Arduino help beginner
Hi all. I'm new to the ardunio and am looking for some help. I'm building a project that will have roughly 10 sensors and say 10 outputs.What the difference between d/i vs a/i Which arduino would you recommend.i am also looking for a sensor that would measure air flow.Thanks a mill in advance.
Depends on the values of d, a, and i.
Depends on the kind of sensors you are referring to. Analog? Digital? Serial? I2C? SPI?
Would that be a grist mill? A gin mill? A CNC mill? (I'd like one of those.)
I think he meant analog input vs digital input. I can't explain better than wikipedia you better google that one because is a common question.
Which Arduino? It depends on the sensors are wether digital or analog.
Start with a UNO to get some experience.
Progress to other Arduinos boards as need requires.
I like the Atmega1284 in final designs (consider a 1284 Weeney or Bobuino2 made by Crossroads.)
Actually the Bobuino2 is great!
Has lots of built in I/O and optional terminal connectors!
http://crossroadsfencing.com/BobuinoRev17/index.html
Pick the Arduino to match the sensors... If all 5V sensors, then Mega2560 will serve you well and provide far more resources than an UNO. If all sensors are 3.3 Volt, you should consider the Due and make interfacing easy on yourself.
If sensors are a combination of 5V and 3.3V you need to search thee forum (or Internet) on 3.3V and 5V voltage conversion methodologies. Sparkfun used to have a few pertinent links.
The 16K of SRAM on the Mega2560 will give some headroom over the 2K on the UNO. Plus the extra I/O is nice. The Due is ARM based, so do your research and make certain your needed library is supported fully on the DUE.
Ray
sounds like he is trying to build an ems system for a car.
Kawgomoo:
Express mail service?
Emergency medical service?
Executive management system? (We need one of those; damned executives out of control!)
PaulS:
While working for at&t, I would have loved to have an Executive Mute System. The insanity that comes from these self-proclaimed experts is frightening.
Ray
very informative replies by PaulS! good job Paul! i will NEVER use an abbreviation on a forum where i suspect you to be there! :smiley:
