Arduino I2C raspberry pi 3
hello,
just start using I2C and want connect arduino UNO and Raspberry Pi 3. Found tutorial how to do this:
works fine and I get data from RPI to UNO. I use two UNO as slave and RPI as master. Now I want use one uno to get data and other to send data to RPI. How can I change code to do this?
UNO1
  I2C Pinouts
  SDA -> A4
  SCL -> A5
//Import the library required
#include <Wire.h>
//Slave Address for the Communication
#define SLAVE_ADDRESS 0x04
char number[50];
int state = 0;
int x = 3;
//Code Initialization
  // initialize i2c as slave
  Wire.begin(SLAVE_ADDRESS);
  // define callbacks for i2c communication
  Wire.onReceive(sendData);
  //  Wire.onRequest(sendData);
  delay(100);
} // end loop
// callback for received data
void receiveData(int byteCount) {
  int i = 0;
  while (Wire.available()) {
    number[i] = Wire.read();
    i++;
  number[i] = '\0';
  Serial.print(number);
}  // end while
// callback for sending data
void sendData() {
  Wire.write(number);
  Wire.write(x);
//End of the program
UNO2
I2C Pinouts
SDA -> A4
SCL -> A5
#include <Wire.h>
#define SLAVE_ADDRESS 0x05
char number[50];
int state = 0;
  Wire.onReceive(receiveData);
  delay(100);
} // end loop
void receiveData(int byteCount){
  int i = 0;
  while(Wire.available()) {
    i++;
  number[i] = '\0';
}  // end while
void sendData(){
  Wire.write(number);
RPI
#RPi Pinouts
#I2C Pins
#GPIO2 -> SDA
#GPIO3 -> SCL
#Import the Library Requreid
import smbus
import time
# for RPI version 1, use "bus = smbus.SMBus(0)"
bus = smbus.SMBus(1)
# This is the address we setup in the Arduino Program
#Slave Address 1
address = 0x04
#Slave Address 2
address_2 = 0x05
def writeNumber(value):
    bus.write_byte(address, value)
    bus.write_byte(address_2, value)
    # bus.write_byte_data(address, 0, value)
    return -1
def readNumber():
    # number = bus.read_byte(address)
    number = bus.read_byte_data(address, 1)
    return number
while True:
	#Receives the data from the User
    data = raw_input("Enter the data to be sent : ")
    data_list = list(data)
    for i in data_list:
    	#Sends to the Slaves
        writeNumber(int(ord(i)))
        time.sleep(.1)
    writeNumber(int(0x0A))
#End of the Script
In the true way of Uno2 initiating the transmission you would need a multi master setup. That can get complex.
It's probably easier to make the RP poll Uno2 regular to see if it has something to tell and if so, read it.
