Arduino GPS client, perl server inserting into mysql DB
Hello again,
I have a perl server running waiting for a connection from the Arduino to receive lat and long coordinates to be inserted into a mysql database. The Arduino is connecting with the server ok but I can't work out how to actually send to the server any data never mind the data I want. I know the lat and long data is there as I previously had it outputting to a web page. I did modify this code to work with my perl server, so I may have started off on the wrong foot all together? :frowning:
Really struggling so any help as always is much appreciated:
server.pl (perl server)
sub listener
    my $dbh = shift || return;
# auto-flush on socket
    $| = 1;
# creating a listening socket
    my $socket = new IO::Socket::INET (
        LocalHost => '0.0.0.0',
        LocalPort => '7777',
        Proto => 'tcp',
        Listen => 5,
        Reuse => 1
        die "cannot create socket $!\n" unless $socket;
        print "server waiting for client connection on port 7777\n";
        print "\n";
    while(1)
        my $client_socket = $socket->accept();        # waiting for a new client connection
# get information about a newly connected client
        my $client_address = $client_socket->peerhost();
        my $client_port = $client_socket->peerport();
        print "connection from $client_address:$client_port\n";
# read up to 1024 characters from the connected client
        my $data = "";
        $client_socket->recv($data, 1024);
print "Received: $data";
        @array = unpack ("sff","$data");
        my $deviceid  = $array[0];
        my $latitude  = $array[1];
        my $longitude = $array[2];
        print "DeviceID: $deviceid \n";
        print "Latitude: $latitude \n";
        print "Longitude: $longitude \n";
        print "\n";
# write response data to the connected client
        $data = "message received from server";
        $client_socket->send($data);
        insertGPSData($dbh, $deviceid, $latitude, $longitude);  #send data to INSERT function
        shutdown($client_socket, 1);      # notify client that response has been sent
    $socket->close();
Arduino Loop Code:
// GPS LOOP START
  while(uart_gps.available())     // While there is data on the RX pin...
      int c = uart_gps.read();    // load the data into a variable...
      if(gps.encode(c))      // if there is a new valid sentence...
        getgps(gps);         // then grab the data.
// Define the variables that will be used
  float latitude, longitude;
// Then call this function
  gps.f_get_position(&latitude, &longitude);
//GPS LOOP FINISH
//ETHERNET LOOP START
  if (client) {
    Serial.println("new client");
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        // if you've gotten to the end of the line (received a newline
        // character) and the line is blank, the http request has ended,
        // so you can send a reply
        if (c == '\n' && currentLineIsBlank) {
          client.write("123");
          client.print(latitude,5);
          client.print(longitude,5);
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
Is the PERL server running on the Arduino, or on a remote server?
In the latter case, you would need to give the remote server's IP address, instead of "0.0.0.0".
You would also need a way to connect to the internet, or network (in case the PERL server is on your local LAN), either with a network shield, or GSM shield
