Arduino GPS Speedometer
Hi everyone, I currently have a project which requires me to use LIDAR sensor to detect distance from an obstacle and using Arduino GPS module NEO-6M module to give output according to the speed its traveling to the obstacle. Basically it means that it will give out different output based on its speed and distance.
This coding that i've tried is that whenever the obstacle is within 200 to 300 cm, it will calculate the height of the obstacle, and when the height is more then 4cm and the object is travelling more than 1kmph, the buzzer will give out an output.
Problem about this coding is that no matter what i tried, in the beginning if the criteria is not fulfilled it will not buzz, but once it achieves it will buzz, but when the condition is not fulfilled it will not stop buzzing, basically means once it buzzes it wont stop, i feel like its a problem with looping,i've tried the buzzer with lidar and buzzer with speed separately it will buzz according to real time condition but once i tried combining it wont work, can anyone give an explanation and give me some ideas? i thank everyone ahead for your time, the coding are as shown:
#include <TinyGPS++.h>           // Include TinyGPS++ library
#include <SoftwareSerial.h>      // Include software serial library
#include <Wire.h>
#include <LIDARLite.h>
TinyGPSPlus gps;
#define S_RX    4                // Define software serial RX pin
#define S_TX    3                // Define software serial TX pin
const int buzzer = 7;//the pin of the active buzzer
int safetyDistance;
SoftwareSerial SoftSerial(S_RX, S_TX);    // Configure SoftSerial library
LIDARLite lidarLite;
int cal_cnt = 0;
void setup(void) {
  SoftSerial.begin(9600);
 pinMode(buzzer,OUTPUT);//initialize the buzzer pin as an output
 lidarLite.begin(0, true); // Set configuration to default and I2C to 400 kHz
  lidarLite.configure(0); // Change this number to try out alternate configurations
  //Starting GPS module
  while (SoftSerial.available() > 0) {
    if (gps.encode(SoftSerial.read())) {
      if (gps.speed.isValid()) {
        Serial.print("Speed      = ");
        Serial.print(gps.speed.kmph());
        Serial.println(" kmph");
        Serial.println("Speed Invalid");
      int dist;
  // At the beginning of every 100 readings,
  // take a measurement with receiver bias correction
  if ( cal_cnt == 0 ) {
    dist = lidarLite.distance();      // With bias correction
    dist = lidarLite.distance(false); // Without bias correction
  // Increment reading counter
  cal_cnt++;
  cal_cnt = cal_cnt % 100;
       // Display distance
   Serial.println("distance =");
  Serial.print(dist);
  Serial.println(" cm");
  delay(10);
  //Safety dstance running
  safetyDistance=dist;
  if (safetyDistance<300 && safetyDistance>200){
        int x= 300- dist;
    double height = x* cos (1.267109037);
    //Display height
    Serial.println ("height =  ");
    Serial.print (height);
    Serial.println (" cm");
      if (gps.speed.kmph()>1 && height>4){
      digitalWrite(buzzer,HIGH);
       digitalWrite(buzzer,LOW);
Hi.
You might have a problem in expecting the Neo 6M to provide accurate speed in the range you are expecting.
John.
Hmm when I try it individually it can return me the speed though and i've tested in a car
The Lidar code is inside this loop:
I'll guess that was unintentional.
I use a Neo 6M as a speedometer in my car. It's reliable at speed, but not reliable at low speeds or stationary. It can report 5 kph or more when the car is stopped.
I would not expect to get reliable performance if you are after cm accuracy.
Perhaps I am misunderstanding your setup.
John.
