Arduino HEX batch file
Hi all,
I have two questions.
  1. Where can I get a hex file using Arduino IDE?
  2. How can I create a batch file (*.bat) to upload the hex file on Arduino?
Thanks a lot.
Use File + Preferences to turn on verbose mode, to see where the hex file is created.
  1. How can I create a batch file (*.bat) to upload the hex file on Arduino?
Use a text editor?
PaulS:
Use a text editor?
  • Thanks. What command lines I should write in the bat file?
there is only one command you need - avrdude.exe - google for the parameters.
If you set the verbose mode the (almost) right command will be shown.
