i am trying to make quad copter and i install gy-801 sensor for gyroscope when i make the joystick up also get values from gyroscope the arduino crash here is the code
#include <L3G.h>
#include <Servo.h>
#include <Wire.h>
L3G gyro;
Servo motor1;
Servo motor2;
Servo motor3;
Servo motor4;
int ch1; // Here's where we'll keep our channel values
int ch2;
int ch3;
byte up;
byte up2;
byte up3;
byte up4;
int x_value;
int y_value;
Wire.begin();
gyro.enableDefault();
pinMode(5, INPUT); // Set our input pins as such
pinMode(6, INPUT);
pinMode(7, INPUT);
Serial.begin(9600); // Pour a bowl of Serial
if (!gyro.init())
Serial.println("Failed to autodetect gyro type!");
while (1);
gyro_values ();
motor1.attach(9);
motor2.attach(10);
motor3.attach(12);
motor4.attach(11);
ch1 = pulseIn(5, HIGH, 25000); // Read the pulse width of
//ch2 = pulseIn(6, HIGH, 25000); // each channel
//ch3 = pulseIn(7, HIGH, 25000);
up = map(ch1, 2500, 0, -75, 200);
up2 = map(ch1, 2500, 0, -75, 200);
up3 = map(ch1, 2500, 0, -75, 200);
up4 = map(ch1, 2500, 0, -75, 200);
motor1.write(up);
motor2.write(up2);
motor3.write(up3);
motor4.write(up4);
void gyro_values()
gyro.read();
x_value = map(gyro.g.x, -1000, 1000, -360, 360);
y_value = map(gyro.g.y, -1000, 1000, -360, 360);
delay(100);
