Arduino GSM library RX problem
I'm trying to use GSM library in IDE with Rx on pin 15 of Arduino Mega 2560..... (Rx3)
Although this pin supports change interupt , it does not work...
If pin 15 is a hardware serial port RX, why does it need to be a pin change interrupt? You say it does not work. What is "it"? Can you describe the problem better?
groundFungus:
GSM library in arduino IDE is using softserial for communication.
Softserial is using change interupts for Rx.
İn the library there is a warning...
"Not all pins on the Mega and Mega 2560 support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69)"....
So pin 15 can bu used for Rx as claimed, but I can't use it...
Perhaps there is a way to use one of the hardware serial ports by changing the library. I am not at all familiar with that library, but it is often just a matter of changing a define or 2.
