Arduino Giga using AdvancedADC in a class to read from 3 analog pins; problem
Hello to all,
I tested the following slightly modified sketch from the examples of Arduino_AdvancedAnalog and it works fine.
But up to now I didn't succeed in packing the used function into a class in order to automate the whole analog-reading procedure in a project.
AnalogIn.ino:
#include <Arduino_AdvancedAnalog.h>
char tmp[64] = "";
AdvancedADC adc(A0, A1, A2);
uint64_t last_millis = 0;
	// Resolution, sample rate, number of samples per channel, queue depth.
		if (!adc.begin(AN_RESOLUTION_12, 16000, 32, 96)) { // ok
			Serial.println("Fehler Start adc");
		while (1);
	if (adc.available()) {
		SampleBuffer buf = adc.read();
		// Process the buffer.
		if (millis() - last_millis > 333) {
			sprintf(tmp, "Wert A0: %d", buf[0]);
			Serial.println(tmp);  // Wert von Kanal 1
			sprintf(tmp, "Wert A1: %d", buf[1]);
			sprintf(tmp, "Wert A2: %d", buf[2]);
			last_millis = millis();
		// Direct access to the underlying buffer.
		// buf.data()
		// Release the buffer to return it to the pool.
		buf.release();
I tried to do the following schematic:
analogIn.h:
class z;
extern z Z;
class z {
  advancedADC *adc;
  bool StartADC();
  int getVal(int n);
analogIn.cpp:
z Z;
z::StartADC() {
  return adc->begin(AN_RESOLUTION_12, 16000, 32, 96);
z::getVal(int n) {
if (adc->available()) {
    SampleBuffer buf = adc->read();
    return buf[n];
    return -1;
  buf.release();
So analogIn.h is included in the main program, usb started, StartADC() called and then getVal(i). When calling getVal(i), the program crashes. What I'm doing wrong? Your help is appreciated!
Regards
Gjg_P320
P.S.: I tried also this and it doesn't work:
analogIn.h:
class z;
extern z Z;
class z {
  bool StartADC();
  int getVal(int n);
analogIn.cpp:
z Z;
z::StartADC() {
  return adc.begin(AN_RESOLUTION_12, 16000, 32, 96);
z::getVal(int n) {
    return buf[n];
    return -1;
  buf.release();
