth® Low Energy module failed!");
Serial.println("Bluetooth® Low Energy Central - Peripheral Explorer");
// start scanning for peripherals
BLE.scan();
// check if a peripheral has been discovered
BLEDevice peripheral = BLE.available();
if (peripheral) {
// discovered a peripheral, print out address, local name, and advertised service
Serial.print("Found ");
Serial.print(peripheral.address());
Serial.print(" '");
Serial.print(peripheral.localName());
Serial.print("' ");
Serial.print(peripheral.advertisedServiceUuid());
// see if peripheral is a WTSDCL
if (peripheral.localName() == "WTSDCL") {
int len = 28;
byte value[len];
// stop scanning
BLE.stopScan();
// peripheral connected, read data
while (1) {
// Process the received data
processData(value, len);
delay(2000);
// Function to process received data
void processData(byte *data, int len) {
static byte dataBuffer[28];
static int bufferIndex = 0;
for (int i = 0; i < len; i++) {
byte b = data[i];
if (b == 0x55) { // Check for packet start
bufferIndex = 1; // Next byte is flag
dataBuffer[0] = b;
} else if (bufferIndex > 0 && bufferIndex < sizeof(dataBuffer)) {
dataBuffer[bufferIndex++] = b;
if (bufferIndex == sizeof(dataBuffer)) { // Packet complete
if (!processPacket(dataBuffer)) {
Serial.println("Failed to process packet");
bufferIndex = 0;
// Function to process a complete packet
bool processPacket(byte *packet) {
if (packet[0] != 0x55 || packet[1] != 0x61) {
Serial.println("Invalid packet");
return false;
// Extract data from the packet
int ax = ((packet[3] << 8) | packet[2]);
int ay = ((packet[5] << 8) | packet[4]);
int az = ((packet[7] << 8) | packet[6]);
int wx = ((packet[9] << 8) | packet[8]);
int wy = ((packet[11] << 8) | packet[10]);
int wz = ((packet[13] << 8) | packet[12]);
int roll = ((packet[15] << 8) | packet[14]);
int pitch = ((packet[17] << 8) | packet[16]);
int yaw = ((packet[19] << 8) | packet[18]);
// Convert to physical units
float ax_g = ax / 32768.0 * 16.0;
float ay_g = ay / 32768.0 * 16.0;
float az_g = az / 32768.0 * 16.0;
float wx_dps = wx / 32768.0 * 2000.0;
float wy_dps = wy / 32768.0 * 2000.0;
float wz_dps = wz / 32768.0 * 2000.0;
float roll_deg = roll / 32768.0 * 180.0;
float pitch_deg = pitch / 32768.0 * 180.0;
float yaw_deg = yaw / 32768.0 * 180.0;
// Output data to Serial Monitor
Serial.print("Acceleration (g): ");
Serial.print(ax_g);
Serial.print("\t");
Serial.print(ay_g);
Serial.print("\t");
Serial.print(az_g);
Serial.print("\n");
Serial.print("Angular Velocity (°/s): ");
Serial.print(wx_dps);
Serial.print("\t");
Serial.print(wy_dps);
Serial.print("\t");
Serial.print(wz_dps);
Serial.print("\n");
Serial.print("Angle (°): ");
Serial.print(roll_deg);
Serial.print("\t");
Serial.print(pitch_deg);
Serial.print("\t");
Serial.print(yaw_deg);
Serial.print("\n\n");
return true;
Can you guide me on what I'm doing wrong here?
WT901SDCL-BT50 Communication Protocol.pdf (568.1 KB)
