Arduino IDE 2.3.2 endless loading problem [Windows 10]]
I have problem in starting up the Arduino IDE. It stuck on loading screen.
Here is my error log.
PS C:\Users\JBY\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.2
Checking for frontend application configuration customizations. Module path: C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.2" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "0.35.3" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-02-20T10:04:35.814Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.2","cliVersion":"0.35.3","buildDate":"2024-02-20T10:04:35.814Z"}
Starting backend process. PID: 20212
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/JBY/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-05-19T05:12:35.009Z root INFO Backend Object.initialize: 7.2 ms [Finished 0.554 s after backend start]
2024-05-19T05:12:35.011Z root INFO Backend Object.configure: 6.5 ms [Finished 0.554 s after backend start]
2024-05-19T05:12:35.011Z root INFO Backend s.onStart: 2.6 ms [Finished 0.554 s after backend start]
2024-05-19T05:12:35.012Z root INFO Backend s.configure: 0.4 ms [Finished 0.578 s after backend start]
2024-05-19T05:12:35.012Z root INFO Backend d.onStart: 0.3 ms [Finished 0.578 s after backend start]
2024-05-19T05:12:35.013Z root INFO Backend d.configure: 0.1 ms [Finished 0.578 s after backend start]
2024-05-19T05:12:35.014Z root INFO Backend d.initialize: 23.1 ms [Finished 0.578 s after backend start]
2024-05-19T05:12:35.014Z root INFO Backend c.onStart: 0.2 ms [Finished 0.578 s after backend start]
2024-05-19T05:12:35.015Z root INFO Backend a.configure: 2.4 ms [Finished 0.580 s after backend start]
2024-05-19T05:12:35.017Z config INFO >>> Initializing CLI configuration...
2024-05-19T05:12:35.017Z root INFO Backend c.initialize: 0.5 ms [Finished 0.581 s after backend start]
2024-05-19T05:12:35.017Z root INFO Backend R.onStart: 0.7 ms [Finished 0.581 s after backend start]
2024-05-19T05:12:35.018Z config INFO Loading CLI configuration from c:\Users\JBY\.arduinoIDE\arduino-cli.yaml...
2024-05-19T05:12:35.018Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.018Z root INFO Backend a.initialize: 0.4 ms [Finished 0.582 s after backend start]
2024-05-19T05:12:35.018Z root INFO Backend w.onStart: 1.3 ms [Finished 0.583 s after backend start]
2024-05-19T05:12:35.018Z root INFO Backend r.configure: 2.0 ms [Finished 0.583 s after backend start]
2024-05-19T05:12:35.018Z discovery-log INFO start
2024-05-19T05:12:35.018Z discovery-log INFO start new deferred
2024-05-19T05:12:35.019Z root INFO Backend d.initialize: 0.6 ms [Finished 0.584 s after backend start]
2024-05-19T05:12:35.019Z root INFO Backend y.onStart: 2.5 ms [Finished 0.586 s after backend start]
2024-05-19T05:12:35.019Z root INFO Backend r.configure: 2.0 ms [Finished 0.586 s after backend start]
2024-05-19T05:12:35.019Z root INFO Backend a.onStart: 0.7 ms [Finished 0.587 s after backend start]
2024-05-19T05:12:35.019Z root INFO Backend h.configure: 0.6 ms [Finished 0.587 s after backend start]
2024-05-19T05:12:35.019Z root INFO Backend s.configure: 0.2 ms [Finished 0.588 s after backend start]
2024-05-19T05:12:35.019Z root INFO Backend l.configure: 0.1 ms [Finished 0.588 s after backend start]
2024-05-19T05:12:35.022Z root INFO Theia app listening on http://127.0.0.1:59345.
2024-05-19T05:12:35.023Z root INFO Finished starting backend application: 4.1 ms [Finished 0.591 s after backend start]
2024-05-19T05:12:35.034Z root WARN The local plugin referenced by local-dir:/c%3A/Users/JBY/.arduinoIDE/plugins does not exist.
2024-05-19T05:12:35.034Z root WARN The local plugin referenced by local-dir:/c%3A/Users/JBY/.arduinoIDE/extensions does not exist.
2024-05-19T05:12:35.034Z root WARN The local plugin referenced by local-dir:C:\Users\JBY\.arduinoIDE\plugins does not exist.
2024-05-19T05:12:35.040Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"C:\\Users\\JBY\\AppData\\Local\\Arduino15","downloads":"C:\\Users\\JBY\\AppData\\Local\\Arduino15\\staging","user":"."},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-05-19T05:12:35.040Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-05-19T05:12:35.040Z config INFO Loaded the CLI configuration.
2024-05-19T05:12:35.042Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/JBY/AppData/Local/Arduino15","sketchDirUri":"file:///.","additionalUrls":[],"network":"none","locale":"en"}
2024-05-19T05:12:35.042Z config INFO Validating the CLI configuration...
2024-05-19T05:12:35.045Z config INFO The CLI config is valid.
2024-05-19T05:12:35.045Z config INFO <<< Initialized the CLI configuration.
2024-05-19T05:12:35.090Z root INFO Resolve plugins list: 72.3 ms [Finished 0.658 s after backend start]
2024-05-19T05:12:35.112Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.112Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
    at Socket.<anonymous> (C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:43051)
    at Socket.emit (node:events:514:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at Socket.push (node:internal/streams/readable:234:10)
    at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-05-19T05:12:35.112Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.209Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.209Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.210Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.210Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.211Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-19T14:12:35+09:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-19T14:12:35+09:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:59347
{"IP":"127.0.0.1","Port":"59347"}
2024-05-19T05:12:35.247Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.328Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59348
{"IP":"127.0.0.1","Port":"59348"}
2024-05-19T05:12:35.329Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.329Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.329Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.409Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.409Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59349
{"IP":"127.0.0.1","Port":"59349"}
2024-05-19T05:12:35.410Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.410Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.410Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.489Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.490Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.490Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.490Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.490Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59350
{"IP":"127.0.0.1","Port":"59350"}
2024-05-19T05:12:35.598Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.599Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.599Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.599Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.599Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59351
{"IP":"127.0.0.1","Port":"59351"}
2024-05-19T05:12:35.656Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.671Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.671Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.671Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.683Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59352
{"IP":"127.0.0.1","Port":"59352"}
2024-05-19T05:12:35.722Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.733Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:35.733Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:35.735Z daemon INFO Daemon is now listening on 127.0.0.1:59353
{"IP":"127.0.0.1","Port":"59353"}
2024-05-19T05:12:35.743Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.744Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.744Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.796Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.816Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59354
{"IP":"127.0.0.1","Port":"59354"}
2024-05-19T05:12:35.821Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.821Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.821Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:35.861Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:35.879Z daemon INFO time="2024-05-19T14:12:35+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:35.881Z daemon INFO Daemon is now listening on 127.0.0.1:59355
{"IP":"127.0.0.1","Port":"59355"}
2024-05-19T05:12:35.949Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.949Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:35.949Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.062Z daemon INFO time="2024-05-19T14:12:35+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.062Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-19T14:12:36+09:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-19T14:12:36+09:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:59357
{"IP":"127.0.0.1","Port":"59357"}
2024-05-19T05:12:36.062Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.062Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.062Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.150Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.150Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.150Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.150Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.150Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59358
{"IP":"127.0.0.1","Port":"59358"}
2024-05-19T05:12:36.242Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.242Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59361
{"IP":"127.0.0.1","Port":"59361"}
2024-05-19T05:12:36.243Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.243Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.243Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.301Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.325Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.325Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.325Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.335Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59362
{"IP":"127.0.0.1","Port":"59362"}
2024-05-19T05:12:36.376Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.390Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.390Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.390Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.411Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59363
{"IP":"127.0.0.1","Port":"59363"}
2024-05-19T05:12:36.457Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.457Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.457Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.457Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.473Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:36.475Z daemon INFO Daemon is now listening on 127.0.0.1:59364
{"IP":"127.0.0.1","Port":"59364"}
2024-05-19T05:12:36.497Z root INFO Deploy plugins list: 72.3 ms [Finished 2.066 s after backend start]
2024-05-19T05:12:36.530Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.533Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.533Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.533Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.552Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:36.553Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:36.557Z daemon INFO Daemon is now listening on 127.0.0.1:59366
{"IP":"127.0.0.1","Port":"59366"}
2024-05-19T05:12:36.591Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.596Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.596Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.596Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.607Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:36.607Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:36.609Z daemon INFO Daemon is now listening on 127.0.0.1:59367
{"IP":"127.0.0.1","Port":"59367"}
2024-05-19T05:12:36.657Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.658Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.658Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.658Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.674Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:36.675Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="arduino-cli.exe version 0.35.3"
2024-05-19T05:12:36.676Z daemon INFO Daemon is now listening on 127.0.0.1:59368
{"IP":"127.0.0.1","Port":"59368"}
2024-05-19T05:12:36.711Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.721Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.721Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.721Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.730Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59369
{"IP":"127.0.0.1","Port":"59369"}
2024-05-19T05:12:36.773Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.777Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.777Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.777Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.793Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:36.795Z daemon INFO Daemon is now listening on 127.0.0.1:59370
{"IP":"127.0.0.1","Port":"59370"}
2024-05-19T05:12:36.831Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.835Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.835Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.835Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.847Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:36.848Z daemon INFO Daemon is now listening on 127.0.0.1:59371
{"IP":"127.0.0.1","Port":"59371"}
2024-05-19T05:12:36.884Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.895Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.895Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.895Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.905Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59372
{"IP":"127.0.0.1","Port":"59372"}
2024-05-19T05:12:36.956Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:36.964Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.964Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:36.964Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:36.977Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:36.977Z daemon INFO time="2024-05-19T14:12:36+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:36.978Z daemon INFO Daemon is now listening on 127.0.0.1:59373
{"IP":"127.0.0.1","Port":"59373"}
2024-05-19T05:12:37.016Z daemon INFO time="2024-05-19T14:12:36+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.023Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.024Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.024Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
Opening channel for service path '/services/electron-window'.
2024-05-19T05:12:37.035Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-19T14:12:37+09:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-19T14:12:37+09:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:59374
{"IP":"127.0.0.1","Port":"59374"}
2024-05-19T05:12:37.075Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.083Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.083Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.083Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.094Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59375
{"IP":"127.0.0.1","Port":"59375"}
Opening channel for service path '/services/ide-updater'.
2024-05-19T05:12:37.135Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.143Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.143Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.143Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.152Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59376
{"IP":"127.0.0.1","Port":"59376"}
2024-05-19T05:12:37.199Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.218Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.218Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.218Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.242Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:37.245Z daemon INFO Daemon is now listening on 127.0.0.1:59378
{"IP":"127.0.0.1","Port":"59378"}
2024-05-19T05:12:37.293Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.295Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.295Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.296Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.351Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59379
{"IP":"127.0.0.1","Port":"59379"}
2024-05-19T05:12:37.361Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.362Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.362Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.373Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.386Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59380
{"IP":"127.0.0.1","Port":"59380"}
2024-05-19T05:12:37.425Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.429Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.429Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.430Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.446Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 245.6 ms [Finished 2.196 s after frontend start]
2024-05-19T05:12:37.447Z root WARN A command editor.action.toggleStickyScroll is already registered.
2024-05-19T05:12:37.448Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59381
{"IP":"127.0.0.1","Port":"59381"}
2024-05-19T05:12:37.497Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.498Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.498Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.498Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.528Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:37.530Z daemon INFO Daemon is now listening on 127.0.0.1:59383
{"IP":"127.0.0.1","Port":"59383"}
2024-05-19T05:12:37.566Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.573Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.573Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.573Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.591Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59384
{"IP":"127.0.0.1","Port":"59384"}
2024-05-19T05:12:37.643Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.643Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.643Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.656Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.674Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:37.676Z daemon INFO Daemon is now listening on 127.0.0.1:59385
{"IP":"127.0.0.1","Port":"59385"}
2024-05-19T05:12:37.711Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.722Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.722Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.722Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.735Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59386
{"IP":"127.0.0.1","Port":"59386"}
2024-05-19T05:12:37.773Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.781Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.781Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.781Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.791Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59387
{"IP":"127.0.0.1","Port":"59387"}
2024-05-19T05:12:37.829Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.835Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.835Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.835Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.846Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:37.847Z daemon INFO Daemon is now listening on 127.0.0.1:59388
{"IP":"127.0.0.1","Port":"59388"}
2024-05-19T05:12:37.882Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.891Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.891Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.891Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.901Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59389
{"IP":"127.0.0.1","Port":"59389"}
2024-05-19T05:12:37.940Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:37.946Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.946Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:37.946Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:37.957Z daemon INFO time="2024-05-19T14:12:37+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:37.957Z daemon INFO Daemon is now listening on 127.0.0.1:59390
{"IP":"127.0.0.1","Port":"59390"}
2024-05-19T05:12:37.994Z daemon INFO time="2024-05-19T14:12:37+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.002Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.002Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.002Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.012Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-19T14:12:38+09:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-19T14:12:38+09:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:59391
{"IP":"127.0.0.1","Port":"59391"}
2024-05-19T05:12:38.055Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.061Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.061Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.061Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.085Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:38.101Z daemon INFO Daemon is now listening on 127.0.0.1:59392
{"IP":"127.0.0.1","Port":"59392"}
2024-05-19T05:12:38.147Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.162Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.162Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.162Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.172Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59393
{"IP":"127.0.0.1","Port":"59393"}
2024-05-19T05:12:38.210Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.218Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.218Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.218Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.230Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59394
{"IP":"127.0.0.1","Port":"59394"}
2024-05-19T05:12:38.268Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.277Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.278Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.278Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.289Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59395
{"IP":"127.0.0.1","Port":"59395"}
2024-05-19T05:12:38.325Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.336Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.336Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.336Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.346Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59396
{"IP":"127.0.0.1","Port":"59396"}
2024-05-19T05:12:38.382Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.393Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.393Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.393Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.403Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59397
{"IP":"127.0.0.1","Port":"59397"}
2024-05-19T05:12:38.440Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.450Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.450Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.450Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.462Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59398
{"IP":"127.0.0.1","Port":"59398"}
2024-05-19T05:12:38.499Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.510Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.511Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.511Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.522Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59399
{"IP":"127.0.0.1","Port":"59399"}
2024-05-19T05:12:38.575Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.584Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.584Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.584Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.596Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59400
{"IP":"127.0.0.1","Port":"59400"}
2024-05-19T05:12:38.635Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.645Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.645Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.645Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.656Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59401
{"IP":"127.0.0.1","Port":"59401"}
2024-05-19T05:12:38.709Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.716Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.716Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.716Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.727Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:38.728Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:38.729Z daemon INFO Daemon is now listening on 127.0.0.1:59402
{"IP":"127.0.0.1","Port":"59402"}
2024-05-19T05:12:38.779Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.788Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.788Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.788Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.799Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59403
{"IP":"127.0.0.1","Port":"59403"}
2024-05-19T05:12:38.836Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.846Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.846Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.846Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.859Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59404
{"IP":"127.0.0.1","Port":"59404"}
2024-05-19T05:12:38.896Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.907Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.907Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.907Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.918Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59405
{"IP":"127.0.0.1","Port":"59405"}
2024-05-19T05:12:38.957Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:38.964Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.964Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:38.964Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:38.976Z daemon INFO time="2024-05-19T14:12:38+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59406
{"IP":"127.0.0.1","Port":"59406"}
2024-05-19T05:12:39.012Z daemon INFO time="2024-05-19T14:12:38+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.023Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.023Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.023Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.033Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-19T14:12:39+09:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-19T14:12:39+09:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:59407
{"IP":"127.0.0.1","Port":"59407"}
2024-05-19T05:12:39.071Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.079Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.079Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.079Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.092Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59408
{"IP":"127.0.0.1","Port":"59408"}
2024-05-19T05:12:39.132Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.139Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.139Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.139Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.150Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59409
{"IP":"127.0.0.1","Port":"59409"}
2024-05-19T05:12:39.188Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.199Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.199Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.199Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.236Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59410
{"IP":"127.0.0.1","Port":"59410"}
2024-05-19T05:12:39.306Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.313Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.313Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.313Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.325Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59411
{"IP":"127.0.0.1","Port":"59411"}
2024-05-19T05:12:39.362Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.370Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.370Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.370Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.381Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:39.381Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:39.383Z daemon INFO Daemon is now listening on 127.0.0.1:59412
{"IP":"127.0.0.1","Port":"59412"}
2024-05-19T05:12:39.432Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.442Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.443Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.443Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.453Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:39.453Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:39.468Z daemon INFO Daemon is now listening on 127.0.0.1:59413
{"IP":"127.0.0.1","Port":"59413"}
2024-05-19T05:12:39.513Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.518Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.518Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.518Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.533Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:39.533Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:39.534Z daemon INFO Daemon is now listening on 127.0.0.1:59414
{"IP":"127.0.0.1","Port":"59414"}
2024-05-19T05:12:39.569Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.592Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.592Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.592Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.602Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59415
{"IP":"127.0.0.1","Port":"59415"}
2024-05-19T05:12:39.645Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.651Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.651Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.651Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.664Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:39.675Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:39.676Z daemon INFO Daemon is now listening on 127.0.0.1:59416
{"IP":"127.0.0.1","Port":"59416"}
2024-05-19T05:12:39.704Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.718Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.718Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.718Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.730Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59417
{"IP":"127.0.0.1","Port":"59417"}
2024-05-19T05:12:39.794Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.801Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.801Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.801Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.813Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59418
{"IP":"127.0.0.1","Port":"59418"}
2024-05-19T05:12:39.849Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.860Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.860Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.860Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.871Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59419
{"IP":"127.0.0.1","Port":"59419"}
2024-05-19T05:12:39.908Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.918Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.918Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.918Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.929Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59420
{"IP":"127.0.0.1","Port":"59420"}
2024-05-19T05:12:39.970Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:39.977Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.977Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:39.977Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:39.989Z daemon INFO time="2024-05-19T14:12:39+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:39.991Z daemon INFO Daemon is now listening on 127.0.0.1:59421
{"IP":"127.0.0.1","Port":"59421"}
2024-05-19T05:12:40.025Z daemon INFO time="2024-05-19T14:12:39+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.045Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
time="2024-05-19T14:12:40+09:00" level=info msg="arduino-cli.exe version 0.35.3"
time="2024-05-19T14:12:40+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:40.047Z daemon INFO Daemon is now listening on 127.0.0.1:59422
{"IP":"127.0.0.1","Port":"59422"}
2024-05-19T05:12:40.048Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.049Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.049Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.130Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.140Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.140Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.140Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.154Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:40.156Z daemon INFO Daemon is now listening on 127.0.0.1:59423
{"IP":"127.0.0.1","Port":"59423"}
2024-05-19T05:12:40.201Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.204Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.204Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
    at Socket.<anonymous> (C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\main.js:2:43051)
    at Socket.emit (node:events:514:28)
    at addChunk (node:internal/streams/readable:324:12)
    at readableAddChunk (node:internal/streams/readable:297:9)
    at Socket.push (node:internal/streams/readable:234:10)
    at Pipe.onStreamRead (node:internal/stream_base_commons:190:23)
2024-05-19T05:12:40.204Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.220Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:40.220Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Executing `arduino-cli daemon`"
2024-05-19T05:12:40.222Z daemon INFO Daemon is now listening on 127.0.0.1:59424
{"IP":"127.0.0.1","Port":"59424"}
2024-05-19T05:12:40.255Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.261Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.261Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.261Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.273Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:40.275Z daemon INFO Daemon is now listening on 127.0.0.1:59425
{"IP":"127.0.0.1","Port":"59425"}
2024-05-19T05:12:40.310Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.318Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.318Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.318Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.329Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59426
{"IP":"127.0.0.1","Port":"59426"}
2024-05-19T05:12:40.363Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.372Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.372Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.372Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.382Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59427
{"IP":"127.0.0.1","Port":"59427"}
2024-05-19T05:12:40.419Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.435Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
2024-05-19T05:12:40.437Z daemon INFO Daemon is now listening on 127.0.0.1:59428
{"IP":"127.0.0.1","Port":"59428"}
2024-05-19T05:12:40.437Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.437Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.437Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.483Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.494Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.494Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.494Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.505Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59429
{"IP":"127.0.0.1","Port":"59429"}
2024-05-19T05:12:40.539Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.552Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.552Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.552Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.563Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59430
{"IP":"127.0.0.1","Port":"59430"}
2024-05-19T05:12:40.597Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.607Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.607Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.607Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.620Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59431
{"IP":"127.0.0.1","Port":"59431"}
2024-05-19T05:12:40.655Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.668Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.668Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.668Z daemon INFO Starting daemon from C:\Users\JBY\AppData\Local\Programs\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-05-19T05:12:40.679Z daemon INFO time="2024-05-19T14:12:40+09:00" level=info msg="Using config file: c:\\Users\\JBY\\.arduinoIDE\\arduino-cli.yaml"
Daemon is now listening on 127.0.0.1:59432
{"IP":"127.0.0.1","Port":"59432"}
2024-05-19T05:12:40.726Z daemon INFO time="2024-05-19T14:12:40+09:00" level=warning msg="Unable to get Documents Folder: The system cannot find the path specified."
2024-05-19T05:12:40.738Z daemon INFO Unable to get Documents Folder: The system cannot find the path specified.
2024-05-19T05:12:40.738Z daemon ERROR Error: Unable to get Documents Folder: The system cannot find the path specified.
Hi @jbjby.
On startup, Arduino IDE queries the Windows operating system for the location of your user "Documents" folder. The reason Arduino IDE is not starting is because when it makes this query Windows responds that the "Documents" folder doesn't exist. Since that folder should always exist, the IDE fails to start with this "Unable to get Documents Folder: ..." error.
Traditionally, the default location of the "Documents" folder was a path with this format:
C:\Users\<username>\Documents
(where <username> is your Windows username)
Although that is the default, it is possible to customize the location of this folder. If the location was changed to a drive that is not accessible (e.g., a USB drive that is unplugged), that could cause the "Unable to get Documents Folder: ..." error.
If you have the Windows "OneDrive folder syncing" feature enabled, the "Documents" folder is located under the OneDrive storage by default, at a path with this format:
C:\Users\<username>\OneDrive\Documents
(where the name of the Documents folder might actually be the localized equivalent)
It is also possible the folder could be located on alternative cloud storage providers (e.g., Dropbox.
When other users reported encountering this "Unable to get Documents Folder: ..." error, we often found that the problem was caused by them having disabled OneDrive in some manner, or else by them not having a connection to the OneDrive service.
Can you think of anything unusual about your system that might cause Arduino IDE to not be able to access your "Documents" folder?
Thank you for answering my question promptly. I really appreciate it.
