Arduino hangs?
Hi
Posting here as I think this is not related to the project but to the Arduino: I made my own word clock and noted that sometimes, very irregular, the system decides to 'hang'. This means that no time will be updated any more. As this is a standalone Arduino project I can't verify any other (serial) output. When I turn it off and on again it works and it stays working all night long...
Any experience?
Thanks!
Any decoupling on the external electronics?
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
If you have a spare pin you could attach an LED+resistor to show that the Arduino is still running, and if you have two spare pins you could use SoftwareSerial to send debug output to another Arduino which can relay the output back to your PC.
You could try posting your code for us to look at!. But I'll put my money on you having used the String class.
Mark
Hi all
There is already one 100 uF condensator attached between ground and 5V where it enters, I hope this is enough for the decoupling or am I misunderstanding this? (sorry pretty new to electronics!)
The extra LED might be a good idea but will take some time to implement as it’s a closed system… I’ll check how I can do this! Adding an extra arduino is not feasible at this time.
I didn’t use any Strings so no string class afaik but I’m using 3 includes: #include <LedControl.h> (matrix), #include <Wire.h> and #include <DS1307.h> (time).
Posting code would be fine for me but than it doesn’t feel like solving the issue any more but just (ab)using you guys :slight_smile:
A fairly common way of hanging an arduino sketch (or other C code for that matter) is writing on inappropriate memory locations. Check that you're not writing off the end of an array, or using a return value from a function that doesn't always explicitly return one. Really though, for any more focused assistance, you'll need to post your code.
The code is too simple for memory writing I believe. Please have a look below. I’m going to add a second 100uF capacitator today.
Thanks for any ideas!
#include <Wire.h>
#include <DS1307.h>
int buttonMinUpdate = 0, buttonHourUpdate = 0;
char dateTime[22];
int minuteNow, minuteOld = 0;
int RTCValues[7], i = 0, year, month, dayOfMonth, dayOfWeek, hour, minute, second, intStatus = 1, oldStatus = 1;
const int buttonPinMinute = 3, buttonPinHour = 4, buttonShutdown = 5;
// inputs: DIN pin, CLK pin, LOAD pin. number of chips
LedControl mydisplay = LedControl(9, 10, 11, 2);
 //setTime();
  DS1307.begin();
  pinMode(buttonPinMinute, INPUT);
  pinMode(buttonPinHour, INPUT);
  pinMode(buttonShutdown, INPUT);
  intStatus = digitalRead(buttonShutdown);
  if(intStatus == 0)
     mydisplay.shutdown(0, false);  // turns on display
     mydisplay.shutdown(1, false);  // turns on display
    mydisplay.shutdown(0, true);  // turns on display
    mydisplay.shutdown(1, true);  // turns on display
  oldStatus = intStatus;
  mydisplay.setIntensity(0, 15); // 15 = brightest
  mydisplay.setIntensity(1, 15); // 15 = brightest
  DS1307.getDate(RTCValues);
  buttonMinUpdate = digitalRead(buttonPinMinute);
  buttonHourUpdate = digitalRead(buttonPinHour);
  sprintf(dateTime, "20%02d-%02d-%02d %02d:%02d:%02d", RTCValues[0], RTCValues[1], RTCValues[2], RTCValues[4], RTCValues[5], RTCValues[6]);
  minuteNow = RTCValues[5];
  if(oldStatus != intStatus)
      if(intStatus == 0)
  if(buttonMinUpdate == 0)
    updateTimeMin();
  if(buttonHourUpdate == 0)
    updateTimeHour();
  if(minuteNow != minuteOld)
      minuteOld = minuteNow;
      VisualizeTime();
  delay(750);
void VisualizeTime()
    mydisplay.clearDisplay(0);
    mydisplay.clearDisplay(1);
    enableHetIs();
    int intMinutes = RTCValues[5];
    int intExtraMin = intMinutes % 5;
    enableMinutes(intExtraMin);
    int intFunction = RTCValues[5] / 5;
    int intHour = RTCValues[4];
    if(intFunction >= 4)
      intHour++;
     enableFunction(intFunction);
    enableHour(intHour);
void enableHour(int intHour)
  while(intHour >= 12)
     if(intHour >= 12)
      intHour -= 12;
   switch (intHour)
    case 0:
      mydisplay.setLed(0, 0, 6, true);
      mydisplay.setLed(0, 1, 6, true);
      mydisplay.setLed(0, 2, 6, true);
      mydisplay.setLed(0, 3, 6, true);
      mydisplay.setLed(0, 4, 6, true);
      mydisplay.setLed(0, 5, 6, true);
    case 1:
      mydisplay.setLed(1, 4, 5, true);
      mydisplay.setLed(1, 5, 5, true);
      mydisplay.setLed(1, 6, 5, true);
void enableHetIs()
   mydisplay.setLed(1, 4, 0, true);
   mydisplay.setLed(1, 5, 0, true);
   mydisplay.setLed(1, 6, 0, true);
   mydisplay.setLed(0, 6, 0, true);
   mydisplay.setLed(0, 5, 0, true);
void enableMinutes(int intExtraMin)
  //there is no break in thise case intentionally
  switch (intExtraMin)
    case 4:
      mydisplay.setLed(1, 2, 4, true);
    case 3:
      mydisplay.setLed(1, 2, 3, true);
    case 2:
      mydisplay.setLed(1, 3, 4, true);
    case 1:
      mydisplay.setLed(1, 3, 3, true);
void enableFunction(int intFunction)
  switch (intFunction)
    case 0:
      enableUur();
    case 1:
      enableVijf();
      enableOver();
void enableUur()
  mydisplay.setLed(1, 1, 5, true);
  mydisplay.setLed(1, 1, 6, true);
  mydisplay.setLed(1, 1, 7, true);
void enableVijf()
  mydisplay.setLed(0, 0, 0, true);
  mydisplay.setLed(0, 1, 0, true);
  mydisplay.setLed(0, 2, 0, true);
  mydisplay.setLed(0, 3, 0, true);
void enableOver()
void updateTimeMin()
   minute = RTCValues[5] + 1;
  if(minute == 60)
    minute = 0;
  hour = RTCValues[4];
  completeUpdate();
void updateTimeHour()
   minute = RTCValues[5];
   hour = RTCValues[4] + 1;
   if(hour == 24)
    hour = 0;
   completeUpdate();
void completeUpdate()
  second = 0;
  dayOfMonth = RTCValues[2] ;
  dayOfWeek = RTCValues[3] ;
  year = RTCValues[0];
  month = RTCValues[1];
  DS1307.setDate(year, month, dayOfMonth, dayOfWeek, hour, minute, second);
  VisualizeTime();
On a first glance, I can't see an issue in the code. Can you add some more serial prints to zero on on where it crashes?
Thanks, but I can't add any serial output as there is no way to attach it at the moment. It is a standalone situation with no breakout for USB.
I added a 2nd capacitor, getting my hopes up!
Stijn: Thanks, but I can't add any serial output as there is no way to attach it at the moment. It is a standalone situation with no breakout for USB.
No spare I/O pins available?
