Downloaded the new IDE, install seemed to go smoothly, but the program failed to start. Got stuck on what looks like a loading screen. The logo just pulses on a gray background.
I've given all the permissions and done all the troubleshooting by turning off my security features. I don't believe that is the issue. I've uninstalled and reinstalled the software as administrator and restarted the computer.
I have another Arduino instance (1.8.19) installed and wonder if that is interfering with this install. They are in separate Program folders, the older version being in C:\Program Files(x86), and this 2.0.4 being in C:\Program Files.
Oddly enough the errors I see in the log indicate this 2.0.4 instance is seeing and choking on third-party libraries for the other 1.8.19 install. Namely teensy.
The log follows:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.0.4
Starting backend process. PID: 8060
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/andre/.theia'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2023-03-14T02:24:23.099Z root INFO Backend Object.initialize: 3.4 ms [Finished 1.050 s after backend start]
2023-03-14T02:24:23.099Z root INFO Backend Object.configure: 2.7 ms [Finished 1.050 s after backend start]
2023-03-14T02:24:23.100Z root INFO Backend MessagingContribution.onStart: 1.3 ms [Finished 1.050 s after backend start]
2023-03-14T02:24:23.100Z root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.081 s after backend start]
2023-03-14T02:24:23.101Z root INFO Backend DefaultWorkspaceServer.onStart: 0.2 ms [Finished 1.081 s after backend start]
2023-03-14T02:24:23.102Z root INFO Backend PluginLocalizationBackendContribution.configure: 0.1 ms [Finished 1.081 s after backend start]
2023-03-14T02:24:23.102Z root INFO Backend PluginLocalizationBackendContribution.initialize: 30.8 ms [Finished 1.081 s after backend start]
2023-03-14T02:24:23.102Z root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.081 s after backend start]
2023-03-14T02:24:23.103Z root INFO Backend ElectronTokenBackendContribution.configure: 0.9 ms [Finished 1.083 s after backend start]
2023-03-14T02:24:23.103Z config INFO >>> Initializing CLI configuration...
2023-03-14T02:24:23.104Z root INFO Backend PluginDeployerContribution.initialize: 0.5 ms [Finished 1.083 s after backend start]
2023-03-14T02:24:23.104Z root INFO Backend ConfigServiceImpl.onStart: 0.7 ms [Finished 1.083 s after backend start]
2023-03-14T02:24:23.105Z config INFO Loading CLI configuration from c:\Users\andre\.arduinoIDE\arduino-cli.yaml...
2023-03-14T02:24:23.105Z root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.3 ms [Finished 1.084 s after backend start]
2023-03-14T02:24:23.105Z root INFO Backend ArduinoDaemonImpl.onStart: 0.8 ms [Finished 1.085 s after backend start]
2023-03-14T02:24:23.105Z root INFO Backend NodeFileUploadService.configure: 1.6 ms [Finished 1.085 s after backend start]
2023-03-14T02:24:23.105Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
2023-03-14T02:24:23.105Z discovery-log INFO start
2023-03-14T02:24:23.105Z discovery-log INFO start new deferred
2023-03-14T02:24:23.106Z root INFO Backend HostedPluginLocalizationService.initialize: 0.3 ms [Finished 1.086 s after backend start]
2023-03-14T02:24:23.106Z root INFO Backend BoardDiscovery.onStart: 0.8 ms [Finished 1.086 s after backend start]
2023-03-14T02:24:23.106Z root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.086 s after backend start]
2023-03-14T02:24:23.106Z root INFO Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 1.087 s after backend start]
2023-03-14T02:24:23.106Z root INFO Backend PluginApiContribution.configure: 0.4 ms [Finished 1.088 s after backend start]
2023-03-14T02:24:23.107Z root INFO Backend HostedPluginReader.configure: 0.3 ms [Finished 1.088 s after backend start]
2023-03-14T02:24:23.107Z root INFO Backend HostedPluginReader.configure: 0.0 ms [Finished 1.088 s after backend start]
2023-03-14T02:24:23.107Z root INFO Backend PlotterBackendContribution.configure: 0.7 ms [Finished 1.089 s after backend start]
2023-03-14T02:24:23.110Z root INFO Theia app listening on http://localhost:55855.
2023-03-14T02:24:23.110Z root INFO Finished starting backend application: 4.7 ms [Finished 1.092 s after backend start]
2023-03-14T02:24:23.118Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/plugins does not exist.
2023-03-14T02:24:23.118Z root WARN The local plugin referenced by local-dir:/c%3A/Users/andre/.arduinoIDE/extensions does not exist.
2023-03-14T02:24:23.118Z root WARN The local plugin referenced by local-dir:C:\Users\andre\.arduinoProIDE\plugins does not exist.
2023-03-14T02:24:23.132Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.133Z root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@1.5.1" with engines:
2023-03-14T02:24:23.133Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.133Z root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.7" with engines:
2023-03-14T02:24:23.133Z root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
2023-03-14T02:24:23.133Z root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
2023-03-14T02:24:23.133Z root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
2023-03-14T02:24:23.133Z root INFO Resolved "vscode-language-pack-bg" to a VS Code extension "vscode-language-pack-bg@1.48.3" with engines:
2023-03-14T02:24:23.134Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.134Z root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.53.2" with engines:
2023-03-14T02:24:23.135Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.135Z root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.53.2" with engines:
2023-03-14T02:24:23.136Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.136Z root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.53.2" with engines:
2023-03-14T02:24:23.137Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.138Z root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.53.2" with engines:
2023-03-14T02:24:23.139Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.140Z root INFO Resolved "vscode-language-pack-hu" to a VS Code extension "vscode-language-pack-hu@1.48.3" with engines:
2023-03-14T02:24:23.140Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.141Z root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.53.2" with engines:
2023-03-14T02:24:23.141Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.142Z root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.53.2" with engines:
2023-03-14T02:24:23.142Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.143Z root INFO Resolved "vscode-language-pack-ko" to a VS Code extension "vscode-language-pack-ko@1.53.2" with engines:
2023-03-14T02:24:23.144Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.144Z root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
2023-03-14T02:24:23.145Z root INFO Resolved "vscode-language-pack-pl" to a VS Code extension "vscode-language-pack-pl@1.53.2" with engines:
2023-03-14T02:24:23.145Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.146Z root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.53.2" with engines:
2023-03-14T02:24:23.148Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.149Z root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.53.2" with engines:
2023-03-14T02:24:23.149Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.150Z root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.53.2" with engines:
2023-03-14T02:24:23.151Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.151Z root INFO Resolved "vscode-language-pack-uk" to a VS Code extension "vscode-language-pack-uk@1.48.3" with engines:
2023-03-14T02:24:23.152Z root INFO PluginTheiaDirectoryHandler: accepting plugin with path
2023-03-14T02:24:23.153Z root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.53.2" with engines:
2023-03-14T02:24:23.160Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"
},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\andre\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\andre\\AppData\\Local\\Arduino15\\staging","u
ser":"C:\\Users\\andre\\Documents\\Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090"
,"enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2023-03-14T02:24:23.160Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2023-03-14T02:24:23.161Z config INFO Loaded the CLI configuration.
2023-03-14T02:24:23.165Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/andre/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/User
s/andre/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2023-03-14T02:24:23.165Z config INFO Validating the CLI configuration...
2023-03-14T02:24:23.166Z config INFO The CLI config is valid.
2023-03-14T02:24:23.167Z config INFO <<< Initialized the CLI configuration.
2023-03-14T02:24:23.174Z daemon INFO INFO[0000] Using config file: c:\Users\andre\.arduinoIDE\arduino-cli.yaml
INFO[0000] arduino-cli.exe version 0.31.0
INFO[0000] Executing `arduino-cli daemon`
2023-03-14T02:24:23.190Z daemon INFO {"IP":"127.0.0.1","Port":"55856"}
2023-03-14T02:24:23.190Z daemon INFO Daemon is running.
2023-03-14T02:24:23.204Z root INFO Resolve plugins list: 99.8 ms [Finished 1.186 s after backend start]
2023-03-14T02:24:23.205Z daemon INFO INFO[0000] Loading hardware from: C:\Users\andre\AppData\Local\Arduino15\packages
2023-03-14T02:24:23.205Z daemon INFO INFO[0000] Loading package builtin from: C:\Users\andre\AppData\Local\Arduino15\packages\builtin
INFO[0000] Checking existence of 'tools' path: C:\Users\andre\AppData\Local\Arduino15\packages\builtin\tools
INFO[0000] Loading tools from dir: C:\Users\andre\AppData\Local\Arduino15\packages\builtin\tools
2023-03-14T02:24:23.206Z daemon INFO INFO[0000] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0000] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0000] Loaded tool tool="builtin:serial-discovery@1.4.0"
INFO[0000] Loaded tool tool="builtin:serial-monitor@0.13.0"
2023-03-14T02:24:23.210Z root INFO Deployed backend plugin "marus25.cortex-debug@1.5.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extensi
on\dist\extension.js": 5.3 ms [Finished 1.192 s after backend start]
2023-03-14T02:24:23.210Z daemon INFO INFO[0000] Loading package teensy from: C:\Users\andre\AppData\Local\Arduino15\packages\teensy\hardware
INFO[0000] Adding monitor tool protocol=teensy tool="teensy:teensy-monitor"
INFO[0000] Loaded platform platform="teensy:avr@1.57.2"
INFO[0000] Checking existence of 'tools' path: C:\Users\andre\AppData\Local\Arduino15\packages\teensy\tools
INFO[0000] Loading tools from dir: C:\Users\andre\AppData\Local\Arduino15\packages\teensy\tools
INFO[0000] Loaded tool tool="teensy:teensy-compile@5.4.1"
2023-03-14T02:24:23.211Z daemon INFO INFO[0000] Loaded tool tool="teensy:teensy-tools@1.57.2"
2023-03-14T02:24:23.213Z root INFO Deployed backend plugin "arduino.vscode-arduino-tools@0.0.2-beta.7" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscod
e-arduino-tools\extension\dist\bundle": 3.9 ms [Finished 1.196 s after backend start]
2023-03-14T02:24:23.221Z root INFO Deployed backend plugin "vscode.cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension"
: 7.7 ms [Finished 1.204 s after backend start]
2023-03-14T02:24:23.222Z daemon INFO INFO[0000] Checking signature index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\package_index.json"
signatureFile="C:\\Users\\andre\\AppData\\Local\\Arduino15\\package_index.json.sig" trusted=true
INFO[0000] Adding libraries dir dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\teensy\\hardware\\avr\\1.57.2\\libraries" locati
on=platform
INFO[0000] Loading libraries index file index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\library_index.json"
2023-03-14T02:24:23.223Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discove
ry teensy:teensy-discovery not found
2023-03-14T02:24:23.225Z root INFO Deployed backend plugin "vscode.json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extensio
n": 3.6 ms [Finished 1.207 s after backend start]
2023-03-14T02:24:23.227Z root INFO Deployed backend plugin "vscode.json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-bui
ltin-json-language-features\extension\client\dist\jsonMain": 2.2 ms [Finished 1.209 s after backend start]
2023-03-14T02:24:23.294Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-bg@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-bg\extension": 66.9 ms [Finished 1.276 s after backend start]
2023-03-14T02:24:23.353Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-cs@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-cs\extension": 59.0 ms [Finished 1.336 s after backend start]
2023-03-14T02:24:23.452Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-de@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-de\extension": 98.7 ms [Finished 1.434 s after backend start]
2023-03-14T02:24:23.453Z daemon INFO INFO[0000] Adding libraries dir dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\libraries" location=i
de
INFO[0000] Adding libraries dir dir="C:\\Users\\andre\\Documents\\Arduino\\libraries" location=user
2023-03-14T02:24:23.513Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-es@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-es\extension": 61.0 ms [Finished 1.495 s after backend start]
2023-03-14T02:24:23.561Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-fr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-fr\extension": 48.2 ms [Finished 1.544 s after backend start]
2023-03-14T02:24:23.604Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-hu@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-hu\extension": 42.2 ms [Finished 1.586 s after backend start]
2023-03-14T02:24:23.649Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-it@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-it\extension": 45.3 ms [Finished 1.631 s after backend start]
2023-03-14T02:24:23.692Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ja@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-ja\extension": 43.5 ms [Finished 1.675 s after backend start]
2023-03-14T02:24:23.737Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ko@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-ko\extension": 44.3 ms [Finished 1.719 s after backend start]
2023-03-14T02:24:23.757Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-nl\extension": 19.8 ms [Finished 1.739 s after backend start]
2023-03-14T02:24:23.801Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pl@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-pl\extension": 44.5 ms [Finished 1.783 s after backend start]
2023-03-14T02:24:23.843Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-pt-br@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vsc
ode-language-pack-pt-BR\extension": 42.2 ms [Finished 1.826 s after backend start]
2023-03-14T02:24:23.892Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-ru@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-ru\extension": 48.5 ms [Finished 1.874 s after backend start]
2023-03-14T02:24:23.942Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-tr@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-tr\extension": 49.6 ms [Finished 1.924 s after backend start]
2023-03-14T02:24:23.972Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-uk@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode
-language-pack-uk\extension": 30.2 ms [Finished 1.954 s after backend start]
2023-03-14T02:24:24.017Z root INFO Deployed backend plugin "ms-ceintl.vscode-language-pack-zh-hans@1.53.2" from "C:\Program Files\Arduino IDE\resources\app\plugins\v
scode-language-pack-zh-hans\extension": 44.4 ms [Finished 1.999 s after backend start]
2023-03-14T02:24:24.017Z root INFO Deploy plugins list: 99.8 ms [Finished 1.999 s after backend start]
Opening channel for service path '/services/electron-window-ext'.
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2023-03-14T02:24:24.652Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 153.1 ms [Finished 1.474 s after frontend start]
2023-03-14T02:24:25.010Z root ERROR The primary packages indexes are missing. Running indexes update before initializing the core gRPC client
2023-03-14T02:24:25.011Z daemon INFO INFO[0001] Updating index url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-03-14T02:24:25.012Z daemon INFO INFO[0001] Starting download url="https://downloads.arduino.cc/packages/package_index.tar.bz2"
2023-03-14T02:24:25.013Z root INFO core-client-provider [platform-index]
2023-03-14T02:24:25.221Z daemon INFO INFO[0002] Loading hardware from: C:\Users\andre\AppData\Local\Arduino15\packages
2023-03-14T02:24:25.222Z daemon INFO INFO[0002] Loading package builtin from: C:\Users\andre\AppData\Local\Arduino15\packages\builtin
2023-03-14T02:24:25.222Z daemon INFO INFO[0002] Checking existence of 'tools' path: C:\Users\andre\AppData\Local\Arduino15\packages\builtin\tools
INFO[0002] Loading tools from dir: C:\Users\andre\AppData\Local\Arduino15\packages\builtin\tools
INFO[0002] Loaded tool tool="builtin:ctags@5.8-arduino11"
INFO[0002] Loaded tool tool="builtin:mdns-discovery@1.0.8"
INFO[0002] Loaded tool tool="builtin:serial-discovery@1.4.0"
2023-03-14T02:24:25.223Z daemon INFO INFO[0002] Loaded tool tool="builtin:serial-monitor@0.13.0"
2023-03-14T02:24:25.225Z daemon INFO INFO[0002] Loading package teensy from: C:\Users\andre\AppData\Local\Arduino15\packages\teensy\hardware
2023-03-14T02:24:25.225Z daemon INFO INFO[0002] Adding monitor tool protocol=teensy tool="teensy:teensy-monitor"
INFO[0002] Loaded platform platform="teensy:avr@1.57.2"
2023-03-14T02:24:25.226Z daemon INFO INFO[0002] Checking existence of 'tools' path: C:\Users\andre\AppData\Local\Arduino15\packages\teensy\tools
INFO[0002] Loading tools from dir: C:\Users\andre\AppData\Local\Arduino15\packages\teensy\tools
2023-03-14T02:24:25.226Z daemon INFO INFO[0002] Loaded tool tool="teensy:teensy-compile@5.4.1"
INFO[0002] Loaded tool tool="teensy:teensy-tools@1.57.2"
2023-03-14T02:24:25.230Z daemon INFO INFO[0002] Checking signature index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\package_index.json"
2023-03-14T02:24:25.231Z root ERROR Detected an error response during the gRPC core client initialization: code: 9, message: Error loading hardware platform: discove
2023-03-14T02:24:25.233Z daemon INFO INFO[0002] Adding libraries dir dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\packages\\teensy\\har
dware\\avr\\1.57.2\\libraries" location=platform
INFO[0002] Loading libraries index file index="C:\\Users\\andre\\AppData\\Local\\Arduino15\\library_index.json"
2023-03-14T02:24:25.365Z daemon INFO INFO[0002] Adding libraries dir dir="C:\\Users\\andre\\AppData\\Local\\Arduino15\\libraries" location=i
de
2023-03-14T02:24:25.365Z daemon INFO INFO[0002] Adding libraries dir dir="C:\\Users\\andre\\Documents\\Arduino\\libraries" location=user
2023-03-14T02:24:26.809Z root ERROR Uncaught Exception:
2023-03-14T02:24:26.809Z root ERROR Error: The index of the cores and libraries must be updated before initializing the core gRPC client.
The following problems were detected during the gRPC client initialization:
[platform-index] - code: 9, message: Error loading hardware platform: discovery teensy:teensy-discovery not found
at isIndexUpdateRequiredBeforeInit (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:388:11)
at CoreClientProvider.evaluateErrorStatus (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:200:16)
at processTicksAndRejections (node:internal/process/task_queues:96:5)
at async ClientReadableStreamImpl.<anonymous> (C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\lib\node\core-client-provider.js:184
:31)
> [2036:0313/192622.156:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
