While I open my IDE, it just pumps up an initial screen, then it quickly disappeared. I want to deal with it by arduino-debug, but it just like the situation of IDE, quickly disappeared...I print my screen before the arduino-debug screen closed, could anyone please help me...my laptop is Win10...
here's the picture link...I cannot understand what the code means on the debug screen...
It’s possible that you made the screenshot before all the text was printed to the screen. It would also be easier for me to translate the non-English text to English if it wasn’t a picture. Please do this:
Click the “Start” menu button.
Type “cmd” into the search field.
Click the search result.
In cmd, type “d:” and press Enter.
Type “d:\Fake_C_Disk\arduino-1.8.9” and press Enter
Type “arduino_debug” and press Enter.
After the Arduino IDE fails to start, press Ctrl + A. This will select all text in the cmd window.
Press Ctrl + C. This will copy the selected text to the clipboard.
In a forum reply here, click the code tags button on the forum toolbar (looks like </>).
Press Ctrl + V. This will paste the selected text between the code tags.
載入組態...
初始化套件...
正在準備開發板...
java.io.IOException: 雲端檔案提供者未執行。
at java.io.FileInputStream.readBytes(Native Method)
at java.io.FileInputStream.read(FileInputStream.java:255)
at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.java:284)
at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.java:326)
at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:178)
at java.io.InputStreamReader.read(InputStreamReader.java:184)
at java.io.BufferedReader.fill(BufferedReader.java:161)
at java.io.BufferedReader.readLine(BufferedReader.java:324)
at java.io.BufferedReader.readLine(BufferedReader.java:389)
at processing.app.legacy.PApplet.loadStrings(PApplet.java:270)
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:100)
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:74)
at processing.app.packages.UserLibrary.create(UserLibrary.java:77)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanLibrary(LibrariesIndexer.java:224)
at cc.arduino.contributions.libraries.LibrariesIndexer.scanInstalledLibraries(LibrariesIndexer.java:201)
at cc.arduino.contributions.libraries.LibrariesIndexer.rescanLibraries(LibrariesIndexer.java:161)
at cc.arduino.contributions.libraries.LibrariesIndexer.setLibrariesFolders(LibrariesIndexer.java:120)
at processing.app.BaseNoGui.onBoardOrPortChange(BaseNoGui.java:678)
at processing.app.Base.onBoardOrPortChange(Base.java:1317)
at processing.app.Base$12.actionPerformed(Base.java:1544)
at processing.app.Base.filterVisibilityOfSubsequentBoardMenus(Base.java:1583)
at processing.app.Base.access$000(Base.java:89)
at processing.app.Base$11.actionPerformed(Base.java:1516)
at processing.app.Base.rebuildBoardsMenu(Base.java:1494)
at processing.app.Base.<init>(Base.java:275)
at processing.app.Base.main(Base.java:151)
java.lang.NullPointerException
at processing.app.helpers.PreferencesMap.load(PreferencesMap.java:101)
Thank you so much, pert!!
I think maybe the problem isn't the named of file. I've totally solved my problem.
Preference : ide 1.8.7 wont start - Installation & Troubleshooting - Arduino Forum
Because of my coumputer software -- OneDrive, had copied my arduino's documents while I had done my install. So that this condition disrupted the opening of Arduino. Then, I deleted the copied documents of arduino and restarted Arduino IDE, it worked!!
Really appreciate you, pert. Thank you again!
Tim0307:
My suggestion of creating the portable folder would have caused the Arduino to run in portable mode:
That makes it so that the Arduino IDE isn't relying on files in any external folder in order to start. It's a good troubleshooting technique when the IDE won't start because if the IDE starts in portable mode you know the problem is with one of the two external folders used by the IDE (and most likely only one of the two).
Tim0307:
Great work finding the solution! Thanks for taking the time to post an update. Anyone else with the same problem who finds this thread will be very grateful. Enjoy!
Per
