Arduino IDE board password request when uploading via scp
I'm trying to upload a sketch to my Arduino Yun via WIFI.
I can ssh as root without password (keys) to the Yun and I have .ssh/config configured as well for both the IP address and arduino.local.
➜  ~ ssh root@192.168.0.29        13:19 19/07/2017
BusyBox v1.19.4 (2014-11-13 19:03:47 CET) built-in shell (ash)
Enter 'help' for a list of built-in commands.
  _______                     ________        __
 |       |.-----.-----.-----.|  |  |  |.----.|  |_
 |   -   ||  _  |  -__|     ||  |  |  ||   _||   _|
 |_______||   __|_____|__|__||________||__|  |____|
          |__| W I R E L E S S   F R E E D O M
root@Arduino:~#
When I try to upload via WIFI I'm prompted for a "board password"; I tried with the only password I know, root, and that doesn't work.
I tried with and without .ssh/config in place with same results.
I'm running the IDE on OSX, version 1.8.3. I tried the hourly builds with the same results.
Tried also upgrading firmware to latest with no luck.
I spent some time going through the java code of the IDE but I haven't quite figured out where this prompt comes from and to which password it refers to.
Attached a screenshot of the prompt.
Any help is much appreciated since I'm kind of stuck and it'd be a pity to have to use a USB cable :confused:
Thanks!!!
G.
probes (91.8 KB)
(deleted)
Depending on when you bought your board, the default password could also be "doghunter".
It should be the same password you use to log onto the Yun's configuration web pages - the pages you get when you point your web browser to your Yun, http://192.168.0.29 using the address from your ssh output.
When new, your Yun had a default password like arduino or doghunter. You likely changed it when going through the initial setup process - if so, that's the password you need to use.
You may have changed your ssh configuration to not need a password (not necessarily a good idea) but that is likely to only affect ssh, and not the configuration web pages or sketch upload process.
