Arduino IDE 1.5.2 .hex file save path?
Hi all. I'm looking for the .hex file generated when I compile a sketch and it's not anywhere that I or my computer can find. I have done some searching and many people have written about finding it in the C:\Documents and Settings<username>\Local Settings\Temp\build path, but as far as I can tell the 1.5.2 IDE doesn't save there.
I'm running Windows 7, but I also just checked this on XP and I'm not seeing it there either. And yes, I have enabled viewing of hidden files.
Any recommendations?
In case you're curious, I'm trying to upload a .hex file over JTAG to the SAM3X8E chip because my homemade Due board isn't responding to either of the USB ports. I suspect it's a noisy power supply, but in the meantime I can connect via Atmel Studio and JTAG just fine.
Thanks!
I'll note that I can see a list of files related to my sketch including a .cpp, .bin, .elf, and a lot more. Is it that there is no .hex generated for the Due and it's the .bin that's used?
Hello michaeluna,
AFAIK, Arduino IDE does not generate .HEX files. To upload your application to Arduino Due (SAM3X8E) using SAM-ICE (JTAG) you only need the .bin file and the Bossac.exe.
Regards!
EDIT: Sorry, I mistakenly said Bossac.exe. Wrong! You have to use your .bin file and SAM-BA 2.11. I apologize for the mistake.
Can you load the .elf file to program via JTAG?
Alternatively, generating the hex file from the elf file is quite easy, it's a command line like:
arm-none-eabi-objcopy -O ihex file.elf file.hex
where objcopy is in the Arduino installation somewhere.
