Arduino IDE and ATTiny45
Hi Gang
I'm keen to use the Arduino IDE to program an ATTiny45. I've watched the following video How-To: Shrinkify Your Arduino Projects but I'm having a problem. If I click Tools > Boards none of the ATTiny boards appear. I've followed the instructions and placed the appropriate folders and files in the correct locations. Any help would be greatly appreciated.
OS: Windows 8
Arduino IDE: Arduino 1.5.6-r2
Sketchbook Location: C:\Users\Jason\Documents\Arduino
File path for attiny: This PC > Documents > Arduino > hardware > attiny
Cheers
Jase :slight_smile:
Did you install the third-party core?
(deleted)
If you use this core for the tiny:
https://code.google.com/p/arduino-tiny/
You can choose between ARduino 1.xx and 1.5XX
Hi Gang
Sorry for the late reply. I've been under the weather.
@Erni: I've downloaded the latest version for 1.5 but the boards still do not appear. :frowning:
@spycatcher2k: Will an earlier version of Arduino work with Windows 8.1?
@johnwasser: I've tried installing both cores. :frowning:
Cheers
Jase :slight_smile:
I'm using 1.0.5 on 8.1 successfully. And programming ATTiny85s.
Make sure you follow the instructions in the README. Often times the Boards.txt file is not completed properly.
Hi Gang
Thanks for the responses. I've followed through the instructions in the README file. I'm unsure what the following instruction means?
* In the "boards.txt" file, change the "upload.tool" entries to the appropriate value for your setup.
If I check the text file I find the following.
attiny45at8.upload.tool=arduino:arduinoisp
What do I need to do with the above statement?
As always appreciate the help.
Cheers
Jase :slight_smile:
ilovetoflyfpv:
Hi Gang
Cheers
Jase :slight_smile:
Just make sure that the other options are commented out with a hash mark like this
attiny84at1.upload.using=arduino:arduinoisp
# attiny84at1.upload.protocol=avrispv2
# attiny84at1.upload.using=pololu
That's all :slight_smile:
