Arduino hangs on virtual method
NickAmSee:
handleTouch in the setup method is working - in loop it is crashing
first glance?
maybe because of this:
  Button button1=Button("A");
  Serial.println("Button1 created");
  gui.addElement(&button1);
  Serial.println("Button1 added");
  Button button2=Button("B");
  Serial.println("Button2 created");
  gui.addElement(&button2);
  Serial.println("Button2 added");
  gui.handleTouch(1,1);
  Serial.println("Touch handled setup");
see anything there...?
hint: what scope are your Button objects?
NickAmSee:
Now it's getting interesting.
a couple of other notes:
you don't need the this-> to access class members within the class:
this->controlElements[elementCount]=controlElement;
just:
this:
  • creates an instance of Button class
  • copy's that instance to button2
  • deletes the first instance created
so just:
Button button2("B");
instead of this:
ControlElement(String id){
      this->id=id;
you can initialize a class in C++ using initializers... but don't get your variable names mixed.
ControlElement(String someId) : id(someId){} // initializes id to the argument someId
and finallly:
String id;
nix the String class.
BulldogLowell:
yes... If you take out the getArea() method from the Circle class in the example... compiler complains:
cannot declare variable 'circle' to be of abstract type 'Circle'
or in other words "you've inherited a pure virtual function and you haven't defined it, you big dope"
PaulS:
I want to make sure that I have this straight. The virtual keyword, without the =0, says that a derived class CAN override the method, but does not have to, while the virtual keyword, with the =0, says that a derived class MUST implement the method. Is that right?
If you have this in your base class 'virtual int handleTouch(int x,int y)=0;' then what bulldoglowell says is the case - you MUST implement that function in your derived classes.
But as is generally the case with C++ there are other options.
You could just implement an empty function in your base class:
    return 0;
And then your derived classes can override this function if they need to.
Not sure doing this is of any value in your case.
Perhaps if you wanted to include a bit of debugging:
virtual int BaseClass::handleTouch(int x,int y)
    Serial.println(x);
    Serial.println(x);
    return 0;
virtual int DerivedClass::handleTouch(int x,int y)
    BaseClass::handleTouch(x, y);
    return 0;
NickAmSee:
As I’m not too deep into C++ a short Java Example what was mit Original intent:
public abstract class ControlElement{
 public abstract int handleTouch(int x,int);
public class Button extrends ControlElement{
public int handleTouch(int x,int y){
ControlElement controlElements=new ControlElement[10];
controlElements[0]=new Button(…);
controlElements[0].handleTouch(…);
This example is C# (sharp)
And C# does not have pointers like C++ does.
So ‘ControlElement controlElements=new ControlElement[10];’ does not mean the same thing in C++.
In C++ this would be ControlElement controlElements[10]; and it literally means an array of objects created from your base class with that pure virtual function.
You have to do it this way in C++ if you want the virtual function polymorphism to kick in.
ControlElement* controlElements = {NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL, NULL};
or
ControlElement* controlElements[10];
memset(controlElements, NULL, 10);
Then you need to create objects from your derived class and put pointers to them (&button / address of button) into your controlElements array.
This might help - it is an array of pointers to float values but the idea is the same.
Here is some basic code to setup your control container - not checked for compile errors.
I have speculated as to your requirements but it should give you a start at least.
class CControlElement
  protected:
    int m_nTopLeftX, m_nTopLefty;
  private:
    // Empty constructor.
	// Making this private prevents it from being called unintentionally - all control elements require a position on the screen.
	// If it gets called then a compile error will be generated and you will need to provide two parameters so this constructor is called instead: CControlElement(const int nTopLeftX, const int nTopLeftY)
	CControlElement()
	  m_nTopLeftX = m_nTopLefty = 0
  public:
    // Constructors
	  m_nTopLeftX = nTopLeftX;
	  m_nTopLefty = nTopLeftY;
	virtual in handleTouch(const int nX, const int nY) = 0;
class CButton: public CControlElement
  private:
	// Making this private prevents it from being called unintentionally - all buttons require a position on the screen.
	// If it gets called then a compile error will be generated and you will need to provide two parameters so this constructor is called instead: CButton(const int nTopLeftX, const int nTopLeftY)
	CButton()
  public:
    // Constructors
	CButton(const int nTopLeftX, const int nTopLeftY): CControlElement(nTopLeftX, nTopLeftY)// Pass the parameters of CButton(...) to the correct constructor from the base class.
class CControlElements
  protected:
    CControlElement* m_arrayControlElements[10];
	int m_nCurrentSize;
	CButton m_button1, m_button2;
  public:
    // Constructor
    CControlElements()
		m_arrayControlElements[m_nCurrentSize++] = &m_button1;
		m_arrayControlElements[m_nCurrentSize++] = &m_button2;
	CControlElement* getControlElement(const int nNumber)
	  if ((nNumber >= 0) && (nNumber < m_nCurrentSize))
		return m_arrayControlElements[nNumber];
	  return NULL;
	int handleTouch(const int nX, const int nY)
	  int nResult = 0;
	  for (int nI = 0; nI < m_nCurrentSize; nI++)
	    nResult = m_arrayControlElements[nI].handleTouch(nX, nY);
	    if (nResult > 0) // Touch handled
		  break; // Break out of for loop.
	  return nResult;
boylesg:
did you miss OP's code in post 19?
BulldogLowell:
The OP can add in the other bits from his original code if he finds my sample code useful.
Oh... local definition. This was the reason..... Working now Thx
