Arduino IDE 1.6.9 and Atmel´s AVRisp MKII programmer stops work
Hi again, i´m coming back after years having the same problem, Arduino IDE is updated and my Atmel´s AVRisp MKII programmer stops work, the message, always the same:
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : usb
Using Programmer : stk500v2
avrdude: usbdev_open(): did not find any USB device "usb"
Windows 10, with Intel microprocessor, Arduino IDE 1.6.9
any solution?, comment?
This thread explains the issue and offers a couple of workarounds: Solved:Bootloader from Arudino IDE with AVRISPmkII fails - Installation & Troubleshooting - Arduino Forum
SorryPert, i was in theplace you wrote me, but still i continue in the same situation, after make the proposed chages this is the result:
El Sketch usa 1.006 bytes (3%) del espacio de almacenamiento de programa. El máximo es 32.256 bytes.
Las variables Globales usan 15 bytes (0%) de la memoria dinámica, dejando 2.033 bytes para las variables locales. El máximo es 2.048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -Uflash:w:C:\Users\josem\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.11/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m -Uflash:w:C:\Users\josem\AppData\Local\Temp\build85fe9d593c6c3a472b2a54cc5e88b608.tmp/BlinkWithoutDelay.ino.hex:i
Using Port : usb
