Arduino IDE 2.3.10 is now available
Is there still no Apple Silicon version?
@bquirky
There are two versions available from https://www.arduino.cc/en/software/ for the Mac; one of them is labelled "Silicon".
I'm not a Mac user so I don't know any intricacies.
Looks like the first available Apple Silicon (aka arm64) version was 2.0.3; but the first released simultaneously with the others was 2.2.0, three years ago.
Doing a bit of research the issue seems to be (parts of) the toolchain that still require Rosetta, not the IDE itself.
There might be more but How to avoid installing Rosetta on an Apple Silicon Mac - #7 by ptillisch contains two links to issues.
While the IDE download for MacOS is published as both x86_64 and arm64, on first use the IDE automatically downloads a few x86_64 components.
Calling ctags an "external" component is disingenuous. It is used automatically when compiling all sketches, regardless of the board / platform selected. As far as I know (and I would love to be proven wrong on this) the Arduino platform spec doesn't provide any way for packages to override or replace ctags. For all practical purposes, ctags is effectively part of the IDE. I and others have tried to help with building ctags for arm64. My hope is the Arduino developers will update their ctags download with an arm64 build.
I believe the other x86_64 components are only used for boards with AVR processors.
I have also tried to help with the AVR toolchain. It is much more challenging than ctags, but with some effort I was able to modify Arduino's scripts to build it for Apple Silicon.
The main change is the math libraries (gmp, mpc, mpfr) which gcc uses internally to perform math operations as the target processor would. Newer versions of these libraries which support Apple Silicon are required. Otherwise the same version of gcc and same set of avr-gcc patches Arduino has used for many years are faithfully reproduced, which should give a build which very closely matches the avr-gcc Arduino has published for many years on all other platforms.
Some shell hackery shows which tools have been updated to run on Apple Silicon
pushd ~/Library/Arduino15 ; diff -u <(find . -type f -perm +111 \
 -exec sh -c 'file "{}" | grep -q "x86_64" && ! file "{}" | grep -q "arm64"' \; \
 -exec dirname -- {} \; | sort -u
) <(find . -type f -perm +111 \
 -exec sh -c 'file "{}" | grep -q "arm64"' \; \
) | sort -d ; popd
For example, narrowing that initial directory to ~/Library/Arduino15/packages/esp32 yields
+./tools/esp-rv32/2507/bin
+./tools/esp-rv32/2507/lib
+./tools/esp-rv32/2507/lib/bfd-plugins
+./tools/esp-rv32/2507/libexec/gcc/riscv32-esp-elf/14.2.0
+./tools/esp-rv32/2507/libexec/gcc/riscv32-esp-elf/14.2.0/install-tools
+./tools/esp-rv32/2507/libexec/gcc/riscv32-esp-elf/14.2.0/plugin
+./tools/esp-rv32/2507/lib/gcc/riscv32-esp-elf/14.2.0/plugin
+./tools/esp-rv32/2507/riscv32-esp-elf/bin
-./tools/esptool_py/4.5.1
+./tools/esptool_py/5.1.0
+./tools/esp-x32/2507/bin
+./tools/esp-x32/2507/lib
+./tools/esp-x32/2507/lib/bfd-plugins
+./tools/esp-x32/2507/libexec/gcc/xtensa-esp-elf/14.2.0
+./tools/esp-x32/2507/libexec/gcc/xtensa-esp-elf/14.2.0/install-tools
+./tools/esp-x32/2507/libexec/gcc/xtensa-esp-elf/14.2.0/plugin
+./tools/esp-x32/2507/lib/gcc/xtensa-esp-elf/14.2.0/plugin
+./tools/esp-x32/2507/xtensa-esp-elf/bin
-./tools/mklittlefs/3.0.0-gnu12-dc7f933
-./tools/mklittlefs/4.0.2-db0513a
-./tools/mkspiffs/0.2.3
+./tools/openocd-esp32/v0.12.0-esp32-20230921/bin
+./tools/openocd-esp32/v0.12.0-esp32-20250707/bin
+./tools/riscv32-esp-elf-gdb/16.3_20250913/bin
+./tools/s3-gcc/2021r2-p5/bin
+./tools/s3-gcc/2021r2-p5/lib
+./tools/s3-gcc/2021r2-p5/libexec/gcc/xtensa-esp32s3-elf/8.4.0
+./tools/s3-gcc/2021r2-p5/libexec/gcc/xtensa-esp32s3-elf/8.4.0/install-tools
+./tools/s3-gcc/2021r2-p5/libexec/gcc/xtensa-esp32s3-elf/8.4.0/plugin
+./tools/s3-gcc/2021r2-p5/lib/gcc/xtensa-esp32s3-elf/8.4.0/plugin
+./tools/s3-gcc/2021r2-p5/xtensa-esp32s3-elf/bin
+./tools/xtensa-esp-elf-gdb/11.2_20220823/bin
+./tools/xtensa-esp-elf-gdb/11.2_20220823/lib
+./tools/xtensa-esp-elf-gdb/16.3_20250913/bin
+./tools/xtensa-esp-elf-gdb/16.3_20250913/lib
So version 4.5.1 of esptool_py is Intel, requiring Rosetta, but 5.1.0 has been updated to Apple Silicon; as has most of the toolchain.
Almost everything in packages/arduino still requires Rosetta. For packages/builtin
-./packages/builtin/tools/ctags/5.8-arduino11
+./packages/builtin/tools/dfu-discovery/0.1.2
+./packages/builtin/tools/mdns-discovery/1.0.12
+./packages/builtin/tools/mdns-discovery/1.0.9
+./packages/builtin/tools/serial-discovery/1.4.1
+./packages/builtin/tools/serial-discovery/1.4.3
+./packages/builtin/tools/serial-monitor/0.14.1
+./packages/builtin/tools/serial-monitor/0.15.0
only ctags (I have IDE 2.3.6 on this box)
