Arduino Headers Question.
Hi all,
I could be missing the point here so if I am please point it out. I am at the moment designing a board for the Mega that is a stand alone board to facilitate a VFO using the cheap AD9850 modules from China. I read a lot about clearance issues between the Mega and a board that is stacked on top via headers. I have seen what people describe on e bay as Tall headers but they seem to just be longer in the pin and not longer or should I say taller in the body of the header.
Am I correct? Or is there headers available that are indeed taller in the plastic body of the header?
Any info greatly appreciated and most welcome. Ian K3HQL
The main issue is the USB jack - add some insulating tape to the top of it if the shield overlaps.
Check the clearance between ICSP pins and the shield too - again just add some insulation if worried.
I tend to use Seeeduino Mega these days, it has a USB mini jack so no risk of shorting from
that and it brings out more of the microcontroller's pins - worth checking out perhaps?
I bought the AD9850 ssb receiver ,the thing is there are no instructions that show how to hook up
the AD9850 gen ssb receiver and support boards, can you help?
MarkT:
Or maybe even cut the board out.
Seeedstudio's Mega version uses mini USB (or perhaps micro USB) connector, and is cheaper, smaller,
has more pins. Finesses the clearance issue!
