Arduino hangs after sending several POST request.
I'm having a problem with my project. the Arduino hangs after sending several post request. the codes have a timer that every timer it will send a post request. After sending to the server, the server will send a reply and I will parse it and get the data. I'm using Arduino UNO wifi rev 2. so I'm using wifi to connect to the server.
there are two cases of the problem
case #1:
after some time, the Arduino can't connect to the host. after several seconds, the Arduino can connect now.
Picture for this case: "Capture.PNG"
case #2:
after some time, it will hang on what server will reply. it contains nothing and hangs in there forever.
Picture for this case: "Capture1.PNG"
these are ALL the codes:
#include <SPI.h>
#include <WiFiNINA.h>
#include <ArduinoJson.h>
int relayPin1 = 2;  //This is the Arduino Pin that will control Relay #1
int relayPin2 = 3;  //This is the Arduino Pin that will control Relay #2
int pressurePin = A0;
int force;
int ledPin = 5;
int num_steps = 0;
int fsr = false;
int longfsr = false;
long buttonTimer = 0;
long longPressTime = 300;
int timer;
//char ssid[] = "***";                     // your network SSID (name)
//char key[]  = "***";                     // your network key
char key[]  = "****";                     // your network key
//const char* host = "***";          // server ip add
int status = WL_IDLE_STATUS;                  // the Wifi radio's status
WiFiClient client;                            // initialize the client library
int portnum = ***;                           // portn number
String line = "";
String reply_content = "";
String Battery_using = "";
StaticJsonBuffer<2000> jsonBuffer;
  //Initialize serial and wait for port to open:
  pinMode(relayPin1, OUTPUT);
  pinMode(relayPin2, OUTPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(relayPin1, HIGH);
  digitalWrite(relayPin2, HIGH);
//  while (!Serial) {
//    ; // wait for serial port to connect. Needed for Leonardo only
// attempt to connect to Wifi network:
Serial.print("[Attempting to connect to WEP network, SSID: ");
Serial.print(ssid);
Serial.println("]");
while ( status != WL_CONNECTED) {
Serial.println("[Connecting...]");
  status = WiFi.begin(ssid, key);
  // wait 5 seconds for connection:
  delay(5000);
  // once you are connected :
  Serial.println("[Connection Succesful]");
timer++;
digitalWrite(ledPin, LOW);
force = analogRead(pressurePin);
if(force > 600 ){
    if(fsr == false ){
      fsr = true;
      buttonTimer = millis();
if ((millis() - buttonTimer > longPressTime) && (longfsr == false)) {
        //short pressed
        longfsr = true;
        num_steps += 1;
  if(fsr == true){
    if(longfsr == true){
      longfsr = false;
      //long pressed
  delay(100);
if(timer==10){
update_data(num_steps);
Get_Data();
timer=0;
if(Battery_using == "Battery_1"){
}else if (Battery_using == "Battery_2"){
  digitalWrite(relayPin1, LOW);
  digitalWrite(relayPin2, LOW);
//===================== Update Footsteps ======================
boolean update_data(int steps){
String da = "data=";
String ta = String(steps);
String data = da+ta;
Serial.print("[Attempting to connect to ");
Serial.print(host);
if (client.connect(host, portnum))
    Serial.println("[Connected]");
    Serial.println("[Sending a request]");
    client.println("POST /Piezo_DLSL/function.php?action=update_footsteps HTTP/1.1");
    client.println("Host: "+ String(host));
    client.println("User-Agent: Arduino/1.0");
    client.println("Connection: close");
    client.println("Content-Type: application/x-www-form-urlencoded;");
    client.print("Content-Length: ");
    client.println(data.length());
    client.println();
    client.println(data);
    Serial.println("[Request sent]");
Serial.println("[Response:]");
    while (client.connected() || client.available())
      if (client.available())
        char line   = client.read();
        reply_content = reply_content + line;
    Serial.println(reply_content);
    Serial.println("[End Of Response]");
    //client.flush();
    client.stop();
    Serial.println("\n[Disconnected]");
}else{
    Serial.println("[Connection failed!]");
    //client.flush();
    client.stop();
//===================== Get Battery Data ======================
boolean Get_Data(){
digitalWrite(ledPin, HIGH);
String data = "data=Battery";
reply_content = "";
Serial.print(host);
    client.println("POST /Piezo_DLSL/function.php?action=Bat_update HTTP/1.1");
    client.println();
        if(reply_content.endsWith("Content-Type: application/json\r\n\r\n")){
           reply_content = "";
  JsonObject& root = jsonBuffer.parseObject(reply_content);
  if (!root.success())
  Serial.print("[parseObject]");
  Serial.print("[ ");
  Serial.print(reply_content);
  Serial.println(" ] Failed");
  jsonBuffer.clear();
  //client.flush();
  client.stop();
}else{
String json_value = root["status"];
Battery_using = json_value;
  Serial.println("[Received Value]");
  Serial.println(json_value);
  jsonBuffer.clear();
// while(client.connected()) {
     //client.flush();
     client.stop();
//     delay(1000);
}else{
    //client.flush();
    client.stop();
Thank you in advance :slight_smile:
You have 2K of SRAM, and are requesting a static buffer that takes up every bit of that. No wonder you are having problems.
String line = "";
The String class can make Swiss cheese of the memory you have. STOP USING IT.
PaulS:
WiFiNina is for Uno WiFi 2 (6144 B SRAM), MKR 1010 and MKR Vidor (32kB SRAM).
but this String use will fragment it all fast
thank you for your replies. I'm parsing a reply from a server I need the static buffer to do it. are there any alternatives?
and also for the string, is there any other type to store a string?
ejdizon1997:
It is not necessary to have the entire response in memory in order to parse it. If you are really expecting the server to send a 2000 character reply, perhaps the server needs to do some of the work, and just send what you need to know.
Yes, and the clue is in your question. A string and an instance of the String class are NOT the same thing.
PaulS:
an array, of course. Okay, I will try to convert all my Strings to my char array.
correct me if my wrong.
I can say that this line String line = "Hello"; is the same as this line? char line[] = "Hello"; ?
