Arduino Google Maps API directions result zero
We have tried the direction example provided by googlemaps api library. Everything is working fine except that the returned values are zero. The API key is valid and the esp8266 is connecting perfectly to the wifi. We think that maybe arduino is sending a wrong request that can not be understood by google maps api.
<#include <GoogleMapsDirectionsApi.h>
  • An example of usisng the directions api to get *
  • travel time (with traffic) between two locations *
  • Example also shows setting a waypoint if you want a specific *
  • route *
  • Written by Brian Lough *
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
//------- Replace the following! ------
char ssid[] = "SSID"; // your network SSID (name)
char password[] = "PASSWORD"; // your network key
#define API_KEY "XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX" // your google apps API Token
WiFiClientSecure client;
GoogleMapsDirectionsApi api(API_KEY, client);
//Free Google Maps Api only allows for 2500 "elements" a day, so carful you dont go over
unsigned long api_mtbs = 60000; //mean time between api requests
unsigned long api_due_time = 0;
bool firstTime = true;
//Inputs
String origin = "Galway";
String destination = "Dublin,Ireland";
String waypoints = "via:Cork,Ireland"; //You need to include the via: before your waypoint
//Optional
DirectionsInputOptions inputOptions;
// Set WiFi to station mode and disconnect from an AP if it was Previously
// connected
WiFi.mode(WIFI_STA);
WiFi.disconnect();
delay(100);
// Attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
IPAddress ip = WiFi.localIP();
Serial.println(ip);
//These are all optional (although departureTime needed for traffic)
inputOptions.departureTime = "now"; //can also be a future timestamp
inputOptions.trafficModel = "best_guess"; //Defaults to this anyways
inputOptions.avoid = "ferries";
inputOptions.units = "metric";
void checkGoogleMaps() {
Serial.println("Getting traffic for " + origin + " to " + destination);
DirectionsResponse response = api.directionsApi(origin, destination, inputOptions);
Serial.println("Response:");
Serial.print("Trafic from ");
Serial.print(response.start_address);
Serial.print(" to ");
Serial.println(response.end_address);
Serial.print("Duration in Traffic text: ");
Serial.println(response.durationTraffic_text);
Serial.print("Duration in Traffic in minutes: ");
Serial.println(response.durationTraffic_value);
Serial.print("Normal duration text: ");
Serial.println(response.duration_text);
Serial.print("Normal duration in minutes: ");
Serial.println(response.duration_value);
Serial.print("Distance text: ");
Serial.println(response.distance_text);
Serial.print("Distance in meters: ");
Serial.println(response.distance_value);
unsigned long timeNow = millis();
if ((timeNow > api_due_time)) {
Serial.println("Check With No Waypoint");
inputOptions.waypoints = "";
checkGoogleMaps();
Serial.print("Check With Waypoint: ");
Serial.println(waypoints);
inputOptions.waypoints = waypoints;
checkGoogleMaps();
api_due_time = timeNow + api_mtbs;
