Arduino GPS Problem
http://arduino.cc/forum/index.php?topic=150925.0
I am experiencing the exact same problem... Does anyone have an answer? It literally happens everytime I plug the GPS in. If the GPS is unplugged, then it works perfectly.
avrdude: stk500_getsync(): not in sync: resp=0xe0 That error only occurs when the ARduino doesn't respond. Please let me know what you guys think, thanks
Then you know what to do. What is the problem?
Ok, I've tried plugging the GPS back in after the code compiles and nothing gets sent back to the serial monitor window. I will double check. Thanks for responding
I FIXED THIS PROBLEM! I had to update everything and plug in GPS after uploading code. Thanks!
Would you be so kind as to share how do you fix it? What do you mean by update everything?
LumbaG: Ok, I've tried plugging the GPS back in after the code compiles and nothing gets sent back to the serial monitor window. I will double check. Thanks for responding
