Hello, I'm having problems to start Arduino IDE for the first time on a PC.
Here is he code from PowerShell when the issue is reproduced:
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Arduino IDE 2.3.3
Checking for frontend application configuration customizations. Module path: C:\Program Files\Arduino IDE\resources\app\lib\backend\electron-main.js, destination 'package.json': C:\Program Files\Arduino IDE\resources\app\package.json
Setting 'theia.frontend.config.appVersion' application configuration value to: "2.3.3" (type of string)
Setting 'theia.frontend.config.cliVersion' application configuration value to: "1.0.4" (type of string)
Setting 'theia.frontend.config.buildDate' application configuration value to: "2024-09-25T09:41:18.242Z" (type of string)
Frontend application configuration after modifications: {"applicationName":"Arduino IDE","defaultTheme":{"light":"arduino-theme","dark":"arduino-theme-dark"},"defaultIconTheme":"none","electron":{"windowOptions":{}},"defaultLocale":"","validatePreferencesSchema":false,"preferences":{"window.title":"${rootName}${activeEditorShort}${appName}","files.autoSave":"afterDelay","editor.minimap.enabled":false,"editor.tabSize":2,"editor.scrollBeyondLastLine":false,"editor.quickSuggestions":{"other":false,"comments":false,"strings":false},"editor.maxTokenizationLineLength":500,"editor.bracketPairColorization.enabled":false,"breadcrumbs.enabled":false,"workbench.tree.renderIndentGuides":"none","explorer.compactFolders":false},"appVersion":"2.3.3","cliVersion":"1.0.4","buildDate":"2024-09-25T09:41:18.242Z"}
Starting backend process. PID: 10836
Using browser-only version of superagent in non-browser environment
Configuration directory URI: 'file:///c%3A/Users/GZC1TQX/.arduinoIDE'
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
2024-10-11T07:36:26.468Z root INFO Backend Object.initialize: 4.3 ms [Finished 0.531 s after backend start]
2024-10-11T07:36:26.469Z root INFO Backend Object.configure: 3.7 ms [Finished 0.531 s after backend start]
2024-10-11T07:36:26.469Z root INFO Backend a.onStart: 1.7 ms [Finished 0.531 s after backend start]
2024-10-11T07:36:26.470Z root INFO Backend a.configure: 0.3 ms [Finished 0.555 s after backend start]
2024-10-11T07:36:26.470Z root INFO Backend d.onStart: 0.2 ms [Finished 0.555 s after backend start]
2024-10-11T07:36:26.471Z root INFO Backend d.configure: 0.1 ms [Finished 0.555 s after backend start]
2024-10-11T07:36:26.472Z root INFO Backend d.initialize: 23.8 ms [Finished 0.555 s after backend start]
2024-10-11T07:36:26.472Z root INFO Backend c.onStart: 0.2 ms [Finished 0.555 s after backend start]
2024-10-11T07:36:26.472Z root INFO Backend s.configure: 2.1 ms [Finished 0.557 s after backend start]
2024-10-11T07:36:26.474Z config INFO >>> Initializing CLI configuration...
2024-10-11T07:36:26.474Z root INFO Backend c.initialize: 0.4 ms [Finished 0.557 s after backend start]
2024-10-11T07:36:26.474Z root INFO Backend x.onStart: 0.6 ms [Finished 0.558 s after backend start]
2024-10-11T07:36:26.475Z config INFO Loading CLI configuration from c:\Users\GZC1TQX\.arduinoIDE\arduino-cli.yaml...
2024-10-11T07:36:26.475Z daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\lib\backend\resources\arduino-cli.exe...
2024-10-11T07:36:26.475Z root INFO Backend s.initialize: 0.3 ms [Finished 0.558 s after backend start]
2024-10-11T07:36:26.475Z root INFO Backend w.onStart: 1.1 ms [Finished 0.559 s after backend start]
2024-10-11T07:36:26.475Z root INFO Backend r.configure: 1.7 ms [Finished 0.559 s after backend start]
2024-10-11T07:36:26.475Z discovery-log INFO start
2024-10-11T07:36:26.475Z discovery-log INFO start new deferred
2024-10-11T07:36:26.476Z root INFO Backend d.initialize: 0.4 ms [Finished 0.560 s after backend start]
2024-10-11T07:36:26.476Z root INFO Backend y.onStart: 1.9 ms [Finished 0.561 s after backend start]
2024-10-11T07:36:26.476Z root INFO Backend r.configure: 1.6 ms [Finished 0.562 s after backend start]
2024-10-11T07:36:26.476Z root INFO Backend s.onStart: 0.4 ms [Finished 0.563 s after backend start]
2024-10-11T07:36:26.476Z root INFO Backend h.configure: 0.3 ms [Finished 0.563 s after backend start]
2024-10-11T07:36:26.476Z root INFO Backend a.configure: 0.1 ms [Finished 0.563 s after backend start]
2024-10-11T07:36:26.476Z root INFO Backend l.configure: 0.1 ms [Finished 0.563 s after backend start]
2024-10-11T07:36:26.478Z root INFO Theia app listening on http://127.0.0.1:54512.
2024-10-11T07:36:26.478Z root INFO Finished starting backend application: 2.5 ms [Finished 0.565 s after backend start]
2024-10-11T07:36:26.501Z root WARN The local plugin referenced by local-dir:/c%3A/Users/GZC1TQX/.arduinoIDE/plugins does not exist.
2024-10-11T07:36:26.501Z root WARN The local plugin referenced by local-dir:/c%3A/Users/GZC1TQX/.arduinoIDE/extensions does not exist.
2024-10-11T07:36:26.501Z root WARN The local plugin referenced by local-dir:C:\Users\GZC1TQX\.arduinoIDE\plugins does not exist.
2024-10-11T07:36:26.551Z config INFO Loaded CLI configuration: {"board_manager":{"additional_urls":[]}}
2024-10-11T07:36:26.551Z config INFO Loading fallback CLI configuration to get 'directories.data' and 'directories.user'
2024-10-11T07:36:26.580Z root INFO Resolve plugins list: 105.3 ms [Finished 0.667 s after backend start]
2024-10-11T07:36:26.736Z daemon INFO time="2024-10-11T09:36:26+02:00" level=info msg="arduino-cli version 1.0.4"
time="2024-10-11T09:36:26+02:00" level=info msg="Using config file: c:\\Users\\GZC1TQX\\.arduinoIDE\\arduino-cli.yaml"
time="2024-10-11T09:36:26+02:00" level=info msg="Executing `arduino-cli daemon`"
Daemon is now listening on 127.0.0.1:54514
{"IP":"127.0.0.1","Port":"54514"}
2024-10-11T07:36:26.737Z daemon INFO Daemon is running.
2024-10-11T07:36:26.760Z daemon INFO time="2024-10-11T09:36:26+02:00" level=info msg="Starting download" url="https://downloads.arduino.cc/libraries/library_index.tar.bz2"
2024-10-11T07:36:26.769Z config INFO Loaded fallback CLI configuration: {"directories":{"user":"C:\\Users\\GZC1TQX\\Documents\\Arduino","data":"C:\\Users\\GZC1TQX\\AppData\\Local\\Arduino15"}}
2024-10-11T07:36:26.769Z config INFO Merged CLI configuration with the fallback: {"directories":{"user":"C:\\Users\\GZC1TQX\\Documents\\Arduino","data":"C:\\Users\\GZC1TQX\\AppData\\Local\\Arduino15"},"board_manager":{"additional_urls":[]}}
2024-10-11T07:36:26.770Z config INFO Loaded the CLI configuration.
2024-10-11T07:36:26.803Z config INFO Mapped the CLI configuration: {"dataDirUri":"file:///c%3A/Users/GZC1TQX/AppData/Local/Arduino15","sketchDirUri":"file:///c%3A/Users/GZC1TQX/Documents/Arduino","additionalUrls":[],"network":"none","locale":"en"}
2024-10-11T07:36:26.803Z config INFO Validating the CLI configuration...
2024-10-11T07:36:26.803Z config INFO The CLI config is valid.
2024-10-11T07:36:26.803Z config INFO <<< Initialized the CLI configuration.
2024-10-11T07:36:27.405Z root INFO Deploy plugins list: 105.3 ms [Finished 1.492 s after backend start]
Opening channel for service path '/services/electron-window'.
Opening channel for service path '/services/ide-updater'.
2024-10-11T07:36:28.296Z root WARN Frontend a.configure took longer than the expected maximum 100 milliseconds: 141.0 ms [Finished 1.714 s after frontend start]
2024-10-11T07:36:28.296Z root WARN A command editor.action.toggleStickyScroll is already registered.
[18604:1011/093628.382:ERROR:accelerator_util.cc(24)] The accelerator string can only contain ASCII characters, invalid string: "Ctrl+ç"
