hi Guys,
Everything was working 100% for ages, but then i decided to add "Processing" to my system as I needed to do some bitmap conversions.
I now have an issue when the Arduino IDE starts it gets to loading boards and then just vanishes...
I ran it with Debug and am getting the following error:
C:\Users\Administrator>"c:\Arduino\arduino_debug.exe"
Loading configuration...
Initializing packages...
Preparing boards...
Starting...
java.lang.NoClassDefFoundError: processing/app/ui/Editor
at java.lang.Class.getDeclaredMethods0(Native Method)
at java.lang.Class.privateGetDeclaredMethods(Class.java:2701)
at java.lang.Class.getDeclaredMethod(Class.java:2128)
at java.awt.Component.isCoalesceEventsOverriden(Component.java:6210)
at java.awt.Component.access$500(Component.java:186)
at java.awt.Component$3.run(Component.java:6164)
at java.awt.Component$3.run(Component.java:6162)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Component.checkCoalescing(Component.java:6161)
at java.awt.Component.<init>(Component.java:6130)
at java.awt.Container.<init>(Container.java:281)
at java.awt.Window.<init>(Window.java:535)
at java.awt.Frame.<init>(Frame.java:420)
at java.awt.Frame.<init>(Frame.java:385)
at javax.swing.JFrame.<init>(JFrame.java:189)
at processing.app.tools.MovieMaker.<init>(Unknown Source)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstruct
orAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingC
onstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:422)
at java.lang.Class.newInstance(Class.java:442)
at processing.app.Editor.addTools(Editor.java:927)
at processing.app.Editor.buildToolsMenu(Editor.java:784)
at processing.app.Editor.buildMenuBar(Editor.java:543)
at processing.app.Editor.<init>(Editor.java:233)
at processing.app.Base.handleOpen(Base.java:899)
at processing.app.Base.handleOpen(Base.java:884)
at processing.app.Base.handleOpen(Base.java:880)
at processing.app.Base.handleNew(Base.java:768)
at processing.app.Base.<init>(Base.java:477)
at processing.app.Base.guardedMain(Base.java:226)
at processing.app.Base.main(Base.java:137)
Caused by: java.lang.ClassNotFoundException: processing.app.ui.Editor
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 32 more
Is there anyone else that has had the same and could advise how i can get rid of it? I tried reinstalling the IDE but it appears java does not forget.
