I am supplying power to Arduino from a 12V adapter. The board gets heated too much after few hours. For my project I wont need a battery source, the board is constantly supplied from adapter. But I want it to run continuously for several months. So does this heating of arduino damage it. If so, how long will it last? How do I estimate this on a paper?
Does putting arduino to sleep reduce this problem?
Thanks in advance.
arduinofresher:
Probably not much. The real problem is that you are using pretty crude regulators and you are leaning 12v against them. A 12v supply is at the upper recommended limit and should be kosher. A 9v adapter will make both you and Arduino feel somewhat more comfortable, but even they throw a lot of heat out. My project runs for months on 9v. I would not use 12v, no matter what the book says.
Ok. I will change the adapter to 9V one. Thanks for the reply.
