yep i bet this questions been hit a thousand times in the past but with the dawn on Arm based Arduino's i think it has more then a fighting chance
this projects goal is simple
computerize a simple single cylinder or v twin engines
taking over 3 things
- throttle yep drive by wire (helps with air control)
- Fuel (simple 30~40psi on a high impedance injector)
- Spark
sensors to be used
Math
Map
TPS
RPM
Maybe o2 but not in the works yet
i have a full shop
2X repraps, CnC machine,and tools list runs on, and more then i need as far as parts and sensors go.
this is not my first venture in to micro-controllers.
3X hexpods, 2X UAV's and my self driving, 3d mapping kinect rover that can kick Pi's FPU's
with it's intel Core i7 2600K oc'd to 4.6ghz(real time full color 3D mapping with 3 xbox kinect's eats cpu power more then you know)
mind you all i'm much better with C#, java, python, then MCU's and hardware.
just need some ideas to get me going.
First project will be my mini chopper it's 230cc 4 stroke V twin with RHB31 Turbo
i want to try and used maybe one of my JR mini servos as they rock for throttle but might use a feedback loop with a pot and steeper for safety.
i CnC'd a fuel pump for it about year ago still going strong reg set to 25psi tested to 140psi at 1270cc/min peek
