Arduino IDE 1.5.5 and USBASP porgrammer
Hello.
I've got atmega 328p connected to my PC VIA USBASP programmer
In my boards.txt i've added:
usbasp328.name=[usbasp]ATmega328
usbasp328.upload.using=usbasp
usbasp328.upload.maximum_size=32768
usbasp328.build.mcu=atmega328p
usbasp328.build.f_cpu=8000000L
usbasp328.build.core=arduino
usbasp328.build.variant=standard
Using Arduino ide 10.5 usbasp328 board and USBASP programmer everything works fine.
Using Arduino ide 1.5.5 during upload process I'm getting error "Board at COM1 is not available".
USBASP is using USB not COM
Do you know what I shoul do to use usbasb in Arduino IDE 1.5.5 ?
I can“t help you but I can give you an advise: turn on Files/Preferences/Shou output messages at: upload and look the avrdude line. It must use "-c usbasp" as a parameter. I tried upload with the originals parameters and always got an "-c arduino". Some changes and it worked when the command line turns to "-c usbasp". I changed the boards.txt and deleted the preferences.txt for this.
