After I translate:
A simple PioSPI sample from
I got the following errors:
loading library from c:\Users\Peter\Documents\Arduino\libraries\arduino-pico-master: invalid library: no header files found
FQBN: rp2040:rp2040:generic
Using board 'generic' from platform in folder: C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2
Using core 'rp2040' from platform in folder: C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2
Detecting libraries used...
C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Generic" -DUSB_PRODUCT="RP2040" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="generic" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 -DBOARD_NAME="GENERIC_RP2040" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\generic C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\sketch_apr16a.ino.cpp -o nul
Alternatives for PioSPI.h: [PioSPI@0.0.1]
ResolveLibrary(PioSPI.h)
-> candidates: [PioSPI@0.0.1]
C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Generic" -DUSB_PRODUCT="RP2040" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="generic" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 -DBOARD_NAME="GENERIC_RP2040" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\generic -Ic:\Users\Peter\Documents\Arduino\libraries\PioSPI\src C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\sketch_apr16a.ino.cpp -o nul
C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Generic" -DUSB_PRODUCT="RP2040" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="generic" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 -DBOARD_NAME="GENERIC_RP2040" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\generic -Ic:\Users\Peter\Documents\Arduino\libraries\PioSPI\src C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\PioSPI.cpp -o nul
C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Generic" -DUSB_PRODUCT="RP2040" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="generic" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 -DBOARD_NAME="GENERIC_RP2040" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\generic -Ic:\Users\Peter\Documents\Arduino\libraries\PioSPI\src c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp -o nul
C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Generic" -DUSB_PRODUCT="RP2040" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="generic" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 -DBOARD_NAME="GENERIC_RP2040" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\generic -Ic:\Users\Peter\Documents\Arduino\libraries\PioSPI\src c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\pio_spi.c -o nul
Generating function prototypes...
C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\tools\pqt-gcc\2.2.0-d04e724/bin/arm-none-eabi-g++ -I C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B/core -c -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 -DUSB_MANUFACTURER="Generic" -DUSB_PRODUCT="RP2040" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 -DARDUINO_VARIANT="generic" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -iprefixC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/ @C:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/lib/platform_inc.txt -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2/include -fno-rtti -std=gnu++17 -g -pipe -w -x c++ -E -CC -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 -DBOARD_NAME="GENERIC_RP2040" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\cores\rp2040 -IC:\Users\Peter\AppData\Local\Arduino15\packages\rp2040\hardware\rp2040\3.7.2\variants\generic -Ic:\Users\Peter\Documents\Arduino\libraries\PioSPI\src C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\sketch_apr16a.ino.cpp -o C:\Users\Peter\AppData\Local\Temp\4275155358\sketch_merged.cpp
C:\Users\Peter\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\Peter\AppData\Local\Temp\4275155358\sketch_merged.cpp
Compiling sketch...
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-python3\\1.0.1-base-3a57aed/python3" -I "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/tools/signing.py" --mode header --publickey "C:\\Users\\Peter\\Documents\\Arduino\\sketch_apr16a/public.key" --out "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core/Updater_Signing.h"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "-Ic:\\Users\\Peter\\Documents\\Arduino\\libraries\\PioSPI\\src" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\sketch\\PioSPI.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\sketch\\PioSPI.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "-Ic:\\Users\\Peter\\Documents\\Arduino\\libraries\\PioSPI\\src" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\sketch\\sketch_apr16a.ino.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\sketch\\sketch_apr16a.ino.cpp.o"
Compiling libraries...
C:\Users\Peter\Documents\Arduino\sketch_apr16a\PioSPI.cpp: In constructor 'PioSPI::PioSPI(pin_size_t, pin_size_t, pin_size_t, pin_size_t, uint8_t, uint32_t)':
C:\Users\Peter\Documents\Arduino\sketch_apr16a\PioSPI.cpp:50:21: warning: format '%u' expects argument of type 'unsigned int', but argument 3 has type 'uint32_t' {aka 'long unsigned int'} [-Wformat=]
50 | ERRORPIOSPI("Set frequency too high, falling back to maximum %u Hz \n", _ck_freq);
| uint32_t {aka long unsigned int}
C:\Users\Peter\Documents\Arduino\sketch_apr16a\PioSPI.cpp:31:50: note: in definition of macro 'ERRORPIOSPI'
31 | #define ERRORPIOSPI(fmt, ...) do { Serial.printf(fmt, ## __VA_ARGS__); Serial.flush();} while (0)
C:\Users\Peter\Documents\Arduino\sketch_apr16a\PioSPI.cpp: In member function 'virtual void PioSPI::beginTransaction(arduino::SPISettings)':
C:\Users\Peter\Documents\Arduino\sketch_apr16a\PioSPI.cpp:189:25: warning: format '%u' expects argument of type 'unsigned int', but argument 3 has type 'uint32_t' {aka 'long unsigned int'} [-Wformat=]
189 | ERRORPIOSPI("Set frequency too high, falling back to maximum %u Hz \n", _ck_freq);
Compiling library "PioSPI"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-gcc" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -std=gnu17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "-Ic:\\Users\\Peter\\Documents\\Arduino\\libraries\\PioSPI\\src" "c:\\Users\\Peter\\Documents\\Arduino\\libraries\\PioSPI\\src\\pio_spi.c" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\libraries\\PioSPI\\pio_spi.c.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "-Ic:\\Users\\Peter\\Documents\\Arduino\\libraries\\PioSPI\\src" "c:\\Users\\Peter\\Documents\\Arduino\\libraries\\PioSPI\\src\\PioSPI.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\libraries\\PioSPI\\PioSPI.cpp.o"
c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp: In constructor 'PioSPI::PioSPI(pin_size_t, pin_size_t, pin_size_t, pin_size_t, uint8_t, uint32_t)':
c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp:50:21: warning: format '%u' expects argument of type 'unsigned int', but argument 3 has type 'uint32_t' {aka 'long unsigned int'} [-Wformat=]
c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp:31:50: note: in definition of macro 'ERRORPIOSPI'
c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp:50:71: note: format string is defined here
| unsigned int
| %lu
c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp: In member function 'virtual void PioSPI::beginTransaction(arduino::SPISettings)':
c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp:189:25: warning: format '%u' expects argument of type 'unsigned int', but argument 3 has type 'uint32_t' {aka 'long unsigned int'} [-Wformat=]
c:\Users\Peter\Documents\Arduino\libraries\PioSPI\src\PioSPI.cpp:189:75: note: format string is defined here
| unsigned int
| %lu
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\libraries\\PioSPI\\PioSPI.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\libraries\\PioSPI\\PioSPI.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\libraries\\PioSPI\\PioSPI.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\libraries\\PioSPI\\pio_spi.c.o"
Compiling core...
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\Bootsel.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\Bootsel.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\FS.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\FS.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\BluetoothDebug.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\BluetoothDebug.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\CoreMutex.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\CoreMutex.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\PIOProgram.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\PIOProgram.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\RP2040Support.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\RP2040Support.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\RP2040USB.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\RP2040USB.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\SerialPIO.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\SerialPIO.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\SerialUART.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\SerialUART.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\SerialUSB.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\SerialUSB.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\StackThunk.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\StackThunk.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\Tone.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\Tone.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\WMath.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\WMath.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\_freertos.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\_freertos.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\api\\Common.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\Common.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\api\\IPAddress.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\IPAddress.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\api\\PluggableUSB.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\PluggableUSB.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\api\\Print.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\Print.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\api\\Stream.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\Stream.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\api\\String.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\String.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\cyw43_wrappers.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\cyw43_wrappers.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\delay.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\delay.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\libb64\\cdecode.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\libb64\\cdecode.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\libb64\\cencode.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\libb64\\cencode.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\lock.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\lock.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\lwip_wrap.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\lwip_wrap.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\main.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\main.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\malloc-lock.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\malloc-lock.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\posix.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\posix.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-gcc" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -std=gnu17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\sdkoverride\\att_db.c" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\att_db.c.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\sdkoverride\\btstack_flash_bank.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\btstack_flash_bank.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-gcc" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -std=gnu17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\sdkoverride\\hids_device.c" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\hids_device.c.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-gcc" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -std=gnu17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\sdkoverride\\pico_bootsel_via_double_reset.c" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\pico_bootsel_via_double_reset.c.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\wiring_analog.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_analog.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\stdlib_noniso.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\stdlib_noniso.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\wiring_digital.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_digital.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\wiring_private.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_private.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\wiring_pulse.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_pulse.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" -I "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core" -c -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -MMD "-iprefixC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/" "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_inc.txt" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/include" -fno-rtti -std=gnu++17 -g -pipe -DF_CPU=133000000L -DARDUINO=10607 -DARDUINO_GENERIC_RP2040 "-DBOARD_NAME=\"GENERIC_RP2040\"" -DARDUINO_ARCH_RP2040 -Os -DWIFICC=CYW43_COUNTRY_WORLDWIDE "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\variants\\generic" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2\\cores\\rp2040\\wiring_shift.cpp" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_shift.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\BluetoothDebug.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\Bootsel.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\CoreMutex.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\FS.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\PIOProgram.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\RP2040Support.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\RP2040USB.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\SerialPIO.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\SerialUART.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\SerialUSB.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\StackThunk.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\Tone.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\WMath.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\_freertos.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\Common.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\IPAddress.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\PluggableUSB.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\Print.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\Stream.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\api\\String.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\cyw43_wrappers.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\delay.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\libb64\\cdecode.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\libb64\\cencode.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\lock.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\lwip_wrap.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\main.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\malloc-lock.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\posix.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\att_db.c.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\btstack_flash_bank.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\hids_device.c.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\sdkoverride\\pico_bootsel_via_double_reset.c.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\stdlib_noniso.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_analog.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_digital.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_private.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_pulse.cpp.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-ar" rcs "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\core\\wiring_shift.cpp.o"
Archiving built core (caching) in: C:\Users\Peter\AppData\Local\Temp\arduino\cores\cb0d9cf03086a66c48df4b4e9edb066f\core.a
Linking everything together...
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-python3\\1.0.1-base-3a57aed/python3" -I "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/tools/simplesub.py" --input "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/memmap_default.ld" --out "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/memmap_default.ld" --sub __FLASH_LENGTH__ 2093056 --sub __EEPROM_START__ 270528512 --sub __FS_START__ 270528512 --sub __FS_END__ 270528512 --sub __RAM_LENGTH__ 256k
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-gcc" -Werror=return-type -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -Os -u _printf_float -u _scanf_float -c "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/boot2/boot2_generic_03h_2_padded_checksum.S" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/pico-sdk/src/rp2040/hardware_regs/include/" "-IC:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/pico-sdk/src/common/pico_binary_info/include" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/boot2.o"
"C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\tools\\pqt-gcc\\2.2.0-d04e724/bin/arm-none-eabi-g++" "-LC:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B" -Wall -Wextra -Werror=return-type -Wno-ignored-qualifiers -Wno-psabi -DCFG_TUSB_MCU=OPT_MCU_RP2040 -DUSBD_PID=0xf00a -DUSBD_VID=0x2e8a -DUSBD_MAX_POWER_MA=250 "-DUSB_MANUFACTURER=\"Generic\"" "-DUSB_PRODUCT=\"RP2040\"" -DPICO_CYW43_ARCH_THREADSAFE_BACKGROUND=1 -DCYW43_LWIP=1 -DLWIP_IPV6=0 -DLWIP_IPV4=1 -DLWIP_IGMP=1 -DLWIP_CHECKSUM_CTRL_PER_NETIF=1 "-DARDUINO_VARIANT=\"generic\"" -DTARGET_RP2040 -DPICO_FLASH_SIZE_BYTES=2097152 -march=armv6-m -mcpu=cortex-m0plus -mthumb -ffunction-sections -fdata-sections -fno-exceptions -DARM_MATH_CM0_FAMILY -DARM_MATH_CM0_PLUS -Os -u _printf_float -u _scanf_float "@C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/platform_wrap.txt" -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common "-Wl,--script=C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/memmap_default.ld" "-Wl,-Map,C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/sketch_apr16a.ino.map" -o "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/sketch_apr16a.ino.elf" -Wl,--no-warn-rwx-segments -Wl,--start-group "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\sketch\\PioSPI.cpp.o" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\sketch\\sketch_apr16a.ino.cpp.o" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B\\libraries\\PioSPI\\PioSPI.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/core\\core.a" "C:\\Users\\Peter\\AppData\\Local\\Temp\\arduino\\sketches\\CDDA6CA21E1CABBA5F0E9634CFA8956B/boot2.o" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/ota.o" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/libpico.a" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/libpicow-noipv6-nobtc-noble.a" "C:\\Users\\Peter\\AppData\\Local\\Arduino15\\packages\\rp2040\\hardware\\rp2040\\3.7.2/lib/libbearssl.a" -lm -lc -lstdc++ -lc -Wl,--end-group
c:/users/peter/appdata/local/arduino15/packages/rp2040/tools/pqt-gcc/2.2.0-d04e724/bin/../lib/gcc/arm-none-eabi/12.3.0/../../../../arm-none-eabi/bin/ld.exe: C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\PioSPI.cpp.o:(.rodata._ZTV6PioSPI+0x20): undefined reference to `_ZN6PioSPI14usingInterruptEi'
c:/users/peter/appdata/local/arduino15/packages/rp2040/tools/pqt-gcc/2.2.0-d04e724/bin/../lib/gcc/arm-none-eabi/12.3.0/../../../../arm-none-eabi/bin/ld.exe: C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\PioSPI.cpp.o:(.rodata._ZTV6PioSPI+0x24): undefined reference to `_ZN6PioSPI17notUsingInterruptEi'
c:/users/peter/appdata/local/arduino15/packages/rp2040/tools/pqt-gcc/2.2.0-d04e724/bin/../lib/gcc/arm-none-eabi/12.3.0/../../../../arm-none-eabi/bin/ld.exe: C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\PioSPI.cpp.o:(.rodata._ZTV6PioSPI+0x30): undefined reference to `_ZN6PioSPI15attachInterruptEv'
c:/users/peter/appdata/local/arduino15/packages/rp2040/tools/pqt-gcc/2.2.0-d04e724/bin/../lib/gcc/arm-none-eabi/12.3.0/../../../../arm-none-eabi/bin/ld.exe: C:\Users\Peter\AppData\Local\Temp\arduino\sketches\CDDA6CA21E1CABBA5F0E9634CFA8956B\sketch\PioSPI.cpp.o:(.rodata._ZTV6PioSPI+0x34): undefined reference to `_ZN6PioSPI15detachInterruptEv'
collect2.exe: error: ld returned 1 exit status
Using library PioSPI at version 0.0.1 in folder: C:\Users\Peter\Documents\Arduino\libraries\PioSPI
exit status 1
Compilation error: exit status 1
Could anybody help me what a hell is that?
