Hallo, after an update of my linux os (openSUSE Tumbleweed) the arduino ide shows only a blank window. I have tested it with the version 2.3.2_Linux_64bit and nightly-20240322_Linux_64bit.
A rollback of the os updates fixes the problem, so i can still work with the ide.
The console output shows the following errors:
// Vertex SKSL
#extension GL_NV_shader_noperspective_interpolation: require
uniform float4 sk_RTAdjust;in float2 position;in float2 localCoord;noperspective out float2 vlocalCoord_S0;void main() {// Primitive Processor QuadPerEdgeAAGeometryProcessor
vlocalCoord_S0 = localCoord;sk_Position = position.xy01;}
// Fragment SKSL
sampler2D uTextureSampler_0_S0;
noperspective in float2 vlocalCoord_S0;void main() {// Stage 0, QuadPerEdgeAAGeometryProcessor
half4 outputColor_S0 = half4(1);float2 texCoord;texCoord = vlocalCoord_S0;outputColor_S0 = (blend_modulate(sample(uTextureSampler_0_S0, texCoord), half4(1)));const half4 outputCoverage_S0 = half4(1);{ // Xfer Processor: Porter Duff
sk_FragColor = outputColor_S0 * outputCoverage_S0;}}
// Vertex GLSL
#version 300 es
#extension GL_NV_shader_noperspective_interpolation : require
precision mediump float;
precision mediump sampler2D;
uniform highp vec4 sk_RTAdjust;
in highp vec2 position;
in highp vec2 localCoord;
noperspective out highp vec2 vlocalCoord_S0;
void main() {
gl_Position = vec4(position, 0.0, 1.0);
gl_Position = vec4(gl_Position.xy * sk_RTAdjust.xz + gl_Position.ww * sk_RTAdjust.yw, 0.0, gl_Position.w);
// Fragment GLSL
#version 300 es
out mediump vec4 sk_FragColor;
uniform sampler2D uTextureSampler_0_S0;
noperspective in highp vec2 vlocalCoord_S0;
void main() {
mediump vec4 outputColor_S0 = vec4(1.0);
highp vec2 texCoord = vlocalCoord_S0;
outputColor_S0 = texture(uTextureSampler_0_S0, texCoord, -0.5);
sk_FragColor = outputColor_S0;
Errors:
link failed but did not provide an info log
[30278:0322/152109.237893:ERROR:shared_context_state.cc(98)] Skia shader compilation error
Best regards
Volkher
