Arduino-ide blank on startup
Hello,
I just received my arduino and I'm trying to get myself up and running with it. I have the latest arduino-ide (0015). When i double click on the arduino.exe it loads up but the window is blank.
Any ideas? Thanks
Here's a screenshot:
What machine and OS are you using?
XP Pro SP3 3.2Ghz P4, 1gb Ram.
I am having the same problem i.e. blank window. My OS is Windows XP Home edition SP3 Ver 5.1 Additional info is I have Java (Version 6 Update 13) installed. Sure would be nice to get it working.
... jon
Good News: Edit the run.bat file and follow the directions down at the bottom of the file: :Error echo *** Error: cannot execute Arduino echo *** Reason: lacking the directory where to find Java in your computer echo *** echo *** Fix: Edit run.bat and add the JAVA_HOME directory echo *** at the 'set JAVA_HOME=""' line echo *** echo *** then call the batch file run.bat in order to execute Arduino
Work fine now. ... jon
