Arduino hardware interrupt to control servo motor
Currently am working on project to open a door with access code using arduino UNO and a servo motor. Normal operation requires entering access code using keypad which is working fine. Another option requires pressing a button that causes an interrupt to rotate the servo motor. My problem is my interrupt only works once and never works again. Plus how do i put the for-loop to rotate the servo motor inside the interrupt function with a delay. I know that is not possible but am calling another function that has the delayMicroseconds but all this is not working. Below is my implementation please help
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <Servo.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
    {'1','2','3'},
    {'4','5','6'},
    {'7','8','9'},
    {'*','0','#'}
byte rowPins[ROWS] = {10, 9, 8, 7}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {13, 12, 11}; //connect to the column pinouts of the keypad
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char holdKeys[] = {};
int i = 0;
int j = 0;
char accessCode[6];
char holdMaskedCode[6];
char holdMaskedNumber[10];
char studentNumber[10];
String accessCodeString;
Servo servo;
const int openButtonPin = 2;
volatile int openButtonState = LOW;
  servo.attach(5);
  lcd.begin(16, 4);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.print("Welcome");
  lcd.setCursor(0,0);
  pinMode(4, OUTPUT);
 //pinMode(openButtonPin, INPUT);
 attachInterrupt(0, enforceOpenAccess, HIGH); // PIN 2
 lcd.clear();
 lcd.print("Student Number");
  //keypad.addEventListener(getAccessCode);
void(* resetFunc)(void) = 0;
  if(openButtonState == HIGH)
       for(int k =0; k<=180; k+=2)
          servo.write(k);
          delay(30);
  char key = keypad.getKey();
  if(key)
    if(j < 10)
        studentNumber[j] = key;
        //holdMaskedNumber[j] = '*';
        lcd.setCursor(0,2);
        lcd.print(String(studentNumber));
        if(j == 9)
          studentNumber[9] = '\0';
          //holdMaskedNumber[9] = 0;
          lcd.clear();
          //String number = String(studentNumber);
          //lcd.print(number);
          //delay(1000);
          //lcd.clear();
          lcd.print("Access Code");
        j++;
       if(i < 5)
      accessCode[i] = key;
      holdMaskedCode[i] = '*';
      lcd.setCursor(1,2);
      lcd.print(String(holdMaskedCode));
      if(i == 4)
        holdMaskedCode[5] = '\0';
        accessCode[5] = '\0';
        //lcd.clear();
        //lcd.setCursor(0,0);
        //accessCodeString = String(accessCode);
        //lcd.print(accessCodeString);
        //delay(1000);
        lcd.clear();
     for(int i =0; i<6; i++)
            lcd.print("Please wait.");
            lcd.clear();
            lcd.print("Please wait..");
            lcd.clear();
            lcd.print("Please wait...");
            lcd.clear();
          digitalWrite(4, HIGH);
          lcd.print("Access Granted");
            servo.write(k);
            delay(30);
          resetFunc();
      i++;
void enforceOpenAccess()
   openButtonState = !openButtonState;
The ISR is only running once and never runs again
Nonsense. A human pressing a switch does NOT require nano-second accuracy in processing the switch press.
If you can't determine the appropriate size of the array, the compiler will by counting the number of initializers. A zero element array is worse than useless, because it leads you to believe that you can store data in it. You can NOT store anything in this array. It's a good thing you don't try. Get rid of this unused array!
Normally, you want to react to RISING, FALLING, or CHANGE. HIGH is an option ONLY on the Due.
Get rid of this. If you think you need this, you are wrong. You have some other flaw in your code that needs to be addressed.
If loop() iterated often enough, you would not need interrupts.
          servo.write(k);
          delay(30);
If the servo is opening a door lock, why does it need to do so ssslllooowwwlllyyy?
Pissing away resources uselessly AND INCORRECTLY, I see. When passing a character array to the String constructor, the char array MUST be a string. A string is a NULL terminated array of chars. Your char array is not NULL terminated, so it is not a string, so it should NOT be passed to a function that expects a string. Even if the array was a string, wrapping the string in a String so that print() has to unwrap the string to print it, after the instance is constructed and then destroyed after printing is stupid.
And, no I will not apologize for calling this code stupid!
          resetFunc();
Why? There is no earthly reason for doing this.
