Arduino HW recomendation
Hi all,
I would like ask more experienced guys. I'm little bit confuned, which one Arduino I should choose as best for my aplication.
Suggest for my project:
I would like control 4 relays for switching fuel maps on my motorbike, control it with display and buttons. And for control throttles on air-intake and lamba sonda tracing.
Thanks a lot
Your post was MOVED to its current location as it is more suitable.
I don't know what a "fuel map" is (a map of fuel stations?), but any Arduino board can do all of these tasks. Look at the Nano.
Avoid the Uno. It's a great board for the classroom, but the Nano beats it in just about every spec.
On the other hand, if this is your first Arduino project, then I strongly recommend that you buy an Uno and a "sensor" kit. Then start experimenting with the sensor kit and the example sketches in the IDE. Diving right into the deep end will only make your project take longer.
Somewhat confusing, Steve!
I agree with Steve's first statement: avoid Uno. And Mega. And Due. A classic Nano v3 would be my recommendation also.
If this is the FIRST Arduino experience, then the Uno is, as I said, a good classroom processor. And more expendable.
... and, if this is your first project, you should do a lot of bench experiments before trying to install something like this on a motorcycle. Then the choices will become clearer to you...
It's almost like, "I want to write a novel, what kind of pen should I use?".
Hi @oration,
on projects with little space, I like to use the Arduino Mini.
It has all the features of the Nano, but it doesn't have the USB interface,
which during normal use is unnecessary.
To upload codes I use the module with FT232RL, which I remove after I record the code.
RV mineirin
People here won't automatically know what that is. Of course, I could Google it. :slight_smile: The concept is, we help for free. Don't force us to do unnecessary work to help you.
There are forum guidelines that you should read, in order to post a question in a way that it will get good results.
Hi guys,
thans for help.
Yes, I´m plannig a plenty of tests before use on my bike. SW and HW must be durable, but the function, that I expect, doesnt has an impect for function at all. Only reading analog values and switching some relays. I checked what marker offers, I am wondering about Arduino Nano, is it suitable too?
The Nano or Pro Mini would probably work for your project. I say "probably" because your requirement is still vague.
Also, there's a new one, "durable". Well, that obviously depends on how it's constructed and used... none of the Arduinos are automotive or industrial grade electronics.
