Arduino GSM Shield V2
Hi guys,
I am working on a project I've got sms and gps to work perfectly together. I am trying to step it up a notch with including MMS messages. There is really no examples on how to do so.
The Shield I am using has a Quetel M10. Does anyone have an example on how to start this off I just need for sending purposes only.
Thanks :slight_smile:
it's very different than SMS. You can read more in the Technical description part of this wikipedia article
MMS messages are delivered in a different way from SMS. The first step is for the sending device to encode the multimedia content in a fashion similar to sending a MIME message (MIME content formats are defined in the MMS Message Encapsulation specification). The message is then forwarded to the carrier's MMS store and forward server, known as the MMSC (Multimedia Messaging Service Centre). If the receiver is on a carrier different from the sender, then the MMSC acts as a relay, and forwards the message to the MMSC of the recipient's carrier using the internet
depending on the capabilities of your shield you would use AT commands such as
AT+CMMSCURL or AT+QMMURL
see Quectel_GSM_MMS_AT_Commands_Manual_V1.1.pdf
or AT Commands for MMS Application
