I have a hardware question about Arduino as a microcontroller over a dedicated computer like a Pi.
I have a 1970's Mini that I'd like to convert the dash.
I'd like to replace the original gauges with a speedo, oil pressure and water temperature gauge with digital LED screens. These digital screens must look exactly like the original gauges. (Something like you'd see in an aircraft simulator)
Can I lay high quality images as backgrounds with the digital needles reading out the correct sensor readings?
I have figured out how to mount the screens so hardware installation is not a problem.
Will I be limited in the future with my grand scheme of things and the additional functions I want to add to the display?
I can take speed and odometer readings from GPS.
I can sort out fuel level, water temp and oil pressure using analog sensors.
(All of these can be managed by a single controller or smaller, individual controllers)
What I want to achieve is:
When I put the car in reverse, I want the LED screen to turn into the reverse camera screen with high resolution.
All I need to know is whether the Arduino UNO R3 can handle this amount of data and provide the highest resolution on the screen or should I already start moving onto more powerful hardware?
TIA!
