Hi please help i have been struggling to compile a code in the new Arduino IDE version, it gives me this same error
Compilation error: Error: 2 UNKNOWN: exit status 1
//Inclusion of libraries to be used in the project
#include "SD.h"
#include <NTPClient.h>
#include <WiFiUdp.h>
#include "Nextion.h"
NexNumber p0_n0 = NexNumber(0,10,"n0");
NexNumber p0_n1 = NexNumber(0,6,"n1");
NexNumber p0_n2 = NexNumber(0,7,"n2");
NexNumber p0_n3 = NexNumber(0,8,"n3");
NexNumber p0_n4 = NexNumber(0,9,"n4");
// Define deep sleep options
uint64_t uS_TO_S_FACTOR = 1000000; // Conversion factor for micro-seconds to seconds
// Sleep for 10 minutes = 600 seconds
uint64_t TIME_TO_SLEEP = 600;
// Define CS pin for the SD card module
#define SD_CS 5
// Save reading number on RTC memory
RTC_DATA_ATTR int readingID = 0;
String dataMessage;
//Initialising SPI
#define BME_SCK 18
#define BME_MISO 19
#define BME_MOSI 23
#define BME_CS 15
Adafruit_BME680 bme; // object to be used for I2C communication
//Adafruit_BME680 bme(BME_CS); // hardware SPI
//Adafruit_BME680 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK);
//Declaration of variables for measurements
float temperature;
float humidity;
float pressure;
float gasResistance;
const int potPin = 34;
int potValue = 0;
//Initiation of a Web Server on port 80 to transmit data to web browser using //Server-Sent Events(SSE) through HTTP connection
AsyncWebServer server(80);
AsyncEventSource events("/events");
/*lastTime and timerDelay variables used to update readings in a client from sensor every 30 seconds*/
unsigned long lastTime = 0;
unsigned long timerDelay = 30000;
void getBME680Readings(){
// Tell BME680 to begin measurement.
unsigned long endTime = bme.beginReading();
if (endTime == 0) {
Serial.println(F("Failed to begin reading :("));
return;
if (!bme.endReading()) {
Serial.println(F("Failed to complete reading :("));
return;
temperature = bme.temperature;
pressure = bme.pressure / 100.0;
humidity = bme.humidity;
gasResistance = bme.gas_resistance / 1000.0;
//Write file into SD card
void writeFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Writing file: %s\n", path);
File file = fs.open(path, FILE_WRITE);
if(!file) {
Serial.println("Failed to open file for writing");
return;
if(file.print(message)) {
Serial.println("File written");
Serial.println("Write failed");
file.close();
String processor(const String& var){
getBME680Readings();
//Serial.println(var);
if(var == "TEMPERATURE"){
return String(temperature);
else if(var == "HUMIDITY"){
return String(humidity);
else if(var == "PRESSURE"){
return String(pressure);
else if(var == "GAS"){
return String(gasResistance);
/*The following variable - index_html has all the HTML, JavaScript and CSS code to build a client web page, this code sets the cards, texts, icons, colours and layout of the page*/
const char index_html[] PROGMEM = R"rawliteral(
<!DOCTYPE HTML><html>
<head>
<title>Simelane S.A - 21615701</title>
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="https://use.fontawesome.com/releases/v5.7.2/css/all.css" integrity="sha384-fnmOCqbTlWIlj8LyTjo7mOUStjsKC4pOpQbqyi7RrhN7udi9RwhKkMHpvLbHG9Sr" crossorigin="anonymous">
<link rel="icon" href="data:,">
<style>
html {font-family: Arial; display: inline-block; text-align: center;}
p { font-size: 1.2rem;}
body { margin: 0;}
.topnav { overflow: hidden; background-color: #4B1D3F; color: white; font-size: 1.7rem; }
.content { padding: 20px; }
.card { background-color: white; box-shadow: 2px 2px 12px 1px rgba(140,140,140,.5); }
.cards { max-width: 700px; margin: 0 auto; display: grid; grid-gap: 2rem; grid-template-columns: repeat(auto-fit, minmax(300px, 1fr)); }
.reading { font-size: 2.8rem; }
.card.temperature { color: #0e7c7b; }
.card.humidity { color: #17bebb; }
.card.pressure { color: #3fca6b; }
.card.gas { color: #d62246; }
</style>
</head>
<body>
<div class="topnav">
<h3>Simelane S.A - 21615701</h3>
</div>
<div class="content">
<div class="cards">
<div class="card temperature">
<h4><i class="fas fa-thermometer-half"></i> TEMPERATURE</h4><p><span class="reading"><span id="temp">%TEMPERATURE%</span> °C</span></p>
</div>
<div class="card humidity">
<h4><i class="fas fa-tint"></i> HUMIDITY</h4><p><span class="reading"><span id="hum">%HUMIDITY%</span> %</span></p>
</div>
<div class="card pressure">
<h4><i class="fas fa-angle-double-down"></i> PRESSURE</h4><p><span class="reading"><span id="pres">%PRESSURE%</span> hPa</span></p>
</div>
<div class="card gas">
<h4><i class="fas fa-wind"></i> GAS</h4><p><span class="reading"><span id="gas">%GAS%</span> KΩ</span></p>
</div>
<div class="card CO2">
<h4><i class="fas fa-wind"></i> CO2</h4><p><span class="reading"><span id="CO2">%CO2%</span> %</span></p>
</div>
</div>
</div>
<script>
/*Client initiates the SSE connection by an EventSource object then listens for- events – updates from the Server – events in this case will be temperature,- humidity, pressure, gas and CO2*/
if (!!window.EventSource) {
var source = new EventSource('/events');
source.addEventListener('open', function(e) {
console.log("Events Connected");
}, false);
source.addEventListener('error', function(e) {
if (e.target.readyState != EventSource.OPEN) {
console.log("Events Disconnected");
}, false);
source.addEventListener('message', function(e) {
console.log("message", e.data);
}, false);
source.addEventListener('temperature', function(e) {
console.log("temperature", e.data);
document.getElementById("temp").innerHTML = e.data;
}, false);
source.addEventListener('humidity', function(e) {
console.log("humidity", e.data);
document.getElementById("hum").innerHTML = e.data;
}, false);
source.addEventListener('pressure', function(e) {
console.log("pressure", e.data);
document.getElementById("pres").innerHTML = e.data;
}, false);
source.addEventListener('gas', function(e) {
console.log("gas", e.data);
document.getElementById("gas").innerHTML = e.data;
}, false);
source.addEventListener('CO2', function(e) {
console.log("CO2", e.data);
document.getElementById("CO2").innerHTML = e.data;
}, false);
</script>
</body>
</html>)rawliteral";
/*Define NTP Client to get time from the internet using Network Time Protocol – same protocol used to get Time in gadgets*/
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
// Variables to save date and time
String formattedDate;
String dayStamp;
String timeStamp;
void getReadings(){
void getTimeStamp() {
while(!timeClient.update()) {
timeClient.forceUpdate();
//The formattedDate comes with the following format: 2018-05-28T16:00:13Z
// extracting date and time
formattedDate = timeClient.getFormattedDate();
Serial.println(formattedDate);
// Extract date
int splitT = formattedDate.indexOf("T");
dayStamp = formattedDate.substring(0, splitT);
Serial.println(dayStamp);
// Extract time
timeStamp = formattedDate.substring(splitT+1, formattedDate.length()-1);
Serial.println(timeStamp);
// Append data to the SD card
void appendFile(fs::FS &fs, const char * path, const char * message) {
Serial.printf("Appending to file: %s\n", path);
File file = fs.open(path, FILE_APPEND);
if(!file) {
Serial.println("Failed to open file for appending");
return;
Serial.println("Message appended");
Serial.println("Append failed");
file.close();
// Write the sensor readings on the SD card – useful for Data logging
void logSDCard() {
dataMessage = String(readingID) + "," + String(dayStamp) + "," + String(timeStamp) + "," + String(temperature) + "," + String(humidity) + "," + String(pressure) + "," + String(gasResistance) + "\r\n";
Serial.print("Save data: ");
Serial.println(dataMessage);
appendFile(SD, "/data.txt", dataMessage.c_str());
nexInit();
// Set the device as a Station and Soft Access Point simultaneously
WiFi.mode(WIFI_AP_STA);
// Set device as a Wi-Fi Station
WiFi.begin(ssid, password);
Serial.println("Setting as a Wi-Fi Station..");
Serial.print("Station IP Address: ");
// Init BME680 sensor
if (!bme.begin()) {
Serial.println(F("Could not find a valid BME680 sensor, check wiring!"));
while (1);
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
// Handle Web Server
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/html", index_html, processor);
// Handle Web Server Events
events.onConnect([](AsyncEventSourceClient *client){
if(client->lastId()){
Serial.printf("Client reconnected! Last message ID that it got is: %u\n", client->lastId());
// send event with message "hello!", id current millis
// and set reconnect delay to 1 second
client->send("hello!", NULL, millis(), 10000);
server.addHandler(&events);
server.begin();
// Initialize a NTPClient to get time
timeClient.begin();
// Set offset time in seconds to adjust for your timezone, for example:
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
timeClient.setTimeOffset(7200);
// Initialize SD card
SD.begin(SD_CS);
if(!SD.begin(SD_CS)) {
Serial.println("Card Mount Failed");
return;
uint8_t cardType = SD.cardType();
if(cardType == CARD_NONE) {
Serial.println("No SD card attached");
return;
Serial.println("Initializing SD card...");
if (!SD.begin(SD_CS)) {
Serial.println("ERROR - SD card initialization failed!");
return; // init failed
// If the data.txt file doesn't exist
// Create a file on the SD card and write the data labels
File file = SD.open("/data.txt");
if(!file) {
Serial.println("File doens't exist");
Serial.println("Creating file...");
writeFile(SD, "/data.txt", "Reading ID, Date, Hour, Temperature, Humidity, Pressure, Gas Resistance \r\n");
else {
Serial.println("File already exists");
file.close();
// Enable Timer wake_up
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
//getReadings();
//getTimeStamp();
//logSDCard();
// Increment readingID on every new reading
//readingID++;
// Start deep sleep
Serial.println("DONE! Going to sleep now.");
//esp_deep_sleep_start();
if ((millis() - lastTime) > timerDelay) {
Serial.printf("Temperature = %.2f ºC \n", temperature);
Serial.printf("Humidity = %.2f % \n", humidity);
Serial.printf("Pressure = %.2f hPa \n", pressure);
Serial.printf("Gas Resistance = %.2f KOhm \n", gasResistance);
potValue = analogRead(potPin);
Serial.print("potValue");
Serial.print(" ");
Serial.println(potValue);
// Send Events to the Web Server with the Sensor Readings
events.send("ping",NULL,millis());
events.send(String(temperature).c_str(),"temperature",millis());
events.send(String(humidity).c_str(),"humidity",millis());
events.send(String(pressure).c_str(),"pressure",millis());
events.send(String(gasResistance).c_str(),"gas",millis());
events.send(String(potValue).c_str(),"CO2",millis());
lastTime = millis();
getReadings();
getTimeStamp();
logSDCard();
readingID++;
float tmp = temperature * 1000;
float hum = humidity * 1000;
float pres = pressure * 1;
float aq = gasResistance * 10;
float co = potValue;
p0_n0.setValue(tmp);
p0_n1.setValue(hum);
p0_n2.setValue(pres);
p0_n3.setValue(aq);
p0_n4.setValue(co);
