I've checked all the troubleshooting pages I can find but nothing like this appears.
I had this project running two years ago, but wanted to update it. Since then, I have a new laptop with Windows 10 and latest IDE. The libraries are the same as were used 2 years ago, except for Blynk.
If I comment out the ADXL345 and I2C libraries, it will compile. The error report mentions the I2C.
I can't even compile for the starter program. See below;
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <Wire.h>
#include <SimpleTimer.h>
#include <ADXL345.h>
#include <I2Cdev.h>
This is the error log that results from trying to compile this;
Arduino: 1.8.8 (Windows 10), Board: "SparkFun ESP8266 Thing, 80 MHz, Flash, Enabled, 512K (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200"
C:\Program Files (x86)\Arduino\libraries\I2Cdev\I2Cdev.cpp: In static member function 'static int8_t I2Cdev::readBytes(uint8_t, uint8_t, uint8_t, uint8_t*, uint16_t)':
C:\Program Files (x86)\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: error: no matching function for call to 'min(uint8_t&, int)'
for (uint8_t k = 0; k < length; k += min(length, BUFFER_LENGTH)) {
C:\Program Files (x86)\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: note: candidates are:
In file included from c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\algorithm:62:0,
from C:\Users\capek\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0-beta2\cores\esp8266/Arduino.h:257,
from C:\Program Files (x86)\Arduino\libraries\I2Cdev\I2Cdev.h:80,
from C:\Program Files (x86)\Arduino\libraries\I2Cdev\I2Cdev.cpp:46:
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note: template<class _Tp, class _Compare> _Tp std::min(std::initializer_list<_Tp>, _Compare)
min(initializer_list<_Tp> __l, _Compare __comp)
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4226:5: note: template argument deduction/substitution failed:
C:\Program Files (x86)\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: note: mismatched types 'std::initializer_list<_Tp>' and 'unsigned char'
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note: template _Tp std::min(std::initializer_list<_Tp>)
min(initializer_list<_Tp> __l)
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algo.h:4221:5: note: template argument deduction/substitution failed:
In file included from c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\algorithm:61:0,
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note: template<class _Tp, class _Compare> const _Tp& std::min(const _Tp&, const _Tp&, _Compare)
min(const _Tp& __a, const _Tp& __b, _Compare __comp)
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:239:5: note: template argument deduction/substitution failed:
C:\Program Files (x86)\Arduino\libraries\I2Cdev\I2Cdev.cpp:276:75: note: deduced conflicting types for parameter 'const _Tp' ('unsigned char' and 'int')
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note: template const _Tp& std::min(const _Tp&, const _Tp&)
min(const _Tp& __a, const _Tp& __b)
c:\users\capek\appdata\local\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:193:5: note: template argument deduction/substitution failed:
exit status 1
Error compiling for board SparkFun ESP8266 Thing.
option enabled in File -> Preferences.
I hope someone can help.
Thanks.
Mike
