It was working for months and then it stopped compiling. It does not matter what the script is, I get the same error(including examples). I have uninstalled/reinstalled the IDE, created a new libraries folder, and reinstalled the libraries according to the Lilygo github. I have checked that the appropriate URL is in the additional board manager
https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
Board Manger is set to EPS32S3 Dev Module
I might try a different PC, I can not figure our what has gotten corrupted.
If anyone can help, I would really appreciate it!
I get the following error
In file included from C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.h:94,
from C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:16:
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c: In member function 'uint8_t TFT_eSPI::readByte()':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:466:20: error: 'GPIO' was not declared in this scope
466 | #define RD_L GPIO.out_w1tc = (1 << TFT_RD)
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c:98:3: note: in expansion of macro 'RD_L'
98 | RD_L;
In file included from C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:20:
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c:100:9: error: 'gpio_input_get' was not declared in this scope; did you mean 'gpio_num_t'?
100 | reg = gpio_input_get(); // Read three times to allow for bus access time
| gpio_num_t
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c: In member function 'void TFT_eSPI::pushBlock(uint16_t, uint32_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:356:26: error: 'GPIO' was not declared in this scope
356 | #define GPIO_CLR_REG GPIO.out1_w1tc.val
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:432:31: note: in expansion of macro 'GPIO_CLR_REG'
432 | #define tft_Write_16(C) GPIO_CLR_REG = GPIO_OUT_CLR_MASK; GPIO_SET_REG = set_mask((uint8_t) ((C) >> 8)); WR_H; \
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c:547:5: note: in expansion of macro 'tft_Write_16'
547 | tft_Write_16(color);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c:558:23: note: in expansion of macro 'tft_Write_16'
558 | else while (len--) {tft_Write_16(color);}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c: In member function 'void TFT_eSPI::pushSwapBytePixels(const void*, uint32_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c:568:20: note: in expansion of macro 'tft_Write_16'
568 | while ( len-- ) {tft_Write_16(*data); data++;}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c: In member function 'void TFT_eSPI::pushPixels(const void*, uint32_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c:578:37: note: in expansion of macro 'tft_Write_16'
578 | if(_swapBytes) { while ( len-- ) {tft_Write_16(*data); data++; } }
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:436:32: note: in expansion of macro 'GPIO_CLR_REG'
436 | #define tft_Write_16S(C) GPIO_CLR_REG = GPIO_OUT_CLR_MASK; GPIO_SET_REG = set_mask((uint8_t) ((C) >> 0)); WR_H; \
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.c:579:27: note: in expansion of macro 'tft_Write_16S'
579 | else { while ( len-- ) {tft_Write_16S(*data); data++;} }
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::begin_tft_write()':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:225:22: error: 'GPIO' was not declared in this scope
225 | #define CS_L GPIO.out_w1tc = (1 << TFT_CS)
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:80:5: note: in expansion of macro 'CS_L'
80 | CS_L;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::begin_nin_write()':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:92:5: note: in expansion of macro 'CS_L'
92 | CS_L;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::end_tft_write()':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:226:22: error: 'GPIO' was not declared in this scope
226 | #define CS_H GPIO.out_w1ts = (1 << TFT_CS)
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:106:7: note: in expansion of macro 'CS_H'
106 | CS_H;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::end_nin_write()':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:121:7: note: in expansion of macro 'CS_H'
121 | CS_H;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::begin_tft_read()':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:147:4: note: in expansion of macro 'CS_L'
147 | CS_L;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::end_tft_read()':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:169:24: note: in expansion of macro 'CS_H'
169 | if(!inTransaction) {CS_H;}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::spiwrite(uint8_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:412:27: note: in expansion of macro 'GPIO_CLR_REG'
412 | #define tft_Write_8(C) GPIO_CLR_REG = GPIO_OUT_CLR_MASK; GPIO_SET_REG = set_mask((uint8_t)(C)); WR_H
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:950:3: note: in expansion of macro 'tft_Write_8'
950 | tft_Write_8(c);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::writecommand(uint8_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:167:20: error: 'GPIO' was not declared in this scope
167 | #define DC_C GPIO.out_w1tc = (1 << TFT_DC)
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:964:3: note: in expansion of macro 'DC_C'
964 | DC_C;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::writedata(uint8_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:168:20: error: 'GPIO' was not declared in this scope
168 | #define DC_D GPIO.out_w1ts = (1 << TFT_DC)
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:1012:3: note: in expansion of macro 'DC_D'
1012 | DC_D; // Play safe, but should already be in data mode
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'uint8_t TFT_eSPI::readcommand8(uint8_t, uint8_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:1035:3: note: in expansion of macro 'CS_L'
1035 | CS_L;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual uint16_t TFT_eSPI::readPixel(int32_t, int32_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:1113:25: note: in expansion of macro 'CS_L'
1113 | if (!inTransaction) { CS_L; } // CS_L can be multi-statement
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:1145:27: note: in expansion of macro 'CS_H'
1145 | if (!inTransaction) { CS_H; } // CS_H can be multi-statement
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::readRect(int32_t, int32_t, int32_t, int32_t, uint16_t*)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:1237:3: note: in expansion of macro 'CS_L'
1237 | CS_L;
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::drawChar(int32_t, int32_t, uint16_t, uint32_t, uint32_t, uint8_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3167:32: note: in expansion of macro 'tft_Write_16'
3167 | if (column[k] & mask) {tft_Write_16(color);}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3168:15: note: in expansion of macro 'tft_Write_16'
3168 | else {tft_Write_16(bg);}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3171:7: note: in expansion of macro 'tft_Write_16'
3171 | tft_Write_16(bg);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::setWindow(int32_t, int32_t, int32_t, int32_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3419:5: note: in expansion of macro 'DC_C'
3419 | DC_C; tft_Write_8(TFT_CASET);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'void TFT_eSPI::readAddrWindow(int32_t, int32_t, int32_t, int32_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3495:3: note: in expansion of macro 'DC_C'
3495 | DC_C; tft_Write_8(TFT_CASET);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::drawPixel(int32_t, int32_t, uint32_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3677:7: note: in expansion of macro 'DC_C'
3677 | DC_C; tft_Write_8(TFT_CASET);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3684:7: note: in expansion of macro 'DC_C'
3684 | DC_C; tft_Write_8(TFT_PASET);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3690:3: note: in expansion of macro 'DC_C'
3690 | DC_C; tft_Write_8(TFT_RAMWR);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual void TFT_eSPI::pushColor(uint16_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\Processors/TFT_eSPI_ESP32_S3.h:625:25: note: in expansion of macro 'tft_Write_16'
625 | #define tft_Write_16N tft_Write_16
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:3711:3: note: in expansion of macro 'tft_Write_16N'
3711 | tft_Write_16N(color);
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp: In member function 'virtual int16_t TFT_eSPI::drawChar(uint16_t, int32_t, int32_t, uint8_t)':
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:5250:31: note: in expansion of macro 'tft_Write_16'
5250 | if (line & mask) {tft_Write_16(textcolor);}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:5251:19: note: in expansion of macro 'tft_Write_16'
5251 | else {tft_Write_16(textbgcolor);}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:5256:18: note: in expansion of macro 'tft_Write_16'
5256 | if (pX) {tft_Write_16(textbgcolor);}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:5305:30: note: in expansion of macro 'tft_Write_16'
5305 | while (tnp--) {tft_Write_16(textcolor);}
C:\Users\paulh\Documents\Arduino\libraries\TFT_eSPI\TFT_eSPI.cpp:5307:19: note: in expansion of macro 'tft_Write_16'
5307 | else {tft_Write_16(textcolor);}
exit status 1
Error compiling for board ESP32S3 Dev Module.
