Arduino Ide 1.8.2 comple error on file that previously worked.
I have a file that is not my code, its code for controlling a 3d matrix display. I have updated my arduino to 1.8.2 and the code is for the chipkit uc32.
The code is throwing too many errors to list them all here, all the errors are the same basic problem.
here is the first subroutine that throws the error.
void displayCube(int side, int x, int y, int z, int color){
 sprite mySprite(side,side,side);
 mySprite.outline(color);
 mySprite.place = {x,y,z};
 mySprite.setIt();
 delay(50);
 mySprite.clearIt();
This is the error i get
m_Animations:89: error: assigning to an array from an initializer list
I am assuming that i would have to change the code to this to fix this error.
 mySprite.place [0] = x;
 mySprite.place [1] = y;
 mySprite.place [2] = z;
 mySprite.setIt();
 delay(50);
 mySprite.clearIt();
My question is what changed in the IDE to cause this error to start happening when the code would actually compile in earlier versions. i make the assumption it compile as is at some point otherwise it would NOT have been written this way in the first place.
Basically i would have to rewrite the entire file to fix every time an array is initialized in this old way with the braced comma separated list.
What version of the Arduino IDE allows arrays to be initialized the old way, as is stands now just about every example in the uc32 chipkit core fails to compile with these errors.
I'm surprised that would have ever worked. You're not initializing the array, you can do this when initializing, for example:
byte place[] = {x,y,z};
is valid.
I had suspected this was related to the chipkit hardware package version, rather than Arduino IDE version, but I tried version 1.0.1 of the package, the oldest one available via Boards Manager and still couldn't set array values this way.
Which version of the Arduino IDE were you using previous to updating to 1.8.2?
Do you remember which version of the chipkit core you were using before? Did you update the version or reinstall after updating to Arduino IDE 1.8.2?
Please give the name of an included example that no longer compiles due to this issue.
Most of the chipkit compile issues I am seeing are dependencies to plib.h which i understand is not included in the new chipkit core. In particular the web server example from diligent website. I was able to compile the example under MPIDE 0150 but not Arduino IDE. I did find a new example in the arduino ide that i was able to compile without the missing plib.h file.
i installed MPIDE version 0150 and i can now compile the above sketch without getting any of the past mentioned errors. This IDE apparently allows arrays to be assigned in the way shown above.
So it looks like i would have to rewrite the sketch to have it compile with the latest version of the Arduino with the chipkit core. Something i may do later since i can at least flash it onto the hardware as is using MPIDE 0150
You could compare the compiler flags used in each IDE for those boards then when you find the one that allows that use of arrays you can add it to the platform.txt in the Arduino chipkit hardware package.
I will certainly try and figure out what changes to make to the platform.txt file, i am currently coding in the old MPIDE, it compiles the code but it lacks lol. Line numbering and code folding which is a major pain in the ........ when you get a compile error code and no line number. The old MPIDE does not even have options for line number or verbose messages when you compile.
