Hello Friends,
I am using an Arduino Mega2560 r3, an L293D IC and a power supply module to run a DC motor. As instructed by the "most complete starter kit" eBook, I looked to my code folder for lesson 29, DC motors, and found an arduino file, as anticipated.
When i open the file with Arduino IDE 1.8.2, I get a error message saying Arduino IDE Failed to open, so I downloaded Developer Virtuoso, and I get the code below in text.
When I upload this sketch, my DC motor spins anti-clockwise, pauses, repeats (also anti-clockwise) 4 more times, then there's a bigger delay, then it spins at a constant speed (still anti-clockwise) for a few seconds, then about a 10 second pause, repeat.
I can tell the code, although i didn't write it, would tell the motor to switch directions back and forth for a bit, to speed up and slow down, than show varying speeds in descending order.
Yet my DC motor shows no variety in speed or direction.
I know it's wired correctly, many different tripple checks, it is a match for what the lesson says and depicts, and what my training with IC's thinks it should be
My question is for what reason would Arduino IDE 1.8.2 not be able to open arduino files provided in the "most complete starter kit" when they could be accessed by Developer Virtuoso; and/or does the code below achieve what in its own footnotes claim to.
None of the code I downloaded from Elegoo in "arduino file" format can be opened by Arduino IDE 1.8.2, although it works great uploading sketches to my arduino mega; I've even reinstalled to no avail.
Will every code provided by Elegoo and opened not with Arduino IDE be corrupted?
Basically if this code below is valid, theres something wrong with my motor
Exercise the motor using
the L293D chip
#define ENABLE 5
#define DIRA 3
#define DIRB 4
int i;
//---set pin direction
pinMode(ENABLE,OUTPUT);
pinMode(DIRA,OUTPUT);
pinMode(DIRB,OUTPUT);
//---back and forth example
Serial.println("One way, then reverse");
digitalWrite(ENABLE,HIGH); // enable on
for (i=0;i<5;i++) {
digitalWrite(DIRA,HIGH); //one way
digitalWrite(DIRB,LOW);
digitalWrite(DIRA,LOW); //reverse
digitalWrite(DIRB,HIGH);
digitalWrite(ENABLE,LOW); // disable
delay(2000);
Serial.println("fast Slow example");
//---fast/slow stop example
digitalWrite(ENABLE,HIGH); //enable on
delay(3000);
digitalWrite(ENABLE,LOW); //slow stop
digitalWrite(DIRA,LOW); //one way
delay(3000);
digitalWrite(DIRA,LOW); //fast stop
delay(2000);
Serial.println("PWM full then slow");
//---PWM example, full speed then slow
analogWrite(ENABLE,255); //enable on
delay(2000);
analogWrite(ENABLE,180); //half speed
delay(2000);
analogWrite(ENABLE,128); //half speed
delay(2000);
analogWrite(ENABLE,50); //half speed
delay(2000);
delay(2000);
delay(2000);
analogWrite(ENABLE,255); //half speed
delay(2000);
digitalWrite(ENABLE,LOW); //all done
delay(10000);
Ultimate project is to use a motion sensor to turn on a fan for about a minute, then the fan turns off until prompted again.
Thanks much if you suffer through reading this all
-Chris
