Arduino I2C Slave
I trying to connect 2 Arduino via I2C. I’m wondering if this code is correct for the slave device. (For the master device, I using Arduino/Labview) :
I would like to dim light pin 9 on the Arduino slave from Labview. Is that code ok? Thank you
Arduio slave code:
#include <Wire.h>
byte IWire1 =0;
int OLight1= 9;
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  pinMode(OLight1, OUTPUT);
  delay(100);
void receiveEvent(int howMany)
 IWire1 = Wire.read();
 analogWrite(OLight1, IWire1);
Ok, I change it and it works now. The light brightess change from low to high in a good flow except that from 240 to 255, it increases significantly. I don’t know why?
Arduino code:
#include <Wire.h>
byte IWire1 =0;
int OLight1= 9;
