Hi - this is a follow-on from Arduino IDE 2.3.2 blank window after linux os update (closed).
Previously IDE 2.3.1 was fine on my openSUSE Leap 15.5 machine, but after a recent OS update, neither 2.3.1 nor 2.3.3 will initialise properly: as per the 1238705 post, I get a blank window along with a mass of error messages on the Konsole (see below). Deleting .config/arduino-ide does NOT resolve the problem on my machine. Today's set of openSUSE updates including chromium updates, but the problem is still not resolved - see below for error messages.
Hope you can resolve this problem quickly - let me know if you need more details, screenshots, etc.
Thanks!
Info details:
Operating System: openSUSE Leap 15.5
KDE Plasma Version: 5.27.9
KDE Frameworks Version: 5.103.0
Qt Version: 5.15.8
Kernel Version: 5.14.21-150500.55.83-default (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i5-4210M CPU @ 2.60GHz
Memory: 7.7 GiB of RAM
Graphics Processor: Mesa Intel® HD Graphics 4600
Manufacturer: Dell Inc.
Product Name: Precision M2800
System Version: 01
Error message details (just the top of a very long file):
// Fragment GLSL
#version 300 es
#extension GL_NV_shader_noperspective_interpolation : require
precision mediump float;
precision mediump sampler2D;
out mediump vec4 sk_FragColor;
flat in mediump vec4 vcolor_S0;
void main() {
mediump vec4 outputColor_S0 = vcolor_S0;
sk_FragColor = outputColor_S0;
Errors:
link failed but did not provide an info log
[3891:1014/134816.981429:ERROR:shared_context_state.cc(98)] Skia shader compilation error
// Vertex SKSL
#extension GL_NV_shader_noperspective_interpolation: require
uniform float4 sk_RTAdjust;in float2 position;in float2 localCoord;noperspective out float2 vlocalCoord_S0;void main() {// Primitive Processor QuadPerEdgeAAGeometryProcessor
vlocalCoord_S0 = localCoord;sk_Position = position.xy01;}
// Fragment SKSL
sampler2D uTextureSampler_0_S0;
noperspective in float2 vlocalCoord_S0;void main() {// Stage 0, QuadPerEdgeAAGeometryProcessor
half4 outputColor_S0 = half4(1);float2 texCoord;texCoord = vlocalCoord_S0;outputColor_S0 = (blend_modulate(sample(uTextureSampler_0_S0, texCoord), half4(1)));const half4 outputCoverage_S0 = half4(1);{ // Xfer Processor: Porter Duff
sk_FragColor = outputColor_S0 * outputCoverage_S0;}}
// Vertex GLSL
#version 300 es
uniform highp vec4 sk_RTAdjust;
in highp vec2 position;
in highp vec2 localCoord;
noperspective out highp vec2 vlocalCoord_S0;
void main() {
gl_Position = vec4(position, 0.0, 1.0);
gl_Position = vec4(gl_Position.xy * sk_RTAdjust.xz + gl_Position.ww * sk_RTAdjust.yw, 0.0, gl_Position.w);
IDE startup chatter (redacted for privacy):
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: /tmp/.mount_arduindvifby/resources/app/lib/backend/electron-main.js, destination 'package.json': /tmp/.mount_arduindvifby/resources/app/package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:35:36.309Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:35:36.309Z"}
Starting backend process. PID: 3900
Configuration directory URI: 'file:///home/<user>/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-14T12:47:55.099Z root INFO Backend Object.initialize: 7.9 ms [Finished 0.696 s after backend start]
2024-10-14T12:47:55.105Z root INFO Backend Object.configure: 6.8 ms [Finished 0.696 s after backend start]
2024-10-14T12:47:55.105Z root INFO Backend a.onStart: 2.2 ms [Finished 0.696 s after backend start]
2024-10-14T12:47:55.106Z root INFO Backend a.configure: 0.4 ms [Finished 0.724 s after backend start]
2024-10-14T12:47:55.107Z root INFO Backend d.onStart: 0.2 ms [Finished 0.724 s after backend start]
2024-10-14T12:47:55.108Z root INFO Backend d.configure: 0.1 ms [Finished 0.724 s after backend start]
2024-10-14T12:47:55.109Z root INFO Backend d.initialize: 27.5 ms [Finished 0.724 s after backend start]
2024-10-14T12:47:55.109Z root INFO Backend c.onStart: 0.3 ms [Finished 0.724 s after backend start]
2024-10-14T12:47:55.109Z root INFO Backend s.configure: 6.4 ms [Finished 0.731 s after backend start]
2024-10-14T12:47:55.111Z config INFO >>> Initializing CLI configuration...
2024-10-14T12:47:55.111Z root INFO Backend c.initialize: 0.9 ms [Finished 0.731 s after backend start]
2024-10-14T12:47:55.111Z root INFO Backend x.onStart: 1.0 ms [Finished 0.732 s after backend start]
2024-10-14T12:47:55.112Z config INFO Loading CLI configuration from /home/<user>/.arduinoIDE/arduino-cli.yaml...
2024-10-14T12:47:55.113Z daemon INFO Starting daemon from /tmp/.mount_arduindvifby/resources/app/lib/backend/resources/arduino-cli...
2024-10-14T12:47:55.113Z root INFO Backend s.initialize: 0.6 ms [Finished 0.733 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend w.onStart: 1.4 ms [Finished 0.734 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend r.configure: 2.2 ms [Finished 0.734 s after backend start]
2024-10-14T12:47:55.113Z discovery-log INFO start
2024-10-14T12:47:55.113Z discovery-log INFO start new deferred
2024-10-14T12:47:55.113Z root INFO Backend d.initialize: 0.5 ms [Finished 0.734 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend y.onStart: 2.1 ms [Finished 0.736 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend r.configure: 1.7 ms [Finished 0.736 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend s.onStart: 0.7 ms [Finished 0.738 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend h.configure: 0.6 ms [Finished 0.738 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend a.configure: 0.2 ms [Finished 0.738 s after backend start]
2024-10-14T12:47:55.113Z root INFO Backend l.configure: 0.1 ms [Finished 0.738 s after backend start]
2024-10-14T12:47:55.116Z root INFO Theia app listening on http://127.0.0.1:41711.
2024-10-14T12:47:55.116Z root INFO Finished starting backend application: 3.2 ms [Finished 0.741 s after backend start]
2024-10-14T12:47:55.122Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]},"build_cache":{"compilations_before_purge":10,"ttl":"720h0m0s"},"daemon":{"port":"50051"},"directories":{"data":"/home/<user>/.arduino15","downloads":"/home/<user>/.arduino15/staging","user":"/home/<user>/Arduino"},"library":{"enable_unsafe_install":false},"logging":{"file":"","format":"text","level":"info"},"metrics":{"addr":":9090","enabled":true},"output":{"no_color":false},"sketch":{"always_export_binaries":false},"updater":{"enable_notification":true}}
2024-10-14T12:47:55.122Z config INFO 'directories.data' and 'directories.user' are set in the CLI configuration model.
2024-10-14T12:47:55.122Z config INFO Loaded the CLI configuration.
Restoring workspace roots: /home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1
isTempSketch: false. Input was /home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1/<AppName>_<user>_Hack1.ino
2024-10-14T12:47:55.214Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///home/<user>/.arduino15","sketchDirUri":"file:///home/<user>/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-10-14T12:47:55.214Z config INFO Validating the CLI configuration...
2024-10-14T12:47:55.214Z config INFO The CLI config is valid.
2024-10-14T12:47:55.214Z config INFO <<< Initialized the CLI configuration.
2024-10-14T12:47:55.388Z daemon INFO time="2024-10-14T13:47:55+01:00" level=info msg="arduino-cli version 1.0.4"
time="2024-10-14T13:47:55+01:00" level=info msg="Using config file: /home/<user>/.arduinoIDE/arduino-cli.yaml"
time="2024-10-14T13:47:55+01:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:42989
{"IP":"127.0.0.1","Port":"42989"}
2024-10-14T12:47:55.388Z daemon INFO Daemon is running.
2024-10-14T12:47:55.438Z daemon INFO time="2024-10-14T13:47:55+01:00" level=info msg="Checking signature" index=/home/<user>/.arduino15/package_index.json signatureFile=/home/<user>/.arduino15/package_index.json.sig trusted=true
2024-10-14T12:47:55.439Z daemon INFO time="2024-10-14T13:47:55+01:00" level=info msg="Loading hardware from: /home/<user>/.arduino15/packages"
time="2024-10-14T13:47:55+01:00" level=info msg="Loading package arduino from: /home/<user>/.arduino15/packages/arduino/hardware"
2024-10-14T12:47:55.441Z root INFO Resolve plugins list: 328.9 ms [Finished 1.065 s after backend start]
2024-10-14T12:47:55.441Z daemon INFO time="2024-10-14T13:47:55+01:00" level=info msg="Missing signature file" index=/home/<user>/.arduino15/packages/arduino/hardware/avr/1.8.6/installed.json
2024-10-14T12:47:55.452Z daemon INFO time="2024-10-14T13:47:55+01:00" level=info msg="Adding monitor tool" protocol=serial tool="builtin:serial-monitor"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded platform" platform="arduino:avr@1.8.6"
time="2024-10-14T13:47:55+01:00" level=info msg="Checking existence of 'tools' path: /home/<user>/.arduino15/packages/arduino/tools"
time="2024-10-14T13:47:55+01:00" level=info msg="Loading tools from dir: /home/<user>/.arduino15/packages/arduino/tools"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="arduino:arduinoOTA@1.3.0"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-10-14T13:47:55+01:00" level=info msg="Loading package builtin from: /home/<user>/.arduino15/packages/builtin"
time="2024-10-14T13:47:55+01:00" level=info msg="Checking existence of 'tools' path: /home/<user>/.arduino15/packages/builtin/tools"
time="2024-10-14T13:47:55+01:00" level=info msg="Loading tools from dir: /home/<user>/.arduino15/packages/builtin/tools"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="builtin:ctags@5.8-arduino11"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="builtin:dfu-discovery@0.1.2"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="builtin:mdns-discovery@1.0.9"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.0"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="builtin:serial-discovery@1.4.1"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.13.0"
time="2024-10-14T13:47:55+01:00" level=info msg="Loaded tool" tool="builtin:serial-monitor@0.14.1"
time="2024-10-14T13:47:55+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/.arduino15/packages/arduino/hardware/avr/1.8.6/libraries isSingleLibrary=false location=platform
time="2024-10-14T13:47:55+01:00" level=info msg="Loading libraries index file" index=/home/<user>/.arduino15/library_index.json
2024-10-14T12:47:55.758Z daemon INFO time="2024-10-14T13:47:55+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/.arduino15/libraries isSingleLibrary=false location=ide
time="2024-10-14T13:47:55+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/Arduino/libraries isSingleLibrary=false location=user
2024-10-14T12:47:55.761Z discovery-log INFO start resolved watching
2024-10-14T12:47:56.989Z root INFO Deploy plugins list: 328.9 ms [Finished 2.614 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-10-14T12:47:58.264Z root INFO Start frontend contributions: 718.0 ms [Finished 2.902 s after frontend start]
2024-10-14T12:47:58.265Z root INFO Changed application state from 'init' to 'started_contributions'.
2024-10-14T12:47:58.303Z root INFO Changed application state from 'started_contributions' to 'attached_shell'.
2024-10-14T12:47:58.304Z root INFO >>> Restoring the layout state...
2024-10-14T12:47:58.306Z root INFO ------- SERIALIZED LAYOUT DATA -------
2024-10-14T12:47:58.306Z root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1/<AppName>_<user>_Hack1.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":277,\"column\":8},\"position\":{\"lineNumber\":277,\"column\":8}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":277,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":533,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":1}},"pinned":[false,false],"size":233,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:threads\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:frames\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:variables\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:watch\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"debug:breakpoints\"},\"innerWidgetState\":\"{}\"}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"includeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"excludeHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}]},"rightPanel":{"type":"sidepanel","items":[]}}
2024-10-14T12:47:58.308Z root INFO ------- END SERIALIZED LAYOUT DATA -------
2024-10-14T12:47:58.389Z root INFO [5914059d-b5f5-4dc3-86b4-84e18aa87f7c] Waiting for backend deployment: 180.2 ms [Finished 3.071 s after frontend start]
2024-10-14T12:47:59.449Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981) starting instance
2024-10-14T12:48:00.134Z root INFO [5914059d-b5f5-4dc3-86b4-84e18aa87f7c] Sync of 23 plugins: 1751.4 ms [Finished 4.822 s after frontend start]
2024-10-14T12:48:00.429Z root INFO <<< The layout has been successfully restored.
2024-10-14T12:48:00.535Z root INFO Initialize the workbench layout: 2140.6 ms [Finished 5.115 s after frontend start]
2024-10-14T12:48:00.538Z root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
2024-10-14T12:48:00.539Z root INFO [5914059d-b5f5-4dc3-86b4-84e18aa87f7c] Loading plugin contributions
2024-10-14T12:48:00.539Z root INFO [5914059d-b5f5-4dc3-86b4-84e18aa87f7c] Load contributions of 23 plugins: 105.2 ms [Finished 5.222 s after frontend start]
2024-10-14T12:48:01.262Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): PluginManagerExtImpl/init()
2024-10-14T12:48:01.264Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-arduino-api@0.1.2 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.343Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(cortex-debug@1.5.1 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.344Z root INFO [hosted-plugin: 3981] Debugger contribution has been registered: cortex-debug
2024-10-14T12:48:01.346Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-arduino-tools@0.1.3 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.348Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(cpp@1.52.1 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.349Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(json@1.46.1 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.352Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(json-language-features@1.46.1 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.354Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-bg@1.48.3 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.355Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-cs@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.356Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-de@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.358Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-es@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.359Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-fr@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.360Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-hu@1.48.3 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.361Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-it@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.361Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-ja@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.362Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-ko@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.363Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-nl@1.48.3 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.363Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-pl@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.364Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-pt-BR@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.365Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-ru@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.366Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-tr@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.366Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-uk@1.48.3 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.367Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-zh-hans@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.370Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): initializing(vscode-language-pack-zh-hant@1.80.0 with /tmp/.mount_arduindvifby/resources/app/lib/backend/plugin-vscode-init)
2024-10-14T12:48:01.376Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduindvifby/resources/app/plugins/vscode-arduino-api/extension/dist/extension.js)
2024-10-14T12:48:01.380Z root INFO [hosted-plugin: 3981] calling activation function on Arduino IDE API for VS Code extensions
2024-10-14T12:48:01.383Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduindvifby/resources/app/plugins/vscode-builtin-json-language-features/extension/client/dist/jsonMain)
2024-10-14T12:48:01.415Z root INFO [hosted-plugin: 3981] calling activation function on JSON Language Features (built-in)
2024-10-14T12:48:01.419Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduindvifby/resources/app/plugins/vscode-arduino-tools/extension/dist/extension.js)
2024-10-14T12:48:01.451Z root INFO [hosted-plugin: 3981] calling activation function on VS Code Arduino Tools
Checking for update
2024-10-14T12:48:01.932Z root INFO Replace loading indicator with ready workbench UI (animation): 896.4 ms [Finished 6.123 s after frontend start]
2024-10-14T12:48:01.932Z root INFO Changed application state from 'initialized_layout' to 'ready'.
2024-10-14T12:48:01.936Z root INFO Frontend application start: 4014.6 ms [Finished 7.481 s after backend start]
2024-10-14T12:48:01.946Z root INFO [5914059d-b5f5-4dc3-86b4-84e18aa87f7c] Starting plugins.
2024-10-14T12:48:02.332Z root INFO [hosted-plugin: 3981] PLUGIN_HOST(3981): PluginManagerExtImpl/loadPlugin(/tmp/.mount_arduindvifby/resources/app/plugins/cortex-debug/extension/dist/extension.js)
Update for version 2.3.3 is not available (latest version: 2.3.3, downgrade is allowed).
2024-10-14T12:48:02.888Z root INFO [hosted-plugin: 3981] Debug configuration provider has been registered: cortex-debug, trigger: 1
calling activation function on Cortex-Debug
GDB server console created
2024-10-14T12:48:02.893Z daemon INFO time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="arduino:arduinoOTA@1.3.0"
time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="arduino:avr-gcc@7.3.0-atmel3.6.1-arduino7"
time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="arduino:avrdude@6.3.0-arduino17"
time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="builtin:serial-discovery@1.4.1"
time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="builtin:serial-monitor@0.14.1"
time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="builtin:ctags@5.8-arduino11"
time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="builtin:dfu-discovery@0.1.2"
time="2024-10-14T13:48:02+01:00" level=info msg="Tool required for debug" tool="builtin:mdns-discovery@1.0.9"
2024-10-14T12:48:02.904Z root INFO [5914059d-b5f5-4dc3-86b4-84e18aa87f7c] Start of 23 plugins: 2359.0 ms [Finished 7.591 s after frontend start]
2024-10-14T12:48:02.951Z root INFO Starting language server: arduino:avr:uno
2024-10-14T12:48:03.124Z daemon INFO time="2024-10-14T13:48:03+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/.arduino15/libraries isSingleLibrary=false location=ide
time="2024-10-14T13:48:03+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/.arduino15/packages/arduino/hardware/avr/1.8.6/libraries isSingleLibrary=false location=platform
2024-10-14T12:48:03.124Z daemon INFO time="2024-10-14T13:48:03+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/Arduino/libraries isSingleLibrary=false location=user
2024-10-14T12:48:03.382Z daemon INFO time="2024-10-14T13:48:03+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/.arduino15/libraries isSingleLibrary=false location=ide
2024-10-14T12:48:03.382Z daemon INFO time="2024-10-14T13:48:03+01:00" level=info msg="Adding libraries dir" dir=/home/<user>/Arduino/libraries isSingleLibrary=false location=user
Marking workspace as a closed sketch. Workspace URI: file:///home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1. Date: 1728910102949.
Marking workspace as a closed sketch. Workspace URI: file:///home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1. Date: 1728910102967.
Closing channel on service path '/services/electron-window'.
Closing channel on service path '/services/ide-updater'.
Storing the sketch as a workspace root: </home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1>.
Skipped storing sketch as workspace root. Already visited: </home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1>.
Stored workspaces roots: /home/<user>/Arduino/<user>_Hack/<AppName>_<user>_Hack1.ino/<AppName>_<user>_Hack1
No sketches were scheduled for deletion.
