Arduino IDE 2.3.2 debugger not working
Back to IDE 2.3.3 and board 2.0.18-20240930 - the current latest versions.
I find that I can get Serial0 prints to work while using the debugger, but not regular Serial prints. I would love to know if there is a way around this.
I do see regular Serial prints inside Setup() but not inside Loop() - very weird.
In order to get the Serial0 prints I use a USB connector with a Prolific PL2303C chip inside it, made by Dtech and bought off Amazon.
Warning!!!! Do not connect the red +ve line as it puts out 5V, but you do need the black gnd connected. I have the green line in TX0 (embossed TX1 on my board???) and the white line in RX0. You need to have a USB connection into the Nano's USB-C connector for uploading and for powering the Nano, and another USB connection into the Dtech port.
This is my test code - just a slightly modified Blink:
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
  delay(2000);
  Serial.println("Serial starting - 18 Nov 2024 #2");
  Serial0.begin(115200);
  delay(2000);
  Serial0.println("Serial0 starting - 18 Nov 2024 #2");
// the loop function runs over and over again forever
  static int i = 1;
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
  Serial.println("Serial: " + String(i));
  Serial0.println("Serial0: " + String(i));
  i = i+1;
