arduino graph plotting
hello i just bought a new serial graph display from sparkfun electronics. And i want to make a temperature monitor with graph plotting. Using analogue values stored into array i am getting from a temperature sensor can you help me. i don't know how to store the values in array and then make the plotting can you give me some instructions of how to do it
“serial graph display from sparkfun electronics”
Link?
// define the array size - byte, int, number of samples
int sensorArray[256]; // entries at 0-255
for (x = 0; x<256; x=x+1){  // capture 256 readings
sensorArray[x] = temperature_reading;  // however you make that reading
need the display info next, output the data in similar manner with a for:next loop
the display i bought is this one https://www.sparkfun.com/products/9351 thanks for your reply it was very helpful can you help me further please
I'd cut the data down to 7 bits (0-127) and use the library to turn on the appropriate pixel as you go across the screen from position 0 to 63.
Or the other direction, with data cut down to 0-63 and go across the screen from 0 to 127.
