Arduino ide 2.3.2 going crazy over int and variables
i'm making myself a lcd (rgb backlight so i have variables for each color) soundboard with buttons, and the IDE keeps spitting a crazy error:
'expected initializer before setGint'
but the line it's pointing at is:
"int setG //green set or not"
and it also goes crazy on another line:
if(setB >= 1 and setG >= 1 and setRed >= 1){ <---- this one int colorSet = 1; }
giving this error:
setuid
exit status 1
here's my full code:
i'm very bad at coding so there will be many errors, but i'm only concerned about it going off on those two lines
//#include <Wire.h>
//#include <LiquidCrystal_I2C.h>
#define botao1 13
#define R 33
#define G 32
#define blue 35
int pot  //0 through 255 pot value
int setB  //blue set or not
int setRed  //red or not
int colorSet  //all colors set or not
  pinMode(13, INPUT); //b1
  pinMode(12, INPUT); //b2
  pinMode(23, INPUT); //b3
  pinMode(14, INPUT); //b4
  pinMode(27, INPUT); //b5
  pinMode(26, INPUT); //b6
  //LiquidCrystal_I2C lcd(0x3F, 16, 2); // LCD I2C, 16 by 2
  pinMode(34, INPUT); //Pot
  pinMode(33, OUTPUT); //red
  pinMode(32, OUTPUT); //green
  pinMode(35, OUTPUT); //blue
  //lcd.backlight();  // backlight
  //lcd.cursor_off(); // turns off the blinking block of the cursor
  if(colorSet < 1){
    int pot = (map(34, 0, 4096, 0, 255));
    //lcd.setCursor(6, 1);
    //lcd.print("Red:");
    //lcd.print(6, 2);
    //lcd.print(pot);
    if(digitalRead(botao1 == HIGH)){
    analogWrite(R, pot);
  int setR = 1
  if(int setRed >= 1){
    //lcd.print("Green:");
    //lcd.setCursor(6, 2);
    //lcd.print(pot);
    if(int setRed = 1 and digitalRead(botao1) == HIGH){
    analogWrite(G, pot);
    int setG = 1;
    if(int setG >= 1){
    //lcd.print("Blue:");
    //lcd.print(pot);
    if(int setG >= 1 and digitalRead(botao1 == HIGH)){
      analogWrite(blue, pot);
      int setB = 1;
    int colorSet = 1;
  if(int colorSet = 1){
    Serial.available();
    Serial.println("0");
    if(Serial.read() == 10){
      //lcd.setCursor(3, 1);
      //lcd.print("Connected!");
Welcome to the forum
Multiple missing semicolons
oh thanks! i just added the semicolons and it worked just fine!
