Arduino IDE 2.00 and LilyGo T-Display ESP S3 - Black Screen
I got the newest LilyGo T-Display ESP32 S3 board and tried to use it with some nice coding ( Is this Best ESP32 board? New T-Display S3 ESP32S3 - YouTube ).
After several trials, I could not make it working.
Compiler compiles, the upload is ok everthing looks good, however the display is black all the time. Tried to resintall all the libraries several times without success.
Downgraded to Arduino IDE V 1.18.12 and also tested V 1.18.19.
In both cases the board worked fine, following this instructions ( T-Display S3 - How to install in Arduino IDE - YouTube ).
Maybe it is V2.00 that is not working with this board.
If you could take a look on that would be great!
Hi @blastaar_br. Thanks for your report.
I'm going to ask you to provide the verbose output from compiling your sketch using both Arduino IDE 1.8.19 and 2.0.0. It is possible this might allow us to spot the cause of the different results you are seeing.
:exclamation: NOTE: These instructions will not solve the problem. They are only intended to gather some more information about the problem.
Please do this:
  1. Start Arduino IDE 1.8.19.
  2. Select File > Preferences from the Arduino IDE 1.8.19 menus.
  3. Check the box next to "Show verbose output during: โ˜ compilation".
  4. Click the OK button.
  5. Select Sketch > Verify/Compile from the Arduino IDE 1.8.19 menus.
  6. Wait for the compilation to finish.
  7. Click on the black console pane at the bottom of the Arduino IDE 1.8.19 window.
  8. Press Ctrl+A to select all the text.
  9. Press Ctrl+C.
    This will copy the selected text to the clipboard.
  10. Select **File > Quit from the Arduino IDE 1.8.19 menus.
  11. Open a forum reply here by clicking the Reply button.
  12. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the compilation output is correctly formatted.
    Code block
  13. Press Ctrl+V.
    This will paste the compilation output into the code block.
Now do the same, but with Arduino IDE 2.x this time:
  1. Start Arduino IDE 2.x
  2. Select File > Preferences from the Arduino IDE 2.x menus.
  5. Select Sketch > Verify/Compile from the Arduino IDE 2.x menus.
  7. Right click on the black "Output" pane at the bottom of the Arduino IDE 2.x window.
  8. From the context menu, click Copy All.
  9. Switch back to the browser window containing the forum reply you started composing in the previous step.
  10. Click the </> icon on the post composer toolbar.
  11. Press Ctrl+V.
  12. Move the cursor outside of the code tags before you add any additional text to your reply.
  13. Click the Reply button to post the output.
In case the output is longer than the forum software will allow to be added to a post, you can instead save it to a .txt file and then attach that file to a reply here:
  1. Open any text editor program.
  2. Paste the copied output into the text editor.
  3. Save the file in .txt format.
  4. Open a forum reply here by clicking the Reply button.
  5. Click the "Upload" icon (image) on the post composer toolbar:
  6. Select the .txt file you saved.
  7. Click the Open button.
  8. Click the Reply button to publish the post.
Alternatively, instead of using the "Upload" icon on the post composer toolbar as described in steps (5) - (7) above, you can simply drag and drop the .txt file onto the post composer field to attach it.
I have the same issue and have the output you requested. Unfortunately I can't upload them here yet, so I uploaded them to pastebin:
1.8.19: C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs - - Pastebin.com
2.0.0: Using board 'esp32s3box' from platform in folder: C:\Users\user\AppData\Local\Ar - Pastebin.com
I don't think esp32s3box works with the Lilygo esp32 S3 t display, I am using ESP32S3 Dev Module from the Arduino IDE boards manager. If you are using VS code with PlatformIO the board selection is esp32-s3-devkitc-1
Hereby the Verbose for the two Arduino IDE versions 1.18.19 and 2.0.0, as asked.
Verbose Arduino V2.00.txt (502.1 KB)
Verbose Arduino V1.8.19.txt (1.8 MB)
Hope it helps finding a solution.
On Arduino 1.8.19 the module works fine with ESP32-S3-Box selected as board.
And also with ESP32S3 Dev Module selected.
Thanks hapklaar, I had problems with s3 box but I will try it again.
Hi, after some tests here I guess there is a hint where the problem in V2.0.0 is:
  1. I did a clean install of the V2.00 here.
  2. I used the code that Volos has shared in this video: How to Scroll Image (ESP32 and TFT display) - YouTube
  3. I used the "Additional boards manager URLS = https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json (from Lilygo website)
    Choose the board as: ESP32S3 Dev Module
And simply compile/upload the code.
  1. After compile and upload, It surprinsgly worked here in the board!! :grimacing:
  2. Then I closed Arduino IDE 2.0.0 and went to the folder where the .ino files for the code are.
  3. Double click on the .ino code and Arduino V2.0.0 opened again.
  4. in the monitoring area a message pop up informing that there are new updates for libraries. I accept installing it and realized that the following libraries were updated:
Downloading lvgl@8.3.2
Installing lvgl@8.3.2
Replacing lvgl@8.3.0-dev with lvgl@8.3.2
Installed lvgl@8.3.2
Downloading TFT_eSPI@2.4.72
Installing TFT_eSPI@2.4.72
Replacing TFT_eSPI@2.4.71 with TFT_eSPI@2.4.72
Installed TFT_eSPI@2.4.72
  1. Try to compile and upload again and now the screen got black !
It seems that there is something wrong with the new libraries...
I attaching the verbose for both situations! Hope it helps!
Verbose V2.0.0 Imagescroll code OK working.txt (217.7 KB)
Verbose V2.0.0 Imagescroll code NOT working.txt (217.9 KB)
Possibly a problem here. The Lilygo directions specifically say to install the TFT_eSPI library files from the following link GitHub - Xinyuan-LilyGO/T-Display-S3
The version number of that header file is 2.4.71 so it might be a possibility that you over wrote the file that you need
What I have tried to do is manually over write the TFT_eSPI@2.4.72 with the TFT_eSPI@2.4.71 . I could see in the library panel filtering by the installed libraries that it accepted the V2.4.71 again, but it did not work.
Need to uninstall Arduino IDE V 2.0.0 and reinstall the V1.18.19, using the TFT_eSPI@2.4.71 library to get the display working again.
Thanks to you both. I was interested in in seeing the output because I had a hypothesis that the different results might be caused by different dependency versions being used in Arduino IDE 1.8.19 vs 2.0.0. The output shows the dependency versions.
The output shared by @hapklaar shows that both IDE versions are using the same dependency versions:
Arduino IDE 1.8.19:
Arduino IDE 2.0.0:
If you look at the same information from @blastaar_br's output, we can see the different library dependency version between the working and non-working states
Working:
The initial information shared by @blastaar_br does indicate the problem was actually caused by updating the "TFT_eSPI" library rather than the different IDE versions:
Working:
However, I'm not sure what is going on here:
@blastaar_br. What exactly do you mean by "manually over write"? Did you copy TFT_eSPI@2.4.71 over the top of the TFT_eSPI@2.4.72 installation?
By the way mine was working now as well, after restarting my PC and recompiling + reflashing.
I think it must have been the previously accidentally updated TFT_eSPI library that caused my issue. I had replaced it with the correct older Lilygo specific one, but apparently that didn't work immediately.
Anyway, thanks for looking into it!
Hi , yes correct! The manufacturer Lilygo makes the V 2.4.71 available ( GitHub - Xinyuan-LilyGO/T-Display-S3 ).
Is there any chance to investigate what is wrong with the TFT_eSPI@2.4.72 , and correct it?
Go for it! This is what open source is all about.
The repository of the library is here:
Start by checking the issue tracker:
It looks like maybe there are some relevant items there already, like this:
Lilygo link to the following page GitHub - Xinyuan-LilyGO/T-Display-S3 on GitHub that contains a pinout diagram, some examples and lower down the page there is a quick start guide and below that is a quick-question-and-answer that describes that the original TFT_eSPI has been modified to work with the Lilygo display either that or there is a patch available on the same page to use with the original library.
I found some time to look at this more today and I was able to reproduce it.
I see that the cached compilation of 2.4.72 is still used even after replacing it with 2.4.71. This is shown in the verbose compilation output:
Compiling library "TFT_eSPI"
Using previously compiled file: C:\Users\per\AppData\Local\Temp\arduino-sketch-B931B68621C0206DBA43FF56A0E05E51\libraries\TFT_eSPI\TFT_eSPI.cpp.o
The caching of compiled libraries is a very useful feature because it means that, after the first compilation, only the sketch code needs to be recompiled on subsequent compilations. This makes those subsequent compilations much faster. But it is also important for the Arduino IDE to recognize when the library has been changed and recompile it. The IDE normally does a good job of that, but it is failing in this case.
I found I was able to force the IDE to clear the cached library compilation by the following technique:
  1. Select Tools > Board > Arduino AVR Boards > Arduino Uno from the Arduino IDE menus.
    โ“˜ Selecting any other board will work. I just picked the Uno as a board most people will have in their IDE.
  2. Select Sketch > Verify/Compile from the Arduino IDE menus.
  3. Wait for the compilation to fail.
  4. Select the actual board you are using from the Tools > Board menu in the Arduino IDE.
  5. Upload the sketch to your board.
This time around, if you have verbose compilation output enabled in the preferences, you should see that the library is recompiled from source:
"C:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32s3-elf-gcc\\gcc8_4_0-esp-2021r2-patch3/bin/xtensa-esp32s3-elf-g++" -DHAVE_CONFIG_H "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DUNITY_INCLUDE_CONFIG_H -DWITH_POSIX -D_GNU_SOURCE "-DIDF_VER=\"v4.4.2\"" -DESP_PLATFORM -D_POSIX_READER_WRITER_LOCKS "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/newlib/platform_include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/freertos/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/freertos/include/esp_additions/freertos" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/freertos/port/xtensa/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/freertos/include/esp_additions" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_hw_support/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_hw_support/include/soc" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_hw_support/include/soc/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_hw_support/port/esp32s3/private_include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/heap/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/log/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/lwip/include/apps" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/lwip/include/apps/sntp" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/lwip/lwip/src/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/lwip/port/esp32/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/lwip/port/esp32/include/arch" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/soc/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/soc/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/soc/esp32s3/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/hal/esp32s3/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/hal/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/hal/platform_port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_rom/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_rom/include/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_rom/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_common/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_system/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_system/port/soc" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_system/port/public_compat" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/xtensa/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/xtensa/esp32s3/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/driver/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/driver/esp32s3/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_pm/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_ringbuf/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/efuse/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/efuse/esp32s3/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/vfs/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_wifi/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_event/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_netif/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_eth/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/tcpip_adapter/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_phy/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_phy/esp32s3/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_ipc/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/app_trace/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_timer/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/mbedtls/port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/mbedtls/mbedtls/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/mbedtls/esp_crt_bundle/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/app_update/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/spi_flash/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bootloader_support/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/nvs_flash/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/pthread/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_gdbstub/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_gdbstub/xtensa" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_gdbstub/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/espcoredump/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/espcoredump/include/port/xtensa" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/wpa_supplicant/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/wpa_supplicant/port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/wpa_supplicant/esp_supplicant/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/ieee802154/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/console" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/asio/asio/asio/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/asio/port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/common/osi/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/include/esp32s3/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/common/api/include/api" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/blufi/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/common/btc/profile/esp/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/host/bluedroid/api/include/api" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_common/tinycrypt/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_core/storage" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/btc/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/common/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/client/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/mesh_models/server/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/core/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api/models/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/bt/esp_ble_mesh/api" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/cbor/port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/unity/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/unity/unity/src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/cmock/CMock/src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/coap/port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/coap/libcoap/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/nghttp/port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/nghttp/nghttp2/lib/includes" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-tls" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-tls/esp-tls-crypto" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_adc_cal/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_hid/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/tcp_transport/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_http_client/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_http_server/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_https_ota/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_https_server/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_lcd/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_lcd/interface" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/protobuf-c/protobuf-c" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/protocomm/include/common" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/protocomm/include/security" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/protocomm/include/transports" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/mdns/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_local_ctrl/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/sdmmc/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_serial_slave_link/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_websocket_client/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/expat/expat/expat/lib" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/expat/port/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/wear_levelling/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/fatfs/diskio" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/fatfs/vfs" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/fatfs/src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/freemodbus/common/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/idf_test/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/idf_test/include/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/jsmn/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/json/cJSON" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/libsodium/libsodium/src/libsodium/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/libsodium/port_include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/mqtt/esp-mqtt/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/openssl/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/perfmon/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/spiffs/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/usb/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/ulp/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/wifi_provisioning/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/rmaker_common/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/json_parser/upstream/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/json_parser/upstream" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/json_generator/upstream" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_schedule/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_rainmaker/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/gpio_button/button/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/qrcode/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/ws2812_led" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/dotprod/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/support/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/windows/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/windows/hann/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/windows/blackman/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/windows/blackman_harris/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/windows/blackman_nuttall/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/windows/nuttall/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/windows/flat_top/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/iir/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/fir/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/math/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/math/add/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/math/sub/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/math/mul/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/math/addc/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/math/mulc/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/math/sqrt/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/matrix/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/fft/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/dct/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/conv/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/common/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/kalman/ekf/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dsp/modules/kalman/ekf_imu13states/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/freertos/include/freertos" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/arduino_tinyusb/tinyusb/src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/arduino_tinyusb/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp_littlefs/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/tool" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/typedef" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/image" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/math" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/nn" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/layer" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/detect" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-dl/include/model_zoo" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-sr/src/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-sr/esp-tts/esp_tts_chinese/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp-sr/include/esp32s3" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp32-camera/driver/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/esp32-camera/conversions/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/include/fb_gfx/include" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5/tools/sdk/esp32s3/qio_opi/include" -mlongcalls -ffunction-sections -fdata-sections -Wno-error=unused-function -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-sign-compare -ggdb -Os -freorder-blocks -Wwrite-strings -fstack-protector -fstrict-volatile-bitfields -Wno-error=unused-but-set-variable -fno-jump-tables -fno-tree-switch-conversion -std=gnu++11 -fexceptions -fno-rtti -MMD -c -w -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_S3_BOX -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_S3_BOX\"" "-DARDUINO_VARIANT=\"esp32s3box\"" -DARDUINO_PARTITION_default -DESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DBOARD_HAS_PSRAM -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=1 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 "@C:\\Users\\per\\AppData\\Local\\Temp\\arduino-sketch-B931B68621C0206DBA43FF56A0E05E51/build_opt.h" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\cores\\esp32" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\variants\\esp32s3box" "-Ic:\\Users\\per\\Documents\\Arduino\\libraries\\TFT_eSPI" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\libraries\\SPI\\src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\libraries\\FS\\src" "-IC:\\Users\\per\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.5\\libraries\\SPIFFS\\src" "c:\\Users\\per\\Documents\\Arduino\\libraries\\TFT_eSPI\\TFT_eSPI.cpp" -o "C:\\Users\\per\\AppData\\Local\\Temp\\arduino-sketch-B931B68621C0206DBA43FF56A0E05E51\\libraries\\TFT_eSPI\\TFT_eSPI.cpp.o"
Hi, this procedure worked! Now I can move forward with Arduino IDE 2.0.0!
Thank you so much.
You are welcome. I'm glad it is working now.
Hi - I was having the same problem with this my first Arduino board.
After initially installing the TFT_esPI 2.4.71 library from LilyGo all was working OK but then it stopped.
After reading this thread it became obvious that the Arduino IDE had updated the library to 2.4.72.
Re-installing the LilyGo version and cleaning the build directory fixed it - so many thanks for the advice.
One thing to note is the custom LilyGo setup seems doesn't use the include the "User_Setup.h" file to configure the board in the User_Setup_Select.h file as the un-modified library recommends; instead it includes the "User_Setups/Setup24_ST7789.h" which has been modified from the normal one. Could it be that this is overwritten when the library is updated because ( ignoring the Mickey.patch issue) wouldn't that break things. ?
