Arduino Giga Local weather, Wifi, temboo or openweather
Is it possible to get my local temperature and humidity from internet to my Arduino Giga using temboo or something similar free service?
I just need code for printing the info to serial.
The code could use GPS-coordinates or city name.
Thanks in advance.
I also have an API-key to openweathermap.org so I can use that.
Does anyone know is Arduino Giga R1 Wifi compatible with OpenWeather -library at all?
I have tried the following code (sorry, the comments are in finnish):
#include <WiFi.h>
#include <ArduinoJson.h>
#include <HttpClient.h>
const char *ssid = "xxxx";
const char *password = "xxxx";
const char *apiKey = "xxxx";
const char *apiEndpoint = "https://api.openweathermap.org/data/2.5/weather?lat=61.4981&lon=23.7444&appid=";
void getWeatherData() {
  // Luo WiFiClient-objekti
  WiFiClient client;
  // Muodosta API-kutsu
  String apiURL = String(apiEndpoint) + apiKey;
  Serial.print("Lähetetään HTTP-pyyntö: ");
  Serial.println(apiURL);
  // Yhdistä palvelimeen
  if (client.connect("api.openweathermap.org", 80)) {
    // Lähetä HTTP-pyyntö
    client.print(String("GET ") + apiURL + " HTTP/1.1\r\n" +
             "Host: api.openweathermap.org\r\n" +
             "User-Agent: ArduinoWiFi/1.1\r\n" +
             "Connection: close\r\n\r\n");
    Serial.println("Yhteys epäonnistui");
    return;
  // Odota vastausta
  while (!client.available()) {
    delay(4000);
String responseHeader = client.readStringUntil('\r\n\r\n');
String response = client.readString();
Serial.println("Vastaus:");
Serial.println(response);
  // Lue vastaus JSON-muodossa
  DynamicJsonDocument jsonDoc(2048);
  DeserializationError jsonError = deserializeJson(jsonDoc, client);
 serializeJsonPretty(jsonDoc, Serial);
  if (jsonError) {
    Serial.print("JSON-parsinta epäonnistui: ");
    Serial.println(jsonError.c_str());
    // Tulosta säätiedot
    const char *description = jsonDoc["weather"][0]["description"];
    float temperature = jsonDoc["main"]["temp"];
    Serial.print("Sää: ");
    Serial.println(description);
    Serial.print("Lämpötila: ");
    Serial.println(temperature);
  // Sulje yhteys
  client.stop();
  // Yhdistetään WiFi-verkkoon
  WiFi.begin(ssid, password);
    delay(5000);
    Serial.println("Yhdistetään WiFi-verkkoon...");
  Serial.println("Yhdistetty WiFi-verkkoon!");
  // Hae säätiedot ja tulosta ne sarjaporttiin
  getWeatherData();
  // Ei tehdä mitään tässä ohjelmassa
and the output to serial is:
Vastaus:
Server: openresty
Date: Mon, 20 Nov 2023 15:12:32 GMT
Content-Type: application/json; charset=utf-8
Content-Length: 486
Connection: close
X-Cache-Key: /data/2.5/weather?lat=61.5&lon=23.74
Access-Control-Allow-Origin: *
Access-Control-Allow-Credentials: true
Access-Control-Allow-Methods: GET, POST
{"coord":{"lon":23.7444,"lat":61.4981},"weather":[{"id":803,"main":"Clouds","description":"broken clouds","icon":"04n"}],"base":"stations","main":{"temp":270.27,"feels_like":265.67,"temp_min":269.85,"temp_max":270.88,"pressure":1017,"humidity":94},"visibility":10000,"wind":{"speed":3.58,"deg":299,"gust":4.92},"clouds":{"all":75},"dt":1700493152,"sys":{"type":2,"id":2081862,"country":"FI","sunrise":1700462700,"sunset":1700487383},"timezone":7200,"id":661226,"name":"Amuri","cod":200}
nullJSON-parsinta epäonnistui: IncompleteInput
So I think the problem is in my JSON parsing code.
Unfortunately I have no idea how to fix it.
Can anyone help?
