Can you show me your code?
Yes, below is the code I am using for testing.
//Jeremy Blum's Arduino Tutorial Series - Episode 15 - GPS Tracking
//Sample Code 2 - Logging GPS Data to an SD Card
//http://www.jeremyblum.com
//TinyGPS Library and Helper Functions by Mikal Hart http://arduiniana.org/libraries/tinygps/
#include <TinyGPS.h>
#include <SD.h>
#include <stdlib.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
It uses an Arduino Mega with a GPS attached to Serial1 at 4800 buad.
TinyGPS gps;
static char dtostrfbuffer[20];
int LED = 13;
//Define String
String SD_date_time = "invalid";
String SD_lat = "invalid";
String SD_lon = "invalid";
String dataString ="";
static void gpsdump(TinyGPS &gps);
static bool feedgps();
static void print_float(float val, float invalid, int len, int prec, int SD_val);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
const int SD1 = 11; //MOSI pin on shield, connect to MOSI pin on board (pin 51)
const int SD2 = 12; //MISO pin on shield, connecto to MISO pin on board (pin 50)
const int SD3 = 13; //SCK pin on shield, connecto to SCK pin on board (pin 52)
int CS = 53; //CS pin on board, connect to D10 on the shield (CS pin for shield)
pinMode(SD1,INPUT);
pinMode(SD2,INPUT);
pinMode(SD3,INPUT);
pinMode(CS, OUTPUT); //Chip Select Pin for the SD Card
pinMode(LED, OUTPUT); //LED Indicator
//Serial interfaces
Serial.begin(38400);
Serial1.begin(38400);
//Connect to the SD Card
if(!SD.begin(CS))
Serial.println("Card Failure");
return;
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.print("Sizeof(gpsobject) = "); Serial.println(sizeof(TinyGPS));
Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
Serial.println("--------------------------------------------------------------------------------------------------------------------------------------");
bool newdata = false;
unsigned long start = millis();
// Every second we print an update
while (millis() - start < 1000)
if (feedgps())
newdata = true;
gpsdump(gps);
//Write the newest information to the SD Card
dataString = SD_date_time + "," + SD_lat + "," + SD_lon;
if(SD_date_time != "invalid")
digitalWrite(LED, HIGH);
digitalWrite(LED, LOW);
//Open the Data CSV File
File dataFile = SD.open("LOG.csv", FILE_WRITE);
if (dataFile)
dataFile.println(dataString);
Serial.println(dataString);
dataFile.close();
Serial.println("\nCouldn't open the log file!");
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const float LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5, 1); //LATITUDE
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5, 2); //LONGITUDE
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps); //DATE AND TIME
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2, 0);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2, 0);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0UL : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2, 0);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
feedgps();
char sz[32];
if (val == invalid)
sz[len] = 0;
if (len > 0)
sz[len-1] = ' ';
for (int i=7; i<len; ++i)
sz[i] = ' ';
Serial.print(sz);
if(SD_val == 1) SD_lat = sz;
else if(SD_val == 2) SD_lon = sz;
Serial.print(val, prec);
if (SD_val == 1) SD_lat = dtostrf(val,10,5,dtostrfbuffer);
else if (SD_val == 2) SD_lon = dtostrf(val,10,5,dtostrfbuffer);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1);
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(" ");
feedgps();
int year;
byte month, day, hour, minute, second, hundredths;
unsigned long age;
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
if (age == TinyGPS::GPS_INVALID_AGE)
Serial.print("******* ******* ");
char sz[32];
sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",
month, day, year, hour, minute, second);
Serial.print(sz);
SD_date_time = sz;
feedgps();
int slen = strlen(str);
for (int i=0; i<len; ++i)
Serial.print(i<slen ? str[i] : ' ');
feedgps();
while (Serial1.available())
if (gps.encode(Serial1.read()))
return true;
return false;
The course information is going to be meaningless unless you are actually moving.
Yeah that is for sure since it seem to be the difference between 2 positions. If it is 2x the same Positions. The pointer is null
Hey!
I don't have your particular kind of GPS, how ever, I got the thing to work at speed 38400. So I got lot of:
* *** 0 0.00 *** 0 0 0
invalid,******* ,*******
But it does record the data on the SD card. There are lot of bug on you code so I'm just gonna paste the new version:
#include <SD.h>
#include <stdlib.h>
#include <SPI.h>
TinyGPS gps;
int CS = 10;
int LED = 13;
void setup(){
Serial.begin(57600);
if(!SD.begin(CS)) {
return;
Serial.print(F("Testing TinyGPS library v. "));
Serial.println(F("by Mikal Hart"));
Serial.print(F("Sizeof(gpsobject) = "));
Serial.println(F("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum"));
Serial.println(F(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail"));
Serial.println(F("--------------------------------------------------------------------------------------------------------------------------------------"));
void loop(){
while (millis() - start < 1000) {
if (feedgps()) newdata = true;
gpsdump(gps);
if(SD_date_time != "invalid") digitalWrite(LED, HIGH);
else digitalWrite(LED, LOW);
if (dataFile) {
dataFile.close();
else Serial.println("\nCouldn't open the log file!");
static void gpsdump(TinyGPS &gps){
float flat, flon;
static void print_int(unsigned long val, unsigned long invalid, int len){
char sz[32];
if (val == invalid) strcpy(sz, "*******");
else sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i) sz[i] = ' ';
if (len > 0) sz[len-1] = ' ';
Serial.print(sz);
feedgps();
static void print_float(float val, float invalid, int len, int prec, int SD_val){
char sz[32];
if (val == invalid) {
sz[len] = 0;
for (int i=7; i<len; ++i) sz[i] = ' ';
Serial.print(sz);
else {
for (int i=flen; i<len; ++i) Serial.print(F(" "));
feedgps();
static void print_date(TinyGPS &gps){
int year;
unsigned long age;
if (age == TinyGPS::GPS_INVALID_AGE) {
Serial.print(F("******* ******* "));
else {
char sz[32];
sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ", month, day, year, hour, minute, second);
Serial.print(sz);
SD_date_time = sz;
feedgps();
static void print_str(const char *str, int len){
for (int i=0; i<len; ++i) Serial.print(i<slen ? str[i] : ' ');
feedgps();
static bool feedgps(){
while (Serial1.available()) {
if (gps.encode(Serial1.read())) return true;
return false;
But here is a few clue.
- you need to declare the SPI.h library.
- you should not use pin 53 for CC I got it hooked on 10. You can put what ever pin that you prefer actually 10 is the default for SPI.
- you should not assign the pin for the spi port your self, the SPI library does it by it self.
- the SPI port on mega256 is at pin 50 pin 51 and pin 52.
- the MOSI pin and CLK pin are OUTPUT, I just say but don't mess with them as I said the library does it for you
So try this and give me new about it.
Oh one last thing, the IDE serial port monitor does not seem to support the speed 38400bps, I don't know why since it's a the product of 9600bps x 4, but any way. I't could be a good thing to set your Serial port 0 speed to a speed that is compatible with the IDE serial port monitor, while leaving the Serial1 at speed 38400. I would suggest to put it a 57600 to make sure you don't get a buffer over run problem.
Hello,
The code you gave me logs the data when its warming up, like when the result is ******. But when the GPS fixes and valid data comes through, the serial monitor prints that it can't open log file.
The results I get:
**** **** ******* ******* **** ******* ******* **** ******* ****** ***** *** 0 0.00 *** 25873 0 3
**** **** ******* ******* **** ******* ******* **** ******* ****** ***** *** 0 0.00 *** 26206 0 3
**** **** ******* ******* **** ******* ******* **** ******* ****** ***** *** 0 0.00 *** 26539 0 3
5 164 37.87208 -122.28707126 08/06/2014 05:57:34 131 33.60 0.00 2.46 N 8603 32.68 NNE 26982 2 3Couldn't open the log file!
5 164 37.87208 -122.28707234 08/06/2014 05:57:35 239 33.90 0.00 0.63 N 8603 32.68 NNE 27399 4 3Couldn't open the log file!
5 164 37.87207 -122.28707259 08/06/2014 05:57:36 264 34.10 0.00 0.41 N 8603 32.68 NNE 27842 6 3Couldn't open the log file!
5 164 37.87207 -122.28707285 08/06/2014 05:57:37 290 34.70 0.00 0.30 N 8603 32.68 NNE 28293 8 3Couldn't open the log file!
I don't know why you defined those functions to be "static", as that will have no meaningful effect.
You can use pin 53 for the chip select signal to the sd card reader, there is no reason why you cannot.
What is the point of your "newdata" variable ? You set this if new data has come from the gps, but then you don't use it.
Your sd card may have had its formatting damaged. try to read the information which is already there. try deleting any existing log.txt file. Try reformatting the sd card.
So, you are saying here, it works when you start it up, and it writes invalid data into the sd card file, and then when the gps actuallly starts working, then it cannot write to the sd file any more ????
The only way this could be happening, is that when all those complicated print functions get run for invalid data, then they work, but when they run for good data, and execute different parts of the code in those print functions, then you are running out of memory or getting data corruption somehow.
To be clear, I don't think it is a bug with any of the code actually related to the sd card open/write/close operation.
Try getting rid of all that printing, by not calling gpsdump( ) at all, and see what happens. You might need to write a short alternative function which justs gets the time and lattitude and longitude from the gps class object, but doesn't do anything else.
This bit of code in your printfloat( ) function is dubious.
It only sets a value into the strings SD_lat and SD_long in the case where the data is invalid. which would seem to be the wrong thing to do.
The char array sz is not null-terminated.
You are relying on some kind of unknown assignment from a char array to a string. There may be a suitable default assignment overload, but I would not do it that way.
Personally, I would not use the tinygps, cause it's far from tiny.
By the way you are right muchinyon, there is no problem using the pin 53, I was cross remembering 2 info that don't belong together, my mistake. Just any pin will do just fine.
I must admit there was lot of crap in the code, I changed it just enough to make it work on my system. But really, you know that all your NMEA data are split by "," so do a routine that will extract just the part you need, and drop the rest.
Your problem is not when you fetch data from you serial port, and it's not when you send stuff to your SD card, so it as to be in between. The running out of memory hypotheses is the bet. Tinygps does so much useless stuff with the data it get, although it does it well I checked in the library, that running out of memory is more then probable.
Tinygps, is a demo program meant to see if you gps is working. Well that is the way I see it any way.
It's really strange cause with this exact code, excepte at a gps communication speed of 4800 bps I get this in my log file:
08/06/2014 17:58:39 , 45.78860, -74.00496
08/06/2014 17:58:40 , 45.78860, -74.00496
08/06/2014 17:58:43 , 45.78860, -74.00496
08/06/2014 17:58:44 , 45.78860, -74.00496
08/06/2014 17:58:45 , 45.78860, -74.00496
08/06/2014 17:58:46 , 45.78860, -74.00496
08/06/2014 17:58:47 , 45.78860, -74.00496
08/06/2014 17:58:48 , 45.78860, -74.00496
08/06/2014 17:58:49 , 45.78860, -74.00496
08/06/2014 17:58:50 , 45.78860, -74.00496
08/06/2014 17:58:51 , 45.78860, -74.00496
08/06/2014 17:58:53 , 45.78860, -74.00496
08/06/2014 17:58:54 , 45.78860, -74.00496
08/06/2014 17:58:55 , 45.78860, -74.00496
08/06/2014 17:58:56 , 45.78861, -74.00496
08/06/2014 17:58:57 , 45.78861, -74.00496
08/06/2014 17:58:58 , 45.78861, -74.00496
08/06/2014 17:58:59 , 45.78861, -74.00497
08/06/2014 17:59:00 , 45.78861, -74.00497
08/06/2014 17:59:01 , 45.78861, -74.00497
08/06/2014 17:59:02 , 45.78812, -74.00490
08/06/2014 17:59:03 , 45.78803, -74.00488
08/06/2014 17:59:04 , 45.78803, -74.00488
08/06/2014 17:59:05 , 45.78802, -74.00488
Well the time is no good, but I can expect that since i'm located at -5 gmt.
So we are really back at is there some sort of a system incompatibility when the serial port is set at 38400bps with the SPI bus.
Can you try to set your Internal GPS speed to some thing else?
Okay, I will try deleting TinyGPS print functions to clear up memory and try it again.
I will also try filtering out the data I need instead of using tinygps and see if that works.
My question would be how do I reset the internal speed of the GPS to 4800?
Thanks for the insight guys!
You can do that for now, will get you to be able to start you project right away.
but this is bugging me, what could lead to this particular problem. This is no good, I'm getting on the case of this incompatibilité
Ouf reading the data sheet tend to make me believe that you might not be able to change the speed. We have to find what the problem is
Yeap forget what I just said.
You need to send the sentence:
“$PUBX,41,1,0007,0003,4800,0*13\r\n”
To the gps. So basicallyL:
Serial1.print(“$PUBX,41,1,0007,0003,4800,0*13\r\n”);
Serial1.begin(4800);
Serial1.flush();
Hi all, I have the iteadstudio GPS shield and I am working with an UNO and a GPS antenna from sparkfun
I am having A LOT of trouble getting the GPS to work, I have tried various sketches provided on this thread BUT I simply do not know what is wrong
On the shield, I have RX=3 and TX=2
I have read that I may need to change the baud rate, but I am not sure where exactly to do this
For reference I followed post #160
If someone could please assist me, I would greatly appreciate it.
Attached is a picture of what the serial monitor prints and I have also attached the sketch I am using
All testing was done outdoors.
Thanks in advance
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
static const int RXPin = 3, TXPin = 2;
static const uint32_t GPSBaud = 4800;
// The TinyGPS++ object
TinyGPSPlus gps;
// The serial connection to the GPS device
SoftwareSerial ss(TXPin, RXPin);
ss.begin(38400);
ss.print("$PUBX,41,1,0007,0003,4800,0*13\r\n"); //change iTead baudrate
ss.flush();
delay(50);
ss.begin(4800); //reset softserial baudrate
ss.flush();
delay(50);
//Serial.println(F("FullExample.ino"));
//Serial.println(F("An extensive example of many interesting TinyGPS++ features"));
//Serial.print(F("Testing TinyGPS++ library v. ")); Serial.println(TinyGPSPlus::libraryVersion());
//Serial.println(F("by Mikal Hart"));
Serial.println(F("---------------------------------------------------------------------------------------------------------------------------------------"));
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
printInt(gps.satellites.value(), gps.satellites.isValid(), 5);
printInt(gps.hdop.value(), gps.hdop.isValid(), 5);
printFloat(gps.location.lat(), gps.location.isValid(), 11, 6);
printFloat(gps.location.lng(), gps.location.isValid(), 12, 6);
printInt(gps.location.age(), gps.location.isValid(), 5);
printDateTime(gps.date, gps.time);
printFloat(gps.altitude.meters(), gps.altitude.isValid(), 7, 2);
printFloat(gps.course.deg(), gps.course.isValid(), 7, 2);
printFloat(gps.speed.kmph(), gps.speed.isValid(), 6, 2);
printStr(gps.course.isValid() ? TinyGPSPlus::cardinal(gps.course.value()) : "*** ", 6);
unsigned long distanceKmToLondon =
(unsigned long)TinyGPSPlus::distanceBetween(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON) / 1000;
printInt(distanceKmToLondon, gps.location.isValid(), 9);
double courseToLondon =
TinyGPSPlus::courseTo(
gps.location.lat(),
gps.location.lng(),
LONDON_LAT,
LONDON_LON);
printFloat(courseToLondon, gps.location.isValid(), 7, 2);
const char *cardinalToLondon = TinyGPSPlus::cardinal(courseToLondon);
printStr(gps.location.isValid() ? cardinalToLondon : "*** ", 6);
printInt(gps.charsProcessed(), true, 6);
printInt(gps.sentencesWithFix(), true, 10);
printInt(gps.failedChecksum(), true, 9);
smartDelay(1000);
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS data received: check wiring"));
// This custom version of delay() ensures that the gps object
// is being "fed".
static void smartDelay(unsigned long ms)
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
static void printFloat(float val, bool valid, int len, int prec)
if (!valid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
Serial.print(' ');
smartDelay(0);
static void printInt(unsigned long val, bool valid, int len)
char sz[32] = "*****************";
if (valid)
sz[len] = 0;
sz[i] = ' ';
if (len > 0)
sz[len-1] = ' ';
Serial.print(sz);
smartDelay(0);
static void printDateTime(TinyGPSDate &d, TinyGPSTime &t)
if (!d.isValid())
Serial.print(F("********** "));
char sz[32];
sprintf(sz, "%02d/%02d/%02d ", d.month(), d.day(), d.year());
Serial.print(sz);
if (!t.isValid())
Serial.print(F("******** "));
char sz[32];
sprintf(sz, "%02d:%02d:%02d ", t.hour(), t.minute(), t.second());
Serial.print(sz);
printInt(d.age(), d.isValid(), 5);
smartDelay(0);
static void printStr(const char *str, int len)
smartDelay(0);
My shield is not detecting microSD card. Says " initializating failed!" . I tried 1 GB and 4 GB cards and tried all formats such as Fat 16, Fat 32, with different allocation sizes ranging from 512 bytes to 1024 kb's. Don't know whats wrong with the shield. The code is perfect and working. Rest is fine. Just the data is not being stored in SD Card.
Ok Finally got the GPS working even inside with 6-8 Sats with the following code, now how do I get this data to and from the SD card?
TinyGPS gps;
static void print_float(float val, float invalid, int len, int prec);
if (feedgps())
newdata = true;
gpsdump(gps);
float flat, flon;
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 9, 5);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 10, 5);
print_date(gps);
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 8, 2);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : TinyGPS::course_to(flat, flon, 51.508131, -0.128002), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
char sz[32];
if (val == invalid)
sz[len] = 0;
sz = ' ';
- if (len > 0)*
- sz[len-1] = ' ';*
- Serial.print(sz);*
- feedgps();*
{ - char sz[32];*
- if (val == invalid)*
_ strcpy(sz, "*******");_ - sz[len] = 0;*
- if (len > 0)*
- sz[len-1] = ' ';*
- for (int i=7; i<len; ++i)*
_ sz = ' ';_
* Serial.print(sz);*
* else*
* Serial.print(val, prec);*
* int vi = abs((int)val);*
* int flen = prec + (val < 0.0 ? 2 : 1);*
* flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;*
* for (int i=flen; i<len; ++i)*
* Serial.print(" ");*
* feedgps();*
* int year;*
* byte month, day, hour, minute, second, hundredths;*
* unsigned long age;*
* gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);
_ Serial.print("****** ******* ");
* else*
* char sz[32];*
* sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",*
* month, day, year, hour, minute, second);*
* print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
_ feedgps();*
static void print_str(const char str, int len)
_{_
_ int slen = strlen(str);_
_ for (int i=0; i<len; ++i)_
_ Serial.print(i<slen ? str : ' ');
feedgps();
while (Serial.available())
if (gps.encode(Serial.read()))
return true;
return false;
}*_
